We have an Ariston AQ9F29U front loader washing machine. we have performed various cycles but the machine does not seem to stop at the end of the cycle, it just keeps washing?? is there something I am doing wrong??
  • 106 Answers
SOURCE: Bosch WFL 1660 Front end
After disconnecting the mains open up behind, it could be a shock absorber (damper) which is broken.
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Try these sites for spares.
Posted on Feb 28, 2009
ronaldo_ross
  • 1056 Answers
SOURCE: Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Posted on Jul 01, 2009
barkencoa
  • 3463 Answers
SOURCE: Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Posted on Jul 24, 2009
SOURCE: Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Posted on Jan 23, 2010
SOURCE: simpson ezi loader washing machine clicks 3 times
It sounds like a door switch fault see if the end light and the start/pause light are flashing count the flashes if end flashes 4 times and the start/pause once or maybe more this could be error 41, door switch fault.A door switch would cost about $ 20 but there may still be a problem with the main Programmer.
Good luck.
Posted on May 03, 2010
I have an Aqualtis 9l29i washing machine. It is working fine but the wash cycles are all ridiculously long.Put it on the quick wash yesterday,three hours later still washing!! Suggestions please?
1. Front load machines always have much longer cycles.
2. The machine you have has a time saver mode on most cycles.
3. Check with your local Ariston reps on the time various wash cycles should take with your model if this is not specified in the user manual, which it normally would be.
4. These are notoriously bad over priced machines which will give you trouble early in ownership and are expensive to fix. For half the price you can buy a good top loader that will give you at least twice the trouble free years of use and not run ridiculous wash cycle times.
Jan 03, 2016 | Washing Machines
Washing machine won't take enough water and won't take washing powder and leaves bad smell inside
AH yes front loaders are bad about this type problem .change the detergent to liquid and run a coulpe empty wash cycles with bleach and or baking soda
Mar 21, 2015 | Ariston Technologies Washing Machines
Why are my clothes dripping wet after the spin cycle I have a ariston front loader avxl129
sounds like the pump could be unable to get the water out after the wash. check the door into the pump, at the bottom front of your machine
Aug 12, 2014 | Ariston Technologies Washing Machines
I have a noisy ariston front loader washing machine and
From the front of the washer, spin the drum by hand, and if it feels rough, or is noisy, or rumbling, then the main drum bearings have failed..
If no noise, then problem is elsewhwere.
Hope this helps.
Jan 27, 2010 | Ariston Technologies AW149NA Washer
Ariston washer dial starts turning and won't stop -no wash/spin..
CHECK THE PIPE TO THE DRAIN HOSE AND FILTER TRAP IF ONE FITTED IF BLOCKED CAN CAUSE THE SAME THING ESPECALY IF YOU HAVE A NON RETURN VALVE FITTED
Jan 05, 2010 | Ariston Technologies Washing Machines
Ariston front loading washing washing
Believe it or not.....its almost always the cloths ( heavy blankets) that one places inside.
TRY:: In the spin cycle if the load is unbalanced the TUB will rock and make that "loose drum out of alignment" noise. STOP the machine and open the door ( IF IT IS A TOP LOADER ) realign the cloths (heavy or more then one blanket) so that it is EVENLY spaced through out the tub.Start the machine again.If it does it again, stop the machine and REALIGN the cloths (blanket !!) again.
p.s. there is a simpler way of doing it but I don't want you to loose your hand in the process.
Aug 31, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
Ariston Front Loading Washing Machine error code F07
Error code F07 is indicating that the heater relay is stuck for one reason or another.
This could be a board problem, as this where the relay is located.
However, it would be worth checking that the heater is o/k before you do anything else., as this possibly could cause the relay to malfunction.
Plz rate my solution.
Thanks.
Jan 11, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
Washing Machines Logo
Top Washing Machines Experts
