Question about Canon MP280 All-In-One InkJet Printer
Canon MP280 Paper Jam Error?
It says that my printer is jammed and it wont let me print anything, but I can see no jam. It starts printing the paper and pulls the paper down six cm or so, and then stops and proceeds to say that there is a jam. I can't find any paper stuck, but I might not be looking properly. This printer has only been used once before and there were no problems. I really need to print this off.
  • 13433 Answers
SOURCE: my canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 12, 2009
thumu
  • 69 Answers
SOURCE: False Paper Jam
My name is Vikram Kumar Thumu, from India-Hyderabad. I have seen your message on the issue related to Paper Jam error messages even though there is no paper jam in printer . I would like to provide my suggestions on the issue. I hope that this should work for you and will resolve the issue.
This issue could happen if there is an issue with any small paper jam in the Printer, or due to the communicational issue .
To isolate the issue, I recommend you to perform below steps.
Steps are:
1. Power OFF printer and then please Disconnect the Printer from Computer and then disconnect the Power cable of Printer from wall outlet.
2. Check thoroughly in Printer that there is no small piece of paper in the Printer.
3. Let the Printer be disconnected and idle for 5 minutes.
Meanwhile please perform further steps on Computer.
  Note: The below steps are applicable if you are using WINDOWS 2000/XP/VIsta Operating system in  your PC
  Steps are:
 Perform the below steps to restart the print spooler :
1. Click Start>Run
2. Type services.msc
3. Click OK
4. A Window will pop up with so many services listed.
5. Scroll down to locate "print spooler" in the list, right click on it and click "Restart"
6. Restart the Computer.
Once if you are done with steps, please connect the Printer and then Power ON Printer and check the issue.
This should resolve the issue for you.
 If you need any further assistance on the issue, you can mail me at thumuvikram@rediffmail.com . I'll be glad to help you.
Bye.
Posted on Oct 20, 2007
  • 12 Answers
SOURCE: paper jam problem in pixma mp145. E3 error.
MP160 PIXMA paper feed jam E3 error. I completely solved this on my Canon MP160 printer but it is a common problem and the fix may work for others such as MP130 MP140 MP145 MP150 MP170 or MP180. With the problem I had, the printer would make the usual motor whirring noises but would not feed the paper. The usual c-clunk sound that indicated the feed roller has been engaged was not there. The screen warning said to remove jammed paper and the printer showed an E3 error.
The problem was caused by the ink cartridge carrier becoming stcky on its track and not fully returning to the rest position on the right side (as viewed from the front). The fix involved taking the printer apart and lubricating the cartridge carrier track and the ramps that lift the cradle that rises to cover the printheads. Unfortunately you have to dismantle the printer and separate the scanner unit to get to the lubrication points. Its not a quick fix.
When you have the printer apart you will see a prominent white lever held by a coiled spring just behind the rest position of the ink cartridge carrier. The lever is actuated by the ink cartridge carrier when it moves to the right. If the lever is not actuated, the motor drive will never engage the large grey feed roller and the paper in the hopper cannot be fed into the printer. Make sure to also put some lube onto the lever at the point where it is struck by the ink cartridge carrier.
Posted on Jun 13, 2009
pineworks
  • 4041 Answers
SOURCE: My canon ip2600 printer has a paper jam error, but there isn't.
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
SOURCE: Paper wont feed into printer no paper jam
In the comments section Blumm suggests pushing a piece of cardboard (like the back of a legal pad) through the feeder as far as you can. Turn the printer off and then on again with it in there. Pull the cardboard out and check for any foreign objects that have been pushed through.
It worked for many people including myself - I got a piece of plastic and it works wonderfully again!
Posted on Jul 31, 2010
Mp280 printer indicating p /3
P03 is a mechanical jam (carriage, paper jam, paper pickup etc).
Open everything you can and look for foreign objects or jammed paper inside the printer.
If you cannot see anything then it may be a sensor error. You could always try cleaning the sensors if you were feeling brave.
Oct 30, 2012 | Canon MP280 All-In-One InkJet Printer
Printer is in alarm mode stating a paper jam when there isn't one?????
Even though u cant see a jam there there is exactly a jam inside
U believe it or not thats why paper jam
Look for the paper detection sensor below the carriage
use ur common sense
I cant say exactly it is detect sensor it may be some other sensor related to gear wheel set
but most of the cases paper jam occurs due to malfunction of paper detect sensor
If u find it use a thin tool to see it is working properly
otherwise give it to someone know how to repair & pay a reasonable price
thx
Sep 17, 2012 | Canon PIXMA MP280 Photo Inkjet All-in-One...
I'm trying to print but it keeps coming up with an error message paper jam, remove jam paper and press start. There's no paper jam and it won't print. I have try talking out the paper from the feeding tray...
Please remove your printer from the PC and uninstall the printer software. Now reinstall the printer driver software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
If the printer shows a jamming error then check the input of the paper feed as there can be some foreign objects that is obstructing the detector opto-coupler or the detect switch. clean and check or the sensor is faulty.
Mar 18, 2011 | Canon Office Equipment & Supplies
Error message paper jammed on my printer but there is no jam. my color ink is out but i don't use color
when it happen like that turn off the printer, print anything, open the active printing file. it will show u the jam paper and the current printing one. cancel the spoonling paper, after cancelling put on the printer and it will work fine
Sep 13, 2010 | Canon PIXMA MX310 All-In-One Printer
Printing error Paper Jam
It happens because of the mechanism wear. I have one the same. You can pres the start button and the printer will restart printing.
May 13, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Canon ip4300 Error code 1300
u have to reset ur printer try to hold ur finger on power button for more than 15 sec then turn it on again
Jun 09, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Paper jam 11
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Step
Step
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Step
9
Nov 07, 2008 | Copystar CS-1815 Printer
Canon MP280 All-In-One InkJet Printer Logo
330 people viewed this question
old marine
old marine
