Question about Bosch Dishwashers
SD6P6B bosch dishwasher showing E:14
My dishwasher is showing E:14 in the screen. I have lost my manual. What does this mean?
4 Suggested Answers
  • 228 Answers
SOURCE: I have a bosch dishwasher, SHU535E05UC/14. The
the spray arms are not rotating check they spin freely if they do remove them and clean any residue food deposits blocking holes for water spray.
Posted on Jan 19, 2010
Testimonial: "You gave me some information how to get my dishes clean, it was very helpful. I cleaned all the arms out, there were food particles stuck inside.Thks"
  • 11 Answers
SOURCE: Bosch Dishwasher SHX46B06UC/14 How can I
http://allrepairmanuals.com/bosch-dishwasher.htm?model_number=SHX46B06UC%2F14 It costs 9.95 but its a PDF and you can view it right away.
Posted on Aug 18, 2010
Macmarkus
  • 2605 Answers
SOURCE: My Bosch integra dishwasher is showing "*1" where
Welcome to FixYa.
Based on your description
I'd say the issue actually is with the control...unfortunately. This is commonly associated with a heating fault on Bosch built dishwashers ( various models including Bosch, Thermador, Siemens, Gaggenau, and Neff ).
Since the issue is likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
These are the steps you'll need to follow to resolve it or at least investigate.
If you feel capable of checking this on your own, there`s a way to visually inspect the control yourself...it really isn't very complicated.
It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
The culprit will 99% of the times be one of the pins from the heater relay,
**Flip this over and inspect the solder joints, it will be obvious when you see it.**
This ones new, but it's where to look...
...hence the unit sit`s and takes longer & longer to finish because it can`t heat to advance or unless the 2 buttons for "cancel" are pressed...this can also manifest as a long cycle time as I mentioned and eventually display's "1" on units with a display and usually very poor cleaning, no heating ( don't be fooled by the homes inlet hot water temperature ) as a result.
You can also run the unit through a regular or econo cycle ...any cycle with the exception of rinse & hold, and with the door panel removed place an ammeter on the gray/black wire it should draw 11 amps during the wash cycle...after it fills and the flow switch indicates it has adequate water to engage the heater.
i.e. ( this may differ from your specific model, but the same rules apply )
**My Opinion - if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...but it has to be done well...or it will not last.
Bosch recommend`s replacing the control and I don`t pretend to speak on their behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power or turn off the breaker before attempting any service to the dishwasher.**
If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau/Siemens, to service your machine.
Thank`s for visiting "FixYa" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness.
Good luck.
Regards,
Macmarkus :)
Posted on Feb 24, 2011
Bosch silence plus showing fault E24. Have lost our manual . How do we fix this ?
Check the manual online:
https://www.manualslib.com/products/Bosch-Silenceplus-She45r55uc-3787557.html
Jul 01, 2017 | Bosch Dishwashers
What does E14 mean ?
The code can mean different things .check the manual that came with it . the manual will also show how to do a self test .
Oct 20, 2014 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Where to buy timer motor for my bosch dishwasher SMU2042UC/14
I have had success finding appliance parts on Amazon of eBay, especially if you have a part number or Model number.
Nov 03, 2013 | Bosch Dishwashers
Does someone know where i can get the manual for an old bosch dishwasher? The model number is smu7056uc/14.
http://www.bosch-home.co.uk/quick-links/customer-service/download-product-manuals.html
Feb 27, 2013 | Bosch Dishwashers
My Bosh 24ES has error code 14 what does this mean and can I fix it
The year 2009 Bosch 24ES manual does not show error code 14.
Your manual may be different.
Call Bosch 1-800-642-3111
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Bosch-GWH2400ES.pdf
Don't forget to read the product manual for required yearly maintenance, and performing this maintenance will eliminate many common error codes.
Aug 09, 2012 | Water Heaters
Need owners and/or service manual for Bosch dishwasher SMU2042UC/14
The specific model manual seems unavailable online but,click on the link below to get to the product support site and see the available manuals.
www.bosch-home.co.uk/customer-service/download-product-manuals.html
Hope this helps.Thanks!
Jan 07, 2012 | Dishwashers
Bosch Dishwasher SHX46B06UC/14 How can I get the instruction manual for this dishwwasher?
Aug 18, 2010 | Dishwashers
Bosch dishwasher lfestyle automatic runs for 1 min then displays e24?
e24 means the water supply isn't getting in
www.homeclick.com/PE-Links/Bosch/Bosch-SHE68E15UC-manual.pdf
This manual has troubleshooting that you can use for yours too.
Mar 31, 2010 | Bosch 24 in. SHU6802UC / SHU6806UC...
Dishwashers Logo
179 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
