Question about LG Washing Machines
My defy toploader comes up with error e9 - LG Washing Machines
SOURCE: I have a Defy Laundromaid
I have a Defy Laundromaid 1300. I was getting an E9 message.How can I solve this?
Posted on Sep 21, 2010
SOURCE: I have Defy Laundromaid
Hi, I get an OD (wording) on my machine after washing-dosnt rinse or spin... what can that be???
DEFY LANNDROMAID 1300M!!!
Posted on May 08, 2011
ZJLimited
  • 17970 Answers
SOURCE: I have a defy top
Error E9 means a problem with your water pressure sensor. Check the sensor by pulling the hose attached to the bottom part of the tub and blow on it and test the terminals of the sensor if it will close or open.
Hope helps.
Posted on May 10, 2011
ZJLimited
  • 17970 Answers
Hope helps.
Posted on May 28, 2011
Chesc
  • 59 Answers
SOURCE: Defy - 13KG Laundromaid 1300
Here's a solution I've gotten from one of the experts..
"Clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!"
Hope this helps.. Good luck! :)
Posted on Jun 09, 2011
E2 is flashing on the screen of my defy Fuzzy washing machine in the rinse program
I'm seeing that water is pumping very slow,like you have a twist or clog in the drain line or the drain line isn't positioned correctly.
I'm using this manual,as there wasn't a model number indicated:
https://www.defy.co.za/wp-content/uploads/2016/06/WTL8019-8KG-Toploader-Manual.pdf
Jan 10, 2018 | Washing Machines
My defy laundromaid electrologic 1300 suddenly stops spinning and gives a ue error
I had the same problem: E9 error when switching the machine on. This indicates something is wrong with the pressure switch. (or connection to the pressure switch). When you open the top cover at the back of the machine it will be in the right hand corner (when looking from the back of the machine). This is a round device with a clear tube coming in at its bottom and a three wire connecting plug at its side. When unplugging I found one of the pins corroded (green tarnish). After cleaning it off with some steel wool the problem became intermittent - indicating the connection is not too sound. Just bending the pin slightly did the trick causing it to soundly make contact inside the plug. Problem solved!!
Aug 03, 2012 | Washing Machines
I have a Defy Laundromaid Electro Logic 1100 washing machine and it is now giving me an E9 error. What could be the problem?
Hope helps.
May 28, 2011 | Washing Machines
I have a defy top loader washing machine model DTL115. When powered it is writing E9 as a fault.
Hope helps.
May 10, 2011 | Washing Machines
I have Defy Laundromaid 1300. I was getting an E9 message.
Sep 21, 2010 | Washing Machines
Error E9 on 845 gvsr
i have a 845gvsr mother board power not coming led is binking but not powered coming. what is the soution......
Jun 26, 2008 | Intel D845GVSR Motherboard
Washing Machines Logo
393 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
