Picture of ctl casa relay remote control for casablanca ceiling fan
  • 25 Answers
SOURCE: casa blanca fan motor speed control
www.casablancafanco.com
Posted on Jan 19, 2009
  • 37 Answers
SOURCE: How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Posted on Jan 27, 2009
MN_Jack76
  • 45 Answers
SOURCE: our casablanca ceiling fan has
If you have the intelitouch system, It's probably the circuit board in the fan. Casablanca has great motors but touchy boards. I ordered mine from www.fanmanlighting.com and installed it myself, it wasn't too difficult. Hope this helps
Posted on Feb 06, 2009
  • 14 Answers
SOURCE: Two ceiling fans, both remotes control the same fan
One of the dip switches is located under the globe, near the ceiling.
The other dip switch is located in the remote control. You have to take the battery out and look in the space where the battery is, usually towards the top of the remote.
On mine, there are four settings, the dip switches have to be in the same position, on both your remote and the fan unit, for them to work. You might have to reset them if you do not want both fans to work from one remote. Maybe one fan and remote have the first switch up and the other three down, that would let them both connect. The other may have the first one down and the others up, then it would only work from the remote that is set the same way.
Usually you can reset them by using the point of a pencil to move each dip switch setting.
Posted on Mar 26, 2009
  • 497 Answers
SOURCE: Need Installation Manual
I suggest you try going to www.manuals.com they have pretty much any kind of manual you can think of.
Posted on Sep 06, 2009
Where can I find a replacement for the Glass?
Casablanca sells parts. Go on-line to locate the part number you need from a schematic and either order directly from them or through a certified dealer. No worries!
Apr 10, 2015 | Casablanca Fan Hampshire C7M62M Ceiling...
How can I change from a remote control system ( which rarely works) to a wall control switch for my isotope 44 from casablanca
Casablanca may be able to supply instructions for alternate methods of wiring your fan for direct control vs. remote control.
Jul 28, 2014 | Casablanca Fans 44" Casablanca Isotope...
Where to get parts for casa blanca ceiling fan?
are you referring to the light globe? You can go to any home decor or home depot/lowes and find replacement covers, and the make sure the screws the hold it in are not stripped and need to be replaced as well
Jul 20, 2014 | Casablanca Fan Mykonos MyKM45 Ceiling Fan
I have an existing Casablanca Lanai Fan Model 79669D installed in ceiling. Is it possible to install remote control after the fact?
yes they have a kit at all hardware stores, you will need to take down the fan to put it up it is easy just use two people works out alot better, good luck ps dont forget to turn the power off before starting
Aug 07, 2011 | Casablanca Fan CAS 79669D Lanai Ceiling...
Just bought the house- it has a casablanca del mar but no remote- the wall switch does not work- can i override the remote?
usually remote control for ceiling fans does not have an override code like the ones available for control using a universal remote. because they are specifically designed to work with certain IR or Radio frequency signals.
Usually a replacement remote is available but you may have to contact the manufacturer to check for availability.
Here's Casablanca Support phone number:
Call Toll Free: 1-888-227-2178
Hope this helps!
Aug 03, 2011 | Casablanca Fan 3845Z Ceiling Fan
I have a Casablanca "trident"
Hello Duke,
I'm guessing you have a "prime touch" remote control system. I'm not exactly sure whats going on but the W-505 Prime Touch receiver in the fan is the brains of the system. They sell replacement W-505 parts at Fan Man Lighting.
Hope this helps.
Feb 08, 2011 | Casablanca Fan Trident COSMOPOLITAN...
Fan won't go on
Possibly a bad receiver, contact Fan Man Lighting at 1-866-600-3267 and ask for Jason, he has 21 years experience with Casablanca
Aug 07, 2008 | Casablanca Fan Televison & Video
Item #44953 56 inch Casa Vieja Casa Aristocrat Ceiling Fan. Can this be flush mounted or do we have to have a pole mount?
im not familiar with this model but you will need a pole to give the blades clearance from the celing and electricl conections uyou sometimes get two poles but as long as you have plenty clearnce one should be ok
Jul 25, 2008 | Casablanca Fan 3245T Ceiling
Remote Control
I had the same issue. I had to replace the remote control reciever located on the fan and that did the trick.
May 05, 2008 | Casa Vieja Probe White Ceiling Fan
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
