My Hitachi washing machine Model is SF80-FJ. But, it is not working in spin option. It is always displaying C4 error. why?
  • 641 Answers
SOURCE: Hitachi SF-H900TPX Washing Machine not working properly
Open machine's service panel and check whether the motor spins. Let us know with your results and we will see how could we assiste you further.
Posted on Aug 31, 2007
Krazytech
  • 725 Answers
SOURCE: Hitachi Washing Machine model SAF-2000PX
check the lid switch ... make sure it is make contact and the the actuator is working hope it helps
Posted on Sep 16, 2008
SOURCE: front loading washing machine will not tumble or spin
This sounds like a drive belt porblem. The belt that connects the drum motor to the drum has slipped/broken/worn out. A new drive belt will most likey fix this one...
Alternately, a loose or broken pulley. I don't suspect a bad motor, since you say you can hear it clicking and whiring...
Posted on Jun 10, 2009
beltronic205
  • 1460 Answers
SOURCE: the washing machine does not spin and displays an
Make sure water pumping out if not check /clean filter
Posted on Oct 03, 2009
  • 136 Answers
SOURCE: my washing machine showing an OE error before end of cycle
OE error is noyhing but an Outlet Error.. OE simply means “the pump is blocked”. Clean and straighten the drain hose / clean the drain filter. Check the hoses (drain hose) and the pump filter but if it didn't cure the problem then turn the thing upside down and strip the pump out of it check if anything is caught in the impellor.. if so remove it and everything will be fine..
Posted on Jan 18, 2010
Hitachi sf-95kj washing machine stop and shown error code c4 when it's go to spin mode
A lot of new machines need the hoses cleaned out. The slime up. The pump gets shut down and the unit won't spin. Unplug unit before you service it to avoid shock. Top has to come off, and front also.
Nov 16, 2013 | Washing Machines
Model:SF-95CJ F9 FAULT CODE
my hitachi model SF-95 CJ is washing machine show F6 ,C4, F4 FAULT CODEcleck
Feb 11, 2012 | Washing Machines
Hitachi washing machine error code Fb indicates problems. what prolems is that? Can you list out the meaning ot each error code.
My washing machineSF-110SS
have a display FD. Anybody know what's that means? And how to solve it. Please
Jun 23, 2011 | Washing Machines
Hitachi washing machine SF-80FJ error C1 on LED
my hitachi model SF-80 FJ is washing machine cleck c2 warning stop Kwongboonsin@yahoo.com Bangkok 10330
Feb 05, 2011 | Washing Machines
Hitachi washing machine. Model:SF-P90DJ Fault code F9
my hitachi model SF-120 HJ is washing machine cleck c2 n c4 warning stop f9..........
Jul 29, 2010 | Washing Machines
WM2487HRM goes thru the wash cycle then gives OE error message. after drain tub with drain tube and reinsert drain filter, will happen again. if drain tub and unplug for 30 minutes, it will do spin only...
Drain hose is kinked or clogged the pump filter needs cleaning .
always turn machine off when working on it . and donot forget there is always water in filter .so put blanked or towels down.
Feb 12, 2010 | LG WM2487HA Washer
AEG 88730 UPDATE
For a solution to your dilemma, I recommend that you first replace the brushes, then to reset the error code C9 hold down the pre-wash & short wash together and turn the control knob from off to gentle spin. this sequence should clear the C9 from your washer.
Aug 18, 2008 | Washing Machines
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
