Question about Garmin eTrex Legend GPS Receiver
Shuts down turn on gps. after a few minites it shuts down and has a line on the screen. the only way to get rid of the line is to pull the batteries.
  • 3 more comments
  • Anonymous Dec 17, 2008
    Same thing.
    Scouring the internet for ideas on what it could be...
  • lucasavaitor Dec 20, 2008
    Yeah, I have the same problem, where did you get this software update?
  • brewerjk Dec 30, 2008
    I have the same problem. I will try the update.
    Thanks
  • Anonymous Jan 04, 2009
    I get some reception, but when I change screens or try to adjust the zoom it shuts off leaving only a slightly right of center vertical line on the screen. The only way to remove the line was to remove the battery/power source. I will update
  • keithtrojan Jan 06, 2009
    i also have the same problem etrex legend.
  • Garmin Master
  • 638 Answers
Go to the Garmin website, search for your particular unit. Download and install the specific unit software and it will clear up this problem. This problem is caused by a new satellite launched in March 2008, the update fixes it.
Posted on Jan 02, 2009
Software update from garmin will fix the problem
Posted on Oct 29, 2008
Vertical lines screen shuts down
This problem has different solutions depending on your tomtom model.
A flat and or faulty battery on some models and a faulty display panel on others. More info required
Jan 28, 2014 | Tomtom One GPS
Touch screen does not work
I had the same problem.
I fixed it by running the battery completely down.
Leave it on until it shuts down, then turn it back on till it shuts down again.
Repeat this a few times to make sure the battery is completely discharged.
After that, I plugged it into a power source and it worked fine.
Jan 06, 2011 | Garmin Nuvi 660 GPS Receiver
The unit runs Ok for a few minutes and then shuts down.
Does it do this on just battery power or with an external power source? If on battery poer, then the battery if defective.
- Jim
Jul 20, 2010 | Garmin Nuvi 660 GPS Receiver
The gps automatically shuts off after few minutes
When you turn the unit on and get to the screen showing Where To?, View Map and Travel Kit look on the upper right hand corner of the display and make sure you see the battery icon all green. If it is not then the battery is not charged
Apr 04, 2010 | Garmin Nuvi 660 GPS Receiver
5yr old Garmin 76s shuts off
KUDOS! Others with the same problem informed me that it is a softwear problem and to download the 4.0 version free on the Garmin web site....l'll do it ASAP and write again if it doesn't work...RG
Jul 19, 2009 | Garmin GPSMAP 76 GPS Receiver
My unit will not turn on when i start my car
Change battery, or check charge wire if hard wired. i would think your battery needs complete change. The reason for delay is usually the fact that it has reached the end of its life and takes some time to build enough charge to drive the display. The power pull is greater than the ability to store, so that is why it shuts down
Jun 22, 2009 | Pioneer AVIC-F700BT Car GPS Receiver
After several munutes of on the screen goes to
I have a Garmin Street Pilot c330 which when plugged in and power button pushed, the screen lights up for a few seconds and shuts down. It was giving a low battery warning before shutting down. Where is teh battery in teh unity? and should I replace the fuse?
Apr 22, 2009 | Magellan Maestro 4040 GPS Receiver
Shuts off, won't charge battery
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 26, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin Nuvi shuts itself off after only seconds during navigation
Is the battery charged? What does the battery indicator say? If you are using it in the car, is the power cord connected and working properly? If it is working correctly, you should see a lightning bolt symbol over the battery bar graph showing that it is connected to an external power source and that it is charging.
- Jim
Jan 23, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin etrex legend
I had this problem today, updated the software, now the unit seems to be working perfectly. The unit "crashes" (single line down screen center) as soon as it get enough satelites to work with WAAS.
Go to Garmin site for software updates. Download and install the WebUpdater. Once or unit is hooked up to your computer and you have internet access, the software will download and update your GPS with the latest software fixes. I had software Version 3.7. For the Legend, Version 3.9 fixes the problems with WAAS.
Jan 04, 2008 | Garmin eTrex Legend GPS Receiver
Garmin eTrex Legend GPS Receiver Logo
141 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
