Sears 92 gas furnace noise when not in air handling mode
My 5 year old Sears gas furnace has a hum coming from the front panel of the blower compartment when the blower is not on. Is this normal.
  • Anonymous Jan 10, 2009
    I have a Carrier perf93 gas furnace that is making a lound humming sound while on for heating the house (little sound when air conditioner is on) can't figure out how to muffle that sound. It was billed as one of their quieter machines but it is Loud!
    Novelist:
  • 124 Answers
A very subtle hum or buzz is normal and is the transformer that creates 24 volt control voltage continually. some are noisier than others . sometimes a tap or bending of the transformer will tweak the metal enough to make it quieter. they can also get loud if incoming voltage is not correct. incoming 120 volts on a furnace is not usually a problem but the transformers are usually wired to the available incoming 230 voltage or 208 voltage if it is a heat pump or electric heat. If it is powered by 230 or 208 volts as most heat pumps are ,then you need to verify which you have and connect the appropriate leads from the trans former to power . it tells you on the side of the transformer which to connect to 230 and which to connect to 208. tape or cap off any unused leads.since you have not mentioned any performance problems i assume the fan does come on when called for and that it is not the loud hum you hear. switching the fan switch at stat to on should bring the fan on right away. if it doesn't then you may hear a loud hum and then youll need to check the fan motor and capacitor. but it sounds like a noisey transformer from here.
Posted on Oct 28, 2008
Blower motor
Make sure the capacitor matches with the new motor
Dec 09, 2013 | Weather King 10AJA6001AH Air Conditioner
I have an e3eb020h furnace that, when I cut it on, the blower works fine, but I have a weird humming noise coming from the furnace unit. What could it be?
humming could be a body panel or metal to metal point that came loose and just needs secured in the furnace or ductwork. could be an electrical issue that you may or may not be able to find with the doors off and trying to locate where the hum is coming from. it may go away when a panel is removed because it night be air sucking through a loose section of the door. the question is vague but I would press around while its running to see if it subsides. as always when its running with the panels off electric shock hazard and arc flash can occur causing bodily injury or death that's why they have the door switch which will cause the unit not to work with the door off. you can tape this switch to test the furnace but be very aware it is done on your own and I cant tell you it is ok to do this if you have no knowledge of electricity and its dangers. this is only for you to possibly find a hum and not press around on electrical components.
Oct 20, 2013 | Ruud Heating & Cooling
Heat....Furnace will not start up worked fine last year it is getting power... I can hear I light hum in the furnace but it will not start it process
If its a high or mid efficiency furnace most of the time the sequence of operation goes as follows: tstat calls for heat (R&W at tstat ) ventor motor starts, pressure switch closes, spark or hsi lights pilot or main burners. main blower motor comes on. From your description of a humming noise it sounds like maybe the ventor motor is seized.
Oct 08, 2012 | Heating & Cooling
Why is it whining and humming?
Sometimes a louver on the squirrel cage comes loose maybe from taking it apart...hand test every louver. You may find that you need a new one.
Jun 29, 2012 | Emerson Lennox Ducane Armstrong Furnace...
Kenmore furnace mdl BGU100168 status light indicates ignition lockout. How to correct.
Can you please verify the furnace mode, nothing comes out with the BGU100168 model #. Is it an oil or gas furnace? Was it bought at Sears?
In the mean time you can try cleaning the filter, with a piece of emery or sand paper sand clean the flame sensor (thermocouple) in front of the pilot light (if applicable). Reset the unit by disconnecting the power for 5 min. and tuning it back on.
Keep me posted!!
Dec 07, 2010 | Heating & Cooling
I have an amana 90 10 years old the blower starts and the igniter glows but the gas does not come out and ignite. the furnace tries three times to start but quits after three tries. What can I do
Hello,1st check that the gas valve is on (the knob on top).2nd check that the gas handle is open in the gas pipe next to the unit.3rd was any work performed on the gas service (new gas stove,clothes dryer,hot waterheater,fireplace) there might be air in the gas pipe that has to be purged out.It is safe to reset the unit and let it attempt to light 3 trys.(turn the power switch on/off) untill the air is out.Listen for a "click" from the gas valve thats is when the gas is on.It is a fuel supply problem,is the gas to the house turned on?any street digging in front of the house by others?Your utility company can check.
Oct 27, 2010 | Amana Heating & Cooling
I have an 11 year old natural gas forced air furnace--a Goodman GMPN100-4 Rev B, which is 100K BTU and 92% efficient which was working fine at the end of last winter. I went to turn it on for the first...
You are correct. If the inducer motor is warm, but not running, it has seized up. If you replace this yourself, I also suggest that when you replace the inducer fan, check to make sure the secondary heat exchanger isn't clogged, or the condensate drain(s). If you have an HVAC contractor replace it, he should do this for you. It shouldn't run more than $350, to have it replaced and he can check for clogs (The price I'm quoting is for standard hours).
You can check this yourself by running the inducer fan without it being attached to the furnace, then attaching it to the furnace. If you notice a significant reduction in airflow, then you have a clogged secondary heat exchanger. I've run across this situation before on this particular model. The owner recenly replaced the inducer motor, but couldn't figure out why he was still having problems. I suspect the clogged heat exchanger contributed to the inducer motor to failing previously, and feel It would definitely be worth checking while you have the fan removed to help eliminate any future problems that could result from this, including heat exchanger failure. The manufacturer of this unit actually recommends you clean the secondary heat exchanger every year, but this is overkill if your furnace was installed and set up properly. I'd recommend doing it every 10 years and you're at that mark now. Instructions on how to do this are in the manual for this unit if you have it. Otherwise, e-mail me at wheels38_97@yahoo.com and I can send you a copy.
Finally, check the limit and flame roll out switches after replacing, as they could have tripped when the motor failed.
Oct 22, 2010 | Heating & Cooling
Rheem gas furnace pilot lights, but no burners or fan
If the burners do not fully ignite, the sensor will shut the furnace down. The lack of sufficient burner flame is a gas valve or gas pressure problem within the valve.
Replacing the gas valve with the original one may get you going. I surely suggest a professional service company for safety reasons and a thorough inspection. A 20 year old furnace is past it's normal life span.
Jan 06, 2009 | Heating & Cooling
Loud humming noise
when was last time furnace was serviced --air filter change burner area cleaned vacuumed the hum can be a few reasons ---fan bearing need service [ oiled ] fan bracket bushings damaged or loose --burner out of adjustment burning improper etc these are a few
Jun 03, 2017 | Heating & Cooling
Carrier 58mvp furnace ecm motor is making viberating noises
ecms are pretty reliable and electronic failure is much more common than bearing or bushing wearout. i suspect the fins on the blower may be coming loose from their pressed on spline and that will start a vibration or shimmy or you could have thrown a weight that balanced the wheel . best to use to warranty to get a new wheel. good luck
Dec 07, 2008 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
396 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
