Question about AEG Ovens
My AEG 4100-1-M oven switches off after 15 min.
Every time I want to use the grill or the oven it switchess off after 15min even when I have set the time to 1 hr.
  • 1462 Answers
SOURCE: B3101 AEG oven cuts out after approx. 15 minutes - why?
this is probably the thermal cut-out causing the problem. not sure where it is located but possibly on the roof of the oven or in the rear casing near the fan. however, the cause may be lack of ventilation to the unit as a whole
Posted on Mar 26, 2007
  • 26 Answers
SOURCE: My large main oven will
Is the clock set? The display must show the correct time and must not be set to automatic cooking.
If the light comes on and the fan is working then the clock is set. If there is no heat then the element behind the cover and surrounding the fan is probably open circuit. This can be accessed without needing to remove the oven from the carcass.
Good luck
Posted on Nov 27, 2008
barkencoa
  • 3463 Answers
SOURCE: aeg competence b2190-1m oven not heating
If the fan is working o/k, then you need replace the oven element.
To access this, remove inner rear cover of oven, there you will see the circular element.
Unscrew the screws securing it ,and remove element.
Detach wires and transfer to new element, be careful not to lose the wires behind the oven rear, refit element and rear cover.
please rate my solution.
Thanks
Posted on Jan 27, 2009
barkencoa
  • 3463 Answers
SOURCE: AEG Competence Oven not working
If you are certain that the element is o/k, and it is not heating, then thwere are 2 possibilitues.
1- the oven thermostat could be faulty, whereby it is giving a feed to the element.
2-some ovens have a fan only setting, as well as heat and fan, make sure that it is not on a fan only setting.
Hope this helps.
Posted on Feb 05, 2010
barkencoa
  • 3463 Answers
SOURCE: AEG Competence D2160-1m2 (double oven)
You neede to replace the oven element.
This is located at the rear of the oven compartment behind a removeable cover.
Posted on Feb 24, 2010
The light on my aeg competence oven and grill is not working. I can not use the timer.
It's either the thermostat / switch or the timer unit. Make sure the timer was not set to have turned off the grill first
http://www.espares.co.uk/part/cookers-and-hobs/thermostats/aeg/p/1604/143/0/0/1061574/top-oven-thermostat.html
May 20, 2010 | Ovens
The top oven of our AEG D5701-4 is slow to heat.
Hi it could be the element on the grill it maybe burning out, what slows the grill to get hot quicker. best to turn of the mains or by the main switch. and get a toorch to check around the element or use a continental reader check if it is receving 240volts
Mar 09, 2010 | AEG D5701-4 Electric Double Oven
Hope this helps.
Feb 05, 2010 | AEG Ovens
Oven is AEG Competence, single oven, fan assisted, 4 yrs old. Oven doesn't heat. Light ok, automatic cooking settings not switched on, grill working
If the fan is working o/k, then you need to replace the oven element.
This is located at the rear of the oven compartment, behind a removeable cover.
This should solve the prob.
Please leave feed back.
Thankyou.
Jan 06, 2010 | AEG Ovens
Aeg oven d4100 cutting out
There is a cooling fan in the cabinet of the oven which is not working either the fan is faulty or the controling cut in stat is, The fan should run when the grill is selected if does not it is more likely to be the fan/motor at fault.
Dec 07, 2009 | AEG D2100-4 Electric Double Oven
I have a Competence B1180, it cuts out after irregular periods of time, although sometimes it may even complete a cooking cycle, if turned off for 10-15min it will re-start, but invariably cuts out again...
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turnig then replace fan. If mains voltage is not present then its the thermal switch.
Mar 01, 2009 | AEG B1180-4 Electric Single Oven
AEG 3032 Oven, no light, no main fan, no heat to grill or oven however the exhaust fan does operate when the grill/oven is switched on. The thermostat clicks when moved from 0 to a higher temperature but...
If you are sure the timer is set to manual and not auto , then I would say that it sounds like the selector switch is faulty or the thermostat is faulty, some times they are combined as one unit, and sometimes they are 2 separate switches.
You need to remove top cover of oven and have a look inside the control panel and see if there is anything obvious like a burnt wire or bad connection
If it is a combined unit, then sometimes the 2 parts of the unit become disengaged or the cam inside the switch breaks.
Plz rate my solution .
Thanks.
Jan 05, 2009 | AEG B1180-4 Electric Single Oven
Belling synergie. oven does not heat up. grill ok. think i need to set to manual but how???
if its flashing auto.
Press and hold the 2 buttons on the left hand - clock and cook time and then press the + button.
This then sets the time to allow manual and takes the auto off.
cheers
will
Dec 24, 2007 | Belling XOU592 / XOU593 Electric Double...
Nov 21, 2006 | AEG B3101-4 Electric Single Oven
Oven switching off
Hello, this is a commom problem. The cooling fan is not working correctly and you need a new controller. The part number is 8996619267611 and costs about £28.00.
Nov 11, 2006 | AEG B1180-4 Electric Single Oven
Ovens Logo
26 people viewed this question
Top AEG Ovens Experts
ashburton
Sal DeAngelo
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
