Question about Desa International CGCFTP Compact Heater
Pilot ignitor We can get the pilot on and fire but the fire turns off within a minute...do you supply parts?
  • bbard Dec 18, 2008
    DESA cgcftp heater pilot will light and the burner will come on, but after a short while the pilot goes out and the burner goes off as well. Is this the thermal couple or some other problem?
  • Anonymous Dec 20, 2008
    same thing
  • 188 Answers
It could be the ignitor or thermocouple. I suugest you contact Master Parts and they should be able to help you. You can find them online at www.masterparts.net or you can call them toll free at 800-446-1446. I hope this helps. Thank you
Posted on Jul 08, 2009
I have a mini max 150 pool and spa heater i have replace the pilot assembly and the theremal couple and the ignitor i have a great flame on the pilot but when i turn the valve to on the burners wont lite...
if pilot stays on and heater wont fire......problem with one of your safety switches, or problem with thermostat controls, or a bad connection someone within the entire circuit
Sep 30, 2013 | Pool & Spa
I have a Heil DC90 Gas furnace with an intermittant pilot ignitor. My fan comes on, but blows cool air (not heat) and does not show a pilot flame. How can I check to see if the ignitor is broken, or if it...
Working on a gas appliance is not recommended unless you are an experienced technician. There is a multitude of things which can go wrong and seriously endanger residents if a repair is not done correctly. That said, the draft inducer motor should start the cycle off. If the pressure sensor shows it working properly, then voltage is sent to the ignitor and gas valve (for pilot lighting). The flame sensor then tests for a pilot, if present allows voltage to the main gas supply, if not puts the system into a timeout and allows it to retry after a set time (2-10 minutes usually). If all of these parts are working properly you may still have an issue with the door switch, the gas controller, the gas supply, etc. which can simulate your issue. Try following that path of logic after eliminating the door switch and fuel supply as the culprit. If you locate the problem you still may have trouble obtaining the proper replacement part as most supply houses do not sell to the general public.
Sep 22, 2011 | Heating & Cooling
Pilot lights but burner won't light. Display continues to read SPK
On these units, the pilot ignitor and the pilot rectefier are the same part. The pilot can be lit, but not be sensed by the rectefier/ignitor. This will keep your burner tray from igniting. You need to replace the ignitor assembley. If it is the same as the raypak digital 406a I charge about $75 for that part, and it takes about 20 minutes to install. Need the part or more help e-mail me. adamh@newconceptchem.com
Oct 22, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
I can see my ignitor light up but it does not fire. About every third load it will fire and it dries a load just fine. But then it doesnt fire the next time.
@Mike,
I've been where you are and it can be frustrating! What you described, for lack of a better phrase, is an 'ignitor dying a slow death.' Within each heating unit (aka. ignitor) there is a tiny thermostat that tells the device WHEN to fire and how often. Your trouble can be fixed by replacing the part. If you supply your machine make and model number we can help point you to a replacement part which you can get online.
Thanks, Chris I.
Sep 08, 2010 | Dryers
The top of my oven works fine, and the pilot for the oven turns on but the oven doesn't start...
Your oven glowbar ignitor part # 5303935066 is faulty and must be replaced. Remove the oven racks and the base pan in the oven to access the ignitor. Turn off the gas supply and unplug the range. Remove the ignitor and replace with a new part.
Nov 03, 2009 | Tappan TGF336F Range
Flame shuts down after 5-8 minutes
AFTER THE BURNER SHUTS DOWN THE 1ST TIME IT SHOULD COME BACK ON WITHIN 1 TO 3 MINUTES. WHEN THE BURNER TRIES TO COME BACK ON YOU'LL HEAR A CLICK AND THE GLOW OF THE IGNITOR SHOULD BE VISIBLE. AFTER 30 TO 60 SECONDS IGNITOR SHOULD FADE AND THE BURNER SHOULD FIRE. IF IGNITOR FADES AND BURNER DOES NOT FIRE YOU WILL NEED TO REPLACE BURNER COILS #279834. IF IGNITOR DOES NOT COME ON YOU WILL HAVE A T STAT OR SENSOR ISSUE. SOUNDS LIKE COILS TO ME. HOPE THIS HELPS PLEASE FEEL FREE TO CONTAT ME HUBAPPLIANCE@COMCAST.NET. PLEASE RATE MY RESPONSE.
Jun 23, 2009 | Dryers
Lighting pilot of GE gas stove
According to the model number you supplied it looks like your oven use a glow bar ignitor not a pilot light. In that case there is no place to hold a fire. what happens with these when you turn the oven on 120 volts goes to the ignitor causing it to heat up ,the amp draw across the ignitor causes the gas safety valve to open, and then lights the gas. So if you turn your oven on you should see a bright red glow if not probably the the ignitor, to check it you would have to verify you actually have power going to it. If the ignitor glows but the gas valve does not open you will still need to replace the ignitor has to pull about 3.2 amps across ignitor to open safety valve. Your broil burner works the same way. And most of the ovens the floor of the oven comes out to allow easier acess to the ignitor. also if you have to change the ignitor put just a dab of dish detergent on the screws to help from stripping them
Nov 27, 2007 | GE JGRP17 Gas Single Oven
Heating & Cooling Logo
73 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
