My roland sp 540i has a problem of colour registration? magenta and cyna olny
2 Suggested Answers
  • 11 Answers
SOURCE: Have a Roland SP 540 V Eco Sol MAx printer/cutter.
you should have to use the syringe method to **** the ink before anything, then make a powerful cleaning, test, you may have to do it several cleanings and should be solved.
Posted on Feb 20, 2010
I have a roland sp-540v, trying to print on banner material with black backing. Keeps on getting message to setup sheet while everything is loaded correct. The sensor is probably not picking up black.
Could you try
(1) Temporarily stick a white strip over the sensor where it detects the media or
(2) On the length of the media or
(3) Even staple same sized white media below the black one which you can un-staple after printing.
kindly ignore if these are (s) tupid answers
Mar 23, 2016 | Roland VersaCAMM VP-540i
I need a driver for Roland VersaCAMM SP-540V for windows 7
IF I CAN REMEMBWE YOU CAN DOWNLOAD IT FROM THE ROLAND SITE
Nov 17, 2013 | Roland VersaCAMM SP-540V
Buttons not working
open the back panel and clean the dust and close then turn on the sp 606
Mar 27, 2013 | Roland Sp-606 Sampling Workstation System
I need drivers windowS 7 for Roland VersaCAMM SP-540V
hello
i add a video explaining how to install sp540v in win7
u need to install the Intercon-NetTool (that u can download from the Roland website) to allow the comunication with the plotter. its all well explained in the video. good luck
Feb 27, 2013 | Roland VersaCAMM SP-540V
Colour misregistration mystery
Various possible causes - the most likely are :
1. Dirty registration sensors - remove IUs and transfer unit and inspect / clean sensors.
2. Damages / worn IU drive gears - inspect. Replacing the gears isn't a small job, if this is your problem.
3. Faulty colour registration shutter - you can check this is working in the service diagnostics menu.
4. EEPROM problem on the controller board - replace main controller board.
These are in order of likeliness. For further information, take a look here.
Nov 25, 2012 | Xerox Phaser 7300DN Laser Printer
Roland Versacamm sp540v is not printing yellow or magenta. What could be causing this? We were out of town and it wasn't used for a few weeks.
your print head dry out, cause is: no use! you should detach the tube between the pump and the caps, the one of magenta and yellow, insert a seringe in the tube (that comes from the cap) and suck some cc´s of ink, .then atatch the tube again and run one or two powerful cleanings, then run the test. A smart advise is: never turn off the machine in the main power, the machine when in stand by, does automatic a check and a cleaning process from time to time if needed.
Jun 24, 2012 | Roland VersaCAMM SP-540V
I have sp 606. i connect to sp606 via usb cable to pc in window xp.but icannot connect in window 7,how i can conecct in window 7
Hi.
As the sp 606 is an older machine, it was designed for xp compatibility.
You can try to run it in compatibility mode, but there are no guarantees that this will work.
There may be a windows 7 driver on the internet for this device, but I have searched and have been unable to find one as of yet.
I did however find a vista driver on the Roland website, it might work for you, as alot of devices that get connected to win7 machines use vista drivers to make them work.
here is a link to the download page for it, maybe it will work for you.
http://www.roland.com/products/en/_support/dld.cfm?PRODUCT=SP-606&iRcId=1812391&dsp=1
I hope that this helps you out, and have a good day.
May 25, 2011 | Roland Sp-606 Sampling Workstation System
Have a Roland SP 540 V Eco Sol MAx printer/cutter. Magenta/Yellow print head clogged (hadn't been used in a few weeks) can't seem to get the ink to flow in those heads! Any idea other than head...
Jan 08, 2010 | Office Equipment & Supplies
Cakewalk P-606
email me if you haven't found it yet.  billymozart@yahoo.com
Feb 21, 2008 | Roland Sp-606 Sampling Workstation System
jasbo
jasbo
