Question about Maytag PYG3200 Dryer
Dryer wont start
Is there a way to tell if a fuse is bad without a circuit tester?
  • 67 Answers
Yes, switch it with a good one
Posted on Oct 28, 2008
I change the ac compressor and now the crv wont start
there is a 30 or 50 amp fuse for the start circuit. I've seen this before, but, only once. inexpensive to fix. other reasons? hard to tell. need answers to:
-does the engine turn over? if so then not fuse.
-is there spark if it does turn over? put a spark tester on one of your plugs to verify.
-is the engine froze? maybe ac tensioner too tight or compressor (new one) could be bad. check to see if you can manually turn the engine over with a 1/2" socket.
these are only preliminary things to start with.
get back with me after you do these things or can give more specific information about "wont start" means.
Jun 05, 2016 | AC Cars & Trucks
Is there a fuse for the horn on a 2000 Chevy Malibu?
fuse for horn on a 2001 malibu is located under the hood.
there is a fuse (15 amp) in slot #43
and there is a relay in slot #21
if you remove the relay and put it back in wrong the horn will not work.
Sep 26, 2014 | 2000 Chevrolet Malibu
Dryer wont come on
Did the circuit breaker trip? If not You may have a bad internal fuse, motor, door switch, timer or start switch.
May 15, 2012 | Estate TGDS840JQ Gas Dryer
Dryer wont start but the timer cliicks frigdiare dryer
It sounds like the thermal fuse. Without knowing model number I cant tell you exactly. Depending on how you access it. Near the blower housing you will see a little white sliver fuse ot a round fuse with two wires running to it. The one next to it has 4 wires running to it. Disconnect power before opening the dryer... Take a meter and see if it has continuity. If not its bad. Anything further please feel free to reply.
Jul 10, 2010 | Frigidaire GLER642A Electric Dryer
Dryer won't start
It is hard to tell exactly what is wrong without seeing it in person, but I can tell you what to look for. First check the power coming to the dryer.... is a breaker tripped? If you have fuses, make sure both fuses for the dryer are good. Even if only one is bad the dryer wont work. If you have a volt/ohm meter, you can check for power, first at the dryer receptacle, then where the cord connects to the dryer. It is important to wear safety glasses when doing this. Then you might check the door switch on the dryer. It is one of the first parts to go bad on some models. If you are not familiar with electricity, it would be good to have an experienced person check out your dryer.
Jun 10, 2010 | Roper REX4634KQ Electric Dryer
My general electric dryer DDE5300 is no longer warm so clothes don't dry, though it runs. How can I tell if its the heating element or the thermostat?
You Will have to use an ohm meter and the tub has to be taken out. You can on a GE open the door and push in on the door switch and starte it with the door open and look straight in and see the heater come on but if either the heat element of thermostat is out the element wont come on. If you live in ahouse with fuses instead of circuit breakes or a fuse box between the dryer and main circut box check the fuses an electric dryer will run on one fuse but not heat if this is the case switch the fuses and see if it runs if not one fuse is bad.
Apr 21, 2010 | Hotpoint NVL333EY Electric Dryer
Dryer wont heat up model # RGL5646AWO
You may have a bad thermal fuse (located on the blower housing) or a bad cycling or high limit thermostat. The high limit thermostat and thermal fuse are easily checked with a ohmmeter or continuity tester (with machine unplugged, of course). They should have continuity -- replace them if open. If they are bad, carefully check your vent. These are often damaged by excessive heat due to a restricted dryer vent.
Dec 31, 2009 | Dryers
Dryer will not start. Used it yesterday, no
Hi welcome to Fixya
You must pop off the top of the dryer then remove the front after the front is off you can remove drum .
The belt goes around the drum and the motor pully and under the tentioner wheel after you get belt on replace front and top.
PLEASE MAKE SURE TO UNPLUG FROM POWER THIS IS 220volts AND CAN HURT YOU BAD
Thank You For Useing Fixya
PLEASE RATE ME
Jul 13, 2009 | Kenmore 62622 Electric Dryer
Is70c keeps shorting out when i switch it on - changed fuse - still have shorting out
If this is still shorting out when you turn on with new fuse, then either there is a shorted wire in the system or there is a bad capacitor. Capacitors handle a specified current flow to the rest of the circuits.
you can use a multi-tester to find shorted currents and open circuits
Jul 11, 2009 | Zanussi TC180W Electric Portable Dryer
Dryer wont work
I'm assuming that the dryer is gas, since both the washer and dryer are on the "same" breaker. I'd try replacing the wall plug before replacing the dryer. If you have a voltage tester, you should see if you are getting an honest 110 volts coming off the circuit. Since the circuit was a problem before, I would test it first and then more on.
Jun 08, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
62 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
