Question about Cameras
Sony Cyber shot dsc-t99 E:61:00 error
I can't shoot anything and my display screen flashes the E:61:00 message.
pishta68
  • 579 Answers
SOURCE: Camera is out of focus
Make sure its on auto focus instead of manual. Also make sure the lens is fully extended
Posted on May 12, 2008
swami nathan
  • 208 Answers
SOURCE: Sony Cyber-shot Error Code E:61:00
you may have these symptoms,
Symptoms :
  1. After pressing the power button in capture mode, the lens would extend and a slight humming from what appeared to be the auto focus motor could be heard for about 5 seconds. When the motor stopped humming, the camera would beep and display E:61:00 in the LCD Screen.
  2. Camera would extend the lens but not be able to focus on anything past 8 inches or so.
  3. Zoom in and zoom out would not work.
  4. Playback mode and the Setup mode was not affected.
To fix this problem,
Do these...
A) Put the camera about a half inch from a hard surface.
B) Let the lense go out and hit the surface and retract a little bit. Let it go out all the way when it tries the next time.
If that doesnt fix it, try this:
A) Turn it on and let the lense go out fully
B) See where the lens comes out of the camera? The little round crack that surrounds it? Wiggle the lense a bit and blow in there a bit. (Be sure not to blow on the lense!)
Now turn it off/on again, and it should be fixed!
If not, try these steps a few more times. If still nothing, then I suggest you to call Sony, but this DID work for 90%, so hopefully it''ll work for you :)
Thanx for using fixya,
Cheers.
Posted on Sep 27, 2008
wicabuss
  • 48 Answers
SOURCE: n auto mode of shooting flash setting cant be changed in sony cyber shot model no dsc w-170
as long as you have a menu button on your camera you should be able to control these functions.turn the camera on in auto or manual. hit menu soon as the camera comes on,now you should be allowed to make any chages you choose.hope this helped.good luck
Posted on Apr 14, 2009
  • 10 Answers
SOURCE: Change language display on Sony Cyber-shot DSC-W220
try under the settings menu
Posted on Jul 19, 2009
welcomejee
  • 10594 Answers
SOURCE: My camera Sony Cyber-Shot DSC
E:61:10 is an error code that shows zoom motor in lens assembly is stuck/ not working for some reason in DSC-T99
Please take apart camera (if you are comfortable with that) and make sure two flexible ribbon wires of lens assembly are connected properly with main board in camera. If both connectors are fine then main board got problem and need qualified tech to replace it, local camera repair shop will do this job for you.
Hope this will help.
Thanks.
Posted on Apr 05, 2011
My Sony Cyber-shot DSC-H9 has a problem when i'am using it outdoor, sunlight .Can shoot a picture, but screen dosen't display the area being photographed.
you must read the owner manual, section troubleshooting for indicate what is wrong. and fix it. Otherwise you must to the repair shop for fix it.
Normally the LCD is faulty, and need replace it.
God bless you
Sep 22, 2012 | Sony Cyber-shot DSC-H9 Digital Camera
When I turn on sony cyber-shot camera I get a screen display that states "access". The lens keeps going in and out and then it states,"turn the power off and on again" What's...
When I turn on sony cyber-shot camera I get a Problem with the Sony Cyber-shot DSC-W35 Digital Camera when I turn on sony cyber-shot camera I get a screen display that states "access". The lens keeps going in and out and then it states,"turn the power off and on again" What's wrong??
Oct 12, 2011 | Sony Cyber-shot DSC-W35 Digital Camera
My sony DSC-w120 digital camera flash is not working.Please tell me how to rectify the same
If there is error message on the display and blinking flash, try to initialize the camera. If the problem persists or there is no error message, there is probably no user solution, camera will have to be repaired by service personnel.
May 20, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
Getting error E9101 with my w55
The error shows that(Abnormality when flash is being
charged.) the problem in in FLASH UNIT, it needs replacement, the part number is given below according to the model number you mention DSC-W55 Part No. 1-479-663-31 Description (FLASH UNIT).
Thanks for using ifxya.
Jul 27, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Flash of sony cybershot dsc-w200 is not working
i think i had the same problem, if u press the home button and then press shooting then hit the flash button on the right hand side it should change the mode.
Jun 22, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
My sony cyber super steadyshot model DSC-T70 flash does not work. Nosmile icon appears on the touch panel when shutter buton is pressed.
go into setup menu and turn on the smile detection. go to photo and press the right arrow should have a pict of flash icon . press until the flash says auto.
Jun 03, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Warning massage
I am having the same problem as well. The error message E:91:01 comes up and the flash will not operate.
Aug 14, 2008 | Sony Cyber-shot DSC-W90 Digital Camera
Sony Cyber-shot DSC-W70...
It's a flash error, something has malfunctioned with your flash and the system board will continue to give this error until reset by service technician
Feb 27, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
E:62:10
Hello, this error message means that there is an melfunction in angular velocity sensor, peripheral cicuits. Simply speaking steady shot function does not work well. Please contact nearest Sony Dealer. Best regards, Arpi
Jun 11, 2007 | Sony Cyber-shot DSC-T10 Digital Camera
Cameras Logo
476 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
