Question about Forfex Health & Beauty
Replacement battery for Forfex type 13 FX652V
Batteries Required are Panasonic 600 rechargeable
SOURCE: Norelco 3805 XL Battery Replacement
I was able to open mine with a 2.4mm slotted screwdriver from one of those mini-screwdriver sets you can get at the store for a couple of bucks. Be aware that the batteries are soldered to the circuit board in this particular razor.
Posted on Jul 20, 2008
  • 10 Answers
SOURCE: need replacement battery for braun Model number 5000-type 5724
Shaver Replacement Battery AA NiMh type
NiMh shaver battery pack with easy solder tabs, dimensions of battery are 1 11/16 length x 9/16 diameter. Battery is 1650 mAhWill fits several older model Braun shavers, $9.99. Contact http://shaveroutlet.com/ for detailed info. Older model Braun shaver batteries don't come on a circuit board and involve soldering.
Since I have never dissembled this model ask Shaver Outlet via e-mail if you buy the parts from them. They have been most helpful to me.
Posted on Aug 29, 2009
brector3
  • 1602 Answers
SOURCE: Need to replace batteries in a 5775 shaver. How to
First, be sure that you have the correct number. There is a model 5775 and a type 5775 which are different. Installation and battery type differs depending on which you have
Posted on Jan 16, 2010
SOURCE: replacing battery in forfex fx652
Hello, where did you get the replacement battery????
Posted on Feb 19, 2010
brector3
  • 1602 Answers
SOURCE: short rechargable battery life...can I
you will find the correct replacement battery type at shaveroutlet.com. see link below
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-battery-pack-for-most-shavers-p-211.html
Posted on Nov 04, 2010
My Panasonic modelkx-tg4741will only charge on one charging stand out of four. the base will not charge. I installed new batteries in each phone
1. Check the power supply from the wall outlets being used for all phones and check the wiring connections to the phones.
2. These phones can only use Nickel metal hydride (Ni-MH) batteries. Don't use some other type of rechargeable battery such as a Ni -Cd rechargeable battery. Check that the battery installed in all the handsets is the Ni-MH type.
3. Clean the contact points on the charging stands and base unit.
4. Remove all the batteries from the handsets and clean the battery contact points.
Nov 13, 2015 | Panasonic Lands Phones
The battery does not seem to work anymore as it should be a rechargable battery. Even if i charge it for more than 8 hours, the battery goes out quickly. I want to know what kind/type rechargable battery...
In most shavers it is possible to strap the EQUIVALENT VOLTAGE/CURRENT cells in series/parallel to give the correct specified rating needed for the battery. If the original is hard to find or is very epensive I have tried many times to change with AAA or AA with rating of over 1000mA cells to be soldered together as required.
I hope you can remove and check the spaces within to try with this arrangement. If not replace with the original from Panasonic.
Jul 20, 2011 | Panasonic ES 366 S Electric Shaver
Philips SE 455 twin set cordless: The charge lasts less than an hour when using speaker phone, so I am looking for replacement batteries. Phones only 2-3 years old and absolutely fine in all other...
A higher capacity battery should work even better because a fully charged 900 mAh battery allows the phone to operate 50% longer than a 600 mAh battery between charges. I have had good results with Rayovac Recharge Plus 900 mAh in my Philips SE450. This phone will latch and not operate upon ringing if it doesn't like its batteries (probably high internal resistance), even though the batteries test good on a battery tester.
Jun 28, 2011 | Philips 2252 Twin Cordless Phone
What kind of batteries do I need? can I use duracel Ni-MH rechargables?
The operating manual specifies to use only Ni-MH AAA batteries and warns to not use Alkaline/Manganese/Ni-Cd batteries. Panasonic web site lists replacement batteries at 19.95 for a pair.
Duracel Ni-MH AAA batteries will be fine.
Dec 10, 2010 | Panasonic (KX-TG1032S) Phone
Where can i get replacement batteries for a Panasonic ES7103. i only get about 3 shaves then it needs a recharge. Thanks
Panasonic does not allow the sale of their specialized shaver batteries to consumers. For additional information, try calling Panasonic at 1-800-338-0552
Dec 02, 2010 | Panasonic ES 8077S Electric Shaver
Rechargeable battery
Hi, try looking on ebay, user name; itl-e. His shop name is; Component-shop. A wide range of batteries supplied including a 6V 5AH which sells for about £8 including p&p. Your Panasonic battery is rated at 6V 4.2AH, so the replacement will last slightly longer between charges. If you want an exact (Panasonic) replacement, try putting "Panasonic LC-R064R2CH into google.
Hpoe this helps! Bob.
Oct 05, 2008 | VAX Appliances V037 Stick Wet/Dry Vacuum
Panasonic CD PLayer SL-CT520 Rechargeable AAA Batteries
Hey this is RaulFixall. You can fix this problem by naking the batteries, I'm mean by taking apart the plastic that cover them. You'll see that the led charging will turn on.
Nov 20, 2007 | Audio Players & Recorders
Health & Beauty Logo
Top Forfex Health & Beauty Experts
Robin Hill
Robin Hill
Jeff Tilburn
Jeff Tilburn
Are you a Forfex Health and Beauty Expert? Answer questions, earn points and help others
