Question about Kyocera Office Equipment & Supplies
Kyocera KM-3050 error 1105
Km-3050
  • 43 Answers
SOURCE: error code C-6 for kyocera km 1500
Fuser error,
may have either a blown lamp, blown thermo fuse or faulty thermistors, but more then likely a combination of at least two.
Posted on Mar 02, 2008
sir fixalot
  • 146 Answers
SOURCE: Kyocera KM 3050 - error C3300
Error C3300 is a CCD Automatic Gain Control issue.
It could be poor contact in the connector terminals from the SHD PWB to the CCD PWB.
It is more likely a defective exposure lamp or inverter board that powers the lamp.
Try lifting up the Document feeder so you can see the optics frame through the platen glass and turning off and then on, the main power switch to see if the green exposure lamp illuminates.
A better, but more complicated way to check the lamp is to enter the service mode and run the exposure lamp test simulation. I will outline this procedure below. BE SURE NOT TO MESS WITH OTHER THINGS IN SERVICE MODE OR YOU COULD RENDER YOUR UNIT COMPLETELY UNUSABLE.
To Enter Service Mode:
Hit the "Status" button
Hit the following sequence on the numerical keypad:
1 0 8 7 1 0 8 7
You should be in service mode.
Use U601 by typing 6 0 1 and then "Start"
U601: Turning the exposure lamps on
Description: Turns the exposure lamp on.
Purpose: To check the exposure lamp.
Display:
CCD: Main Exposure Lamp
CID: Document Processor Exposure Lamp (inside the feeder)
Method
1. Press the start key.
2. Select the item.
3. Press the start key. The selected lamp lights.
4. To turn the exposure lamp off, press the stop key.
Completion
Press the stop key. The screen for selecting a maintenance item No. is displayed.
After checking the lamp(s) operation hit "reset" a few times to back out where you can type 0 0 1 "Start" to Exit Service Mode.
Posted on Jun 03, 2008
SOURCE: Have error: C6000 on Kyocera
Have Kyocera FS-1118MFPF that is coming up with Error C6000. Can we fix this ourselves
Posted on Sep 25, 2008
  • 126 Answers
SOURCE: KYOCERA MITA KM-1500 ERROR CODE C7980
C-7980 - Means that the waste tonerresevoir in the process unit is full with less than 100,000 copies onthe unit.
Clean/ empty the waster toner and vac.Also clean the sensor.
You may have to change the Process unit if cleaning does not work.
Posted on Mar 02, 2009
krizanto81
  • 65 Answers
SOURCE: what is code error E70 on kyocera km-1510
the problem e70 is concerning with the document processor of ur machine. either there is a jammed paper on it or the actuator of ur switch on the document processor is broken.
Posted on Jun 27, 2009
How to get print history of kyocera km-3050
you cannot print but you can view it only.
click on the panel the STATUS button
under printing you can view the print logs.
Good Luck!
Apr 13, 2016 | Kyocera Office Equipment & Supplies
HOW CAN I CLEAR ERROR CODE CFB 30 ON KM 3050
Abort Code recommended you have a tech come and re-flash the copier firmware. Firmware is the copiers Operating system not a driver. Firmware is only available thru secure server available to dealerships and KMBS
Jan 30, 2016 | Kyocera Mita KM-3050 4050 Toner Black...
Kyocera repair
press status button enter 1087 1087 then 201 start press flashing crosshairs with pen point then enter 01 start
Sep 02, 2014 | Kyocera Copystar Fax System M Km-5050...
Error cfb30
Try upgrading the latest firmware
Aug 24, 2014 | Kyocera Copystar Fax System M Km-5050...
C6000 on Kyocera KM-3050
you can try to reset the error code by going into
simulation mode
at the machine punch in 10871087
once in simulation mode.. go to sim 163
that's a fuser reset
execute that..
if problem persists you need to replace fuser
Mar 10, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
SYSTEM ERROR
error 610 machine kyocera km-3035 ????
Nov 05, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Have error: C6000 on Kyocera KM-3050
Aug 02, 2008 | Office Equipment & Supplies
71 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
