Question about Xerox Phaser 8500/DN Printer
Xerox 850 fault code 15.004.45
Thanks for your post about this problem, please send me the instructions
Randy Lewter LNSTUDIO@mac.com
L&N Studio 602 E Pryor St Athens, AL 35611
    President:
  • 2,072 Answers
First of all you will need Torx bits or drivers to remove the covers etc. I think mostly you will need a number 10 and 15 size.
First off you want to remove both side covers, there is one screw on the top back of the covers, and another on both covers, top front, you have to open the front paper path door to access the front screws. Then about the middle of the covers pull up and outward, they will kind of pop off, but thats fine, they have tabs on the bottom that can be pesky.
Remove the paper tray, the green maintenance tray and set aside.
Now remove the 2 green rails that the maintenance kit rides on. They both are held in by one screw. It will take some manupilating to get them out, but basically you push them sliightly back, inward and twist slightly until they come out. TAKE NOTE of how the leaf springs are on the rails, A hint when putting them back in, is to take some scotch tape and tape them on the side to keep them in place, You will see what I mean when you remove them. But its much easier to get the rails back in when those springs are taped to the side. And no worry about removing the tape afterward, I will have no affect on the machine if its left in.
Next, you look up and you will see a stainless steel curved plate. About 10 inches long and 3 inches high. There are 2 screws on the top of it that must be removed. There are 2 tabs on bottom, Once the screws are removed it just lifts out.
Now about midway up the paper path is the registration rollers. First, you have to go, ( looking from the front of the machine) to the left side of the machine, You will see a electromech clutch on a shaft with a 2 inch black gear with a belt attached. Remove the clip that holds the clutch on, slide off the gear and just let the belt drop in place.
Now, return to the front,The assembly is stainless steel, you will see a couple of rollers on it and some paper path actuators. There is one screw on the right side of that assembly that you need to remove, and on the left side, just by the bearing there is an "E" clip holding the bearing against the frame. remove the screw and the clip, Then move that transport CAREFULLY to the left and out. Be very careful to keep the 2 pieces together, there is a switch actuator that can be easily broken. So please take caution. On the right side, there will be a bearing that WILL fall out, and drop down into the paper feed area. Trust me it will do that. Just locate it and pick it up. When replacing that transport. I suggest, ( unless your considering suicide LOL) Put some white out or a little glue on the outside of that bearing when you press it back into the frame. Otherwise, IT WILL keep falling out and really try your patience. Just trust me on that one.
Now, look in the front , just above where the maintenance tray would go. You will see 2 screws, about 10 inches apart, They will be surounded by a beige/brownish plastic. Remove those 2 screws, they hold in the heater assembly you want to repair. When you remove those screws it will not yet come out, wiggle it a bit and look on the right side so you can easily determine the conectors, plugs you need to remove. Some have 1 some have 2.
Once you do that, slide that heater assembly downward and out. You will see the 2 lamps in there.
Take those little spring metal clips out,, replace BOTH lamps. Use some emery cloth to clean the contacts. Clean the reflector behind those lamps before replacing . That will make the heat transfer more efficient.
Once those are in , in reverse order reassamble. Just be cautious replacing that registration assembly so you dont break the black actuator.
It's really not hard, just takes some time. Give yourself an hour to an hour and a half. But that is your problem I guarantee it.
Posted on Nov 03, 2008
Issues with Charcoal canister, trac off and check engine light
Please contact randy on the original link for the first time you posted this, do not post a new question.
Aug 29, 2016 | 2013 Scion xB
Xerox 7345 error code009-936 has been received. Please send the solving process.
Return to Search Results
Solutions for : Fault Code 009-936: More Than One Consumable is End of Life Fault Related Fault Code: 009-936 Solutions ranked by relevance:
  1. Make Sure All Highlighted Supplies Are Replaced
Have you found what you are looking for? Yes
Not Yet
Please Help
Dec 17, 2015 | Xerox Workcentre 7345 Printer, Copier,...
Xerox error code
There is a bulletin from Xerox that helps to troubleshoot and identify the error. If you provide me your e-mail address I will send it to you. Please e-mail me at sales@iteminc.com.
Sep 16, 2014 | Xerox Phaser 8560DN Laser Printer
Pch.com/w71 Where is it?
authorization code:r6301
Nov 26, 2011 | pch.com
Svc Rprt Flt Xerox Phaser 850. 15.004.45:96992, 22.613.05:96992
Yes you can. What you are experiencing is the drum heaters are not working. The way to verify that is, if you can turn the lights off in the office your in, and then turn the machine back on. On the right side of the machine you will see a fan vent area, slots cut out in the cover where the fan is mounted. Watch through those openings for a glow inside the machine, I very much doubt you will see any glow. There are two 150 watt halogen lamps in there that are used for the drum heaters, one or both of those lamps have gone bad and need replaced. The code you are getting comes from the fact those lamps are not working and the drum does not reach operating temperature.
If you want to replace them or have someone that can, let me know I will send you the instructions. You can purchase those bulbs at any lowes or home depot, anyone who sells halogen light bulbs will have them. Cost should be around $15.
Jan 21, 2009 | Xerox Phaser 8500/DN Printer
U2 Error Fisher Paykel dd-602 dishwasher
Hi there, Error U2 -
Possible Causes - Loading
Check loading to ensure no items extend
beyond the height of the drawer.
Good Luck!
neo
Sep 01, 2008 | Fisher and Paykel 24 in. DD-602 Built-in...
P1762 fault on 98 jeep gc
I saw this post while tying to fix my jeep.  I did not know what it was, but found this site that does.  Hope it helps.
http://jeepsunlimited.com/forums/showthread.php?postid=5153594
Randy
Aug 25, 2008 | 1998 Jeep Grand Cherokee
How to delete User fault codes
yes what is your email so i can send you the tep by step
Aug 02, 2008 | Fisher and Paykel 24 in. DD-602 Built-in...
Ps3 insertion wheels ride on have jumped off track
You can send it to 5000 Mobile Hwy Ste. 1 Pensacola, FL 32506. You can check with BBB.com to see we're a reputable business. Just box it up and send it via USPS. Make sure you record your serial number and pack it tight with peanuts. Also write fragile on the box as well. If you have any questions you can call my personal number at 850-602-6336. Thanks, Matt
Aug 02, 2008 | Sony Playstation 3 (PS3) Console
Xerox tektronics phaser 850- media jam
The preheat entry sensor assembly probably has broken sensor arms, and will need replaced.
Jun 13, 2008 | Xerox Phaser 850 Printer
Xerox Phaser  8500/DN Printer Logo
207 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
