Question about Uniden CXAI5698 5.8 GHz Corded / Cordless Phone
How to change date & time on a Uniden handset phone AS7401
5 Suggested Answers
SOURCE: Setting Time and Date on phones
Just got this phone. It is indeed day/month/year. European style. NOT what we want for a phone in the states. Really annoyed with the fact there is not an option. Might be returning it.
Posted on Dec 26, 2007
SOURCE: Need English documentation for Uniden Sireus 5080 phone & 0500 handsets
Here is the solution I found.
I also bought this equipment and also didn't find anything suitable in the internet, BUT a phonecall to the suplier EUROCOM brought the solution.
I called their service nr. 03-9029000 and got the English user manual as a PDF doc. by email.
Yssachar
Posted on Feb 15, 2009
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
KingDWS
  • 1606 Answers
SOURCE: I have a new Uniden cordless phone. The handsets
You can downlaod the manual from uniden in pdf form.
http://www.uniden.com/products/productdetail.cfm?product=DECT1580-4
the -4 or -5 refers to how many handsets you set. The 1580 is the actual model number.
To register I think all you do is place them on the master pad once then on their own charger stations. On some models they come all done so you just plug them in charge them up and use them.
Posted on Mar 23, 2010
How do I change (set) correct date and time?
You can download the user manual from here, and it will help you set the date and time: http://www.tutodoc.com/download/uniden-d1785-3t-owners-manual.pdf
May 10, 2015 | Uniden D1785-3T - 3 Handset DECT 6.0...
I need an English user manual for Uniden corded phone AS7401
Hi, i need user manual for Uniden AS7401, how to get it? can email to me at kenlkb@yahoo.com.sg ?
Nov 06, 2011 | Uniden Cordless Phone
How to turn volumn on ringer up also put in the dates & time
To change the ringer volume, while in standby mode (not on a call, not doing anything in a menu, etc) press Up(+) or Down(-) on the base or press up or down on the circular cursor pad on the handset.
The date and time should be set automatically the first time an identified call comes through. If you need to change it, press MENU/SELECT on the handset then select "Day & Time". Select the day of week, then use the number keypad to enter the hour and minutes in HHMM format (e.g., enter 0345 for 3:45). Then, select AM or PM.
If you need a manual, you can download one at
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1480-5Com.pdf.
Sep 19, 2011 | Uniden Cordless Phone
How to set time on phone
Which Uniden DECT 6.0 phone do you have? There are many.
Some Uniden phones will set the time automatically if you have Caller ID from your telephone provider.
To manually set the time on the Uniden D2280, press Menu on the handset when it is in standby. (It's the center of the wheel with the up/down arrows.) Go down to the Date and Time submenu and press Menu again. Enter the time and day using the keypad (press CID to advance past a character without changing it). Then select AM or PM. Press Menu to save. Press the phonebook key to go back to a previous menu or End to exit.
For the DECT1580, you set the date and time similarly. However, you start by pressing Menu on the base when the phone and handsets are not in use. (Have the handsets within range of the base.) Use the up/down arrows to select the day of the week. Then use the keypad to enter the current time.
The manuals for most Uniden DECT phones are here: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . They are listed in numerical and alphabetical order. Ignore the number after the dash in the model number, that merely indicates the number of handsets in the original package. One manual will cover units sold with different number of handsets.
I hope this helps.
Aug 25, 2011 | Uniden DECT 6.0 Cordless Phone ID
The Uniden XDECT7055 Owner's Manual is unclear regarding setting up the day/time. When I go to the MENU/SELECT function and scroll down, the date/time is not one of the functions offers to set. The only...
Phoned Uniden - durrgggh - had the same problem - simple solution - advised them to improve the manual - is totally not clear!!!!
As below:
  • Day and time must be set in 12hr times - not 24 hrs
  • Must be set from a handset - any handset that is registerd to the base is fine
  • Follow handset instructions but make sure hours are set as 01 - press menu / select to confirm
  • Then place the handset back on its base - all other handsets and the BASE will then change to that day / time
Hope this helps
Dec 06, 2009 | Uniden Cordless Phone
Uniden CXAI5698 5.8 GHz Corded / Cordless Phone Logo
896 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
