Question about Uniflame 200209 Open Flame Patio Heater
Propane patio heater wont stay lit
I can fire up the patio heater as desribed by the instructions. I lite the pilot light then turn on the gas and the flame ignites as it should. But after a few minutes I hear a click at the control knob and the flames goes out. I can start it again but the flame stays on for a shorter period of time. After that I can not light it and I have to wait several minutes (30-60 min) to get it to light again. Is this a gas issue or a hardware issue?
  • Anonymous Jan 13, 2009
    I HAVE THE SAME EXACT PROBLEM AS THIS GUY DOES AND I HAVE TRIED EVERYTHING I KNOW TO DO AN CAN NOT KEEP THE THING LIT. PLEASE HELP. SIGNED, VERY FRUSTRATED.
Buffalo12980
  • 625 Answers
SOURCE: Pilot light lit but no heat
the pilot's millivolt generator may be at fault.  if you have a meter that is capable of measuring a very small DC voltage, connect it up to the very end of the thermocouple and the copper cappillary. the thermocouple has a welded bead at the very end inside that generates a small DC voltage. Same principle of a J-K thermocouple. Iron constintan  - two dissimiller metals where joined together produce a voltage when heated.  the thermocouple actuates a millivolt electromagnet inside the valve to keep the valve pellet open.  no voltage there it won't actuate the electromagnet.
Posted on Oct 15, 2007
Buffalo12980
  • 625 Answers
SOURCE: problem getting patio heater to light
the little tube that is in the path of the flame is a capillary tube that houses a thing called a j-k thermocouple. it is nothing more then a millivolt generator that produces a very small dc voltage that actuates a very small electromagnet in the main valve. when you start the unit you need to push in a button, correct? when you release the button the valve should stay open, but you say it doesn't. the millivolt generator needs to be replaced. try doing a search for "dynaglow" heaters or www dot desatech dot com for a new generator.
Posted on Dec 06, 2007
  • 8 Answers
SOURCE: Patio Heater pilot lights won't stay lit
crappy pilot flame (not properly heating the thermocouple), bad thermocouple, thermocouple loose where it screws into the pilot safety valve, bad safety valve magnet.
One or more of those is the problem.
Oh...there is also a saftey switch...in case it tips over. It will also cause the pilot to not stay lit (if the switch or wires that go to i are faulty)
Posted on Jun 18, 2008
detox101
SOURCE: Gas fireplace pilot flame won't stay lit.
Hi , you can try and pull the panel on the bottom of fireplace out and check the adapter in fireplace. Sometimes they go bad. When you open in also check to see if there is an adapter plugged in and a option to use the battery operated function. If this goes bad the pilot will not stay lit.
Posted on Jan 14, 2009
jumptrout51
  • 3361 Answers
SOURCE: Pilot is lit for 30 secs but when I turn the knob for the big fla
You have a white scale buildup in the gas valve outlet blocking the main gas flow. Take the valve apart and clean it.
Posted on Jun 14, 2009
I have a nexgrill propane patio heater the pilot light works but when i turn it to lo or high after a minute or so the pilot light stays on but the burner wont light
Propane Patio Heater Troubleshooting - YouTube
? 6:54
www.youtube.com/watch?v=BqYIWuDUZOUDec 12, 2008 - Uploaded by PatioShoppers Great tips about troubleshooting your outdoor patio heater. ...Pilot Light Won't Stay Lit - How to Replace a Broken Thermo Couple on Furnace ...
May 12, 2014 | Williams 2509612 Ceramic Mid-Size Heater
Pilot light will light and stay lit, but will go out when you turn on the burner.
The most likley cause for patio heaters that light but go out when turned up is a worn thermocouple. These are consumable items that need changing when the patio heaters fails to light. Found this site very useful:
patio heater problem solving
Dec 31, 2012 | Stainless Garden Sun Steel Propane Patio...
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
My propane patio heater will not stay lit
Clean pilot first if this does not work it could be your thermocouple also check gas in tank
Apr 01, 2012 | Fire Sense 60368 Patio Heater
Fire sense patio heater won't light...
you prob need a new theromocuple on your pilot or just cleen it with sandpaper this may help
Apr 14, 2010 | Fire Sense 01775 Patio Heater
Laars Lite 2 LG - pilot light will not stay lit. As long as you hold down the pilot light once it is lit it stays lit but when I turn the nob to the "on" position (release the pilot light button) the flame...
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
Aug 08, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Kirkland outdoor heater will not stay lit
The thermocouple is bad. That is the part right next to the pilot light that sense's the flame and hold the gas valve open to the pilot. Take the old thermocouple off and go to hard ware store and get a 18" one of what ever length you need and replace. 5 dollar part.
May 31, 2009 | Stainless Patio Heaters - Steel Deluxe...
Patio heater
There must be a blockage in the hose and regulator or your large tank may be checking and not allowing the unit to stay lit. Remove the large bottle. Let the gas line equalize for about 30 seconds and then reattach the bottle. Very slowly, open the knob on the large tank and I mean very slowly. Did I say open it slowly. The new OPD propane tanks often have a very touchie excess control valve that won't allow enough gas through if opened too rapidly. Now tray and light the heater. If you still experience the same, get a technician involved so they can inspect the gas pressure.
Oct 23, 2007 | Heating & Cooling
Uniflame 200209 Open Flame Patio Heater Logo
298 people viewed this question
Top Uniflame Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
John Rodgers
John Rodgers
Are you an Uniflame Heating and Cooling Expert? Answer questions, earn points and help others
