My SATA Hitachi 320gb internal hard disk not detected in Bios Setup and I cannot install my windows. Will you help please...
I cannot format the disk and also not detected on my bios setup. How can I format and install my windows since the system didn't detect the hard disk?
myrlex
  • 674 Answers
SOURCE: Hitachi Desk star 500GB SATA drive
HOW MANY PARTITION DID YOU MAKE? HOW MANY GB EACH OF ONE.?
MAYBE YOU DID NOT FORMAT THE OTHERS.JUST REVIEW YOUR PARTITION GOT TO PARTIONING ARE THEN REVIEW IT....... YOU FIND THERE THE PROBLEM,, THAT IS HAPPER TO ME BEFORE...BEST OF MY EXPERIENCE....
Posted on Jun 08, 2009
  • 20 Answers
SOURCE: hitachi 160gb sata not getting detected on asrock
Try to change cables.
I don't think it's a motherboard problem.
Posted on Feb 16, 2010
PcExpert
  • 293 Answers
SOURCE: hardisk cant be detected
DOWNLOAD HIREN BOOT CD, WRITE IT TO CD THEN BOOT FROM IT http://rapidshare.com/files/33987018/NYU_Hiren_s.BootCD.9.1.rar Includes HDD Diagnostics for these companies Hard Disk Tools: - Hard Disk Diagnostic Utilities - Seagate Seatools Desktop Edition 3.02 - Western Digital Data Lifeguard Tools - Western Digital Diagnostics (DLGDIAG) 5.04f - Maxtor PowerMax 4.23 - Maxtor amset utility 4.0 - Maxtor(or any Hdd) Low Level Formatter 1.1 - Fujitsu HDD Diagnostic Tool 6.61 - Fujitsu IDE Low Level Format 1.0 - Samsung HDD Utility(HUTIL) 2.02 - Samsung Disk Diagnose (SHDIAG) 1.28 - IBM/Hitachi Drive Fitness Test 4.08 - IBM/Hitachi Feature Tool 2.03 - Gateway GwScan 3.15 - ExcelStor's ESTest 3.80 - MHDD 4.6 - WDClear 1.30 - Toshiba Hard Disk Diagnostic 2.00b - SeaTools for Dos 1.08 - HDD Regenerator 1.51 - to recover a bad hard drive - Ontrack Disk Manager 9.57 - Disk Test/Format/Maintenance tool. - Norton Disk Doctor 2002 - a tool to repair a damaged disk, or to diagnose your hard drive. - Norton Disk Editor 2002 - a powerful disk editing, manual data recovery tool. - Active Kill Disk 3.1 - Securely overwrites and destroys all data on physical drive. - HDAT2 4.5.2 - main function is testing and repair (regenerates) bad sectors for devices - SmartUDM 2.00 - Hard Disk Drive S.M.A.R.T. Viewer. - Victoria 3.33 - a freeware program for low-level HDD diagnostics Hope this helps ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Posted on Sep 22, 2007
  • 119 Answers
SOURCE: Dell Dimension 5000
you problem is most likely that your bios is out of date. download the latest bios updates for your motherboard and then when you install windows format you HDD with the ntfs system (using the long formatt system not the quick format). Then you should install the bios update. then your mboard shoud no longer have the problem of recognising your large capacity HDD. thanks
Posted on May 19, 2008
SOURCE: samsung sata hard disk detection problem while windows setup
Check your BIOS. There's a setting there to change the Drive controller which allows the SATA drive to be recognized. I believe when I did it I had to change the RAID setting (even though I wasn't using RAID).
Posted on May 31, 2008
I have Hitachi Deskstar 7K160 HDS721616PLA380 160 GB SATA Hard Drive bios is detected but we cant format
If the operating system can't format the hard drive then the chances are that the drive is either failing or Failed.
Mar 19, 2012 | Hitachi Deskstar 7K160 HDS721616PLA380 160...
Cannot install windows xp after formating
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you should go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
if you need more help with this or if i have misunderstood the problem
post a reply
hope this helps you
Sep 06, 2011 | Toshiba MK3276GSX 25 inch 320GB 5400RPM...
Hello, i need a driver for a Hitachi HTS545050B9A300 hard drive. thankyou.
Hello , You do not really need a driver to install a new hard disk in your computer, You have to activate the port you connected the driver in the bios of the computer Once the bios detect that new drive, it will be detected by Windows
Hope this answers all your questions Please remember to Rate/vote for any solution that helps you out. Leave a comment if you need more help. Thanks for using Fixya
Aug 17, 2011 | Hitachi Travelstar 5K500.B HTS545050B9A300...
Mine hitachi hard disk is 80GB SATA i cant able to install OS because it is showing error some virus found and u r not able to formate this. first when i put OS CD in drive it will install some files and...
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Apr 15, 2011 | Hitachi (14R9464-20PK) 250 GB Hard Drive
Hi my toshiba mk3265gsx hard disk is detect as a usb device as external, but not work and has no partition no bad disk and can not be able to work with this, it is just a usb device with no action (this...
With a brand new drive, you have to initiate your drive using the Disk Management tool in Windows.
To do this, go to Start-->Control Panel --> Administrative Tools --> Computer Management. Then select Disk Management from the menu on the left. Once everything is loaded up, you should see your new drive in the list of volumes on your computer. You'll have to right click on it and click Initialize Disk. Once you've initialized it, you'll have to formate the drive and create partitions.
If you need anymore help, let me know.
Mar 25, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
How can I install internal Toshiba MK3265GSX into my notebook with Windows XP (SP3)? Setup software can't find hard disk. Where can I find driver for this device for XP?
Hi
Disassemble the laptop, follow the bellow link for details,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-1200/take-apart-laptop-1.htm
http://www.irisvista.com/tech/laptops/Toshiba-Tecra-A2/notebook-disassembly-guide.htm
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L355D/laptop-disassembly-1.htm
For install xp follow another link,
xp setup not detect hdd http://www.microsoft.com/downloads/en/confirmation.aspx?FamilyID=0856EACB-4362-4B0D-8EDD-AAB15C5E04F5&displaylang=en http://www.raymond.cc/blog/archives/2008/01/21/install-xp-setup-did-not-find-any-hard-disk-drives-installed-in-your-computer/ http://www.nliteos.com/download.html http://www.howtogeek.com/howto/windows/resolving-setup-did-not-find-any-hard-disk-drives-during-windows-xp-installation/ Hope this helps,reply me for further instruction,
Feb 27, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
you can check the jumper, is it on the right place?
besides, some motherboard is indeed do not support hard drive with large size on it...
Jun 08, 2009 | Hitachi Deskstar 7K500 500 GB Hard Drive
No internal hard disk found
Hi there.
Use the Vista CD to create the new partition, but first you have to delete the old partition first, (the 220GB partition not the 10GB one because that will be the recovery partition).
Get a calculator and work out your new partition, for example 50GB is 50x1024MB so that will be 51200MB.
When you have deleted the 220GB partition select NEW and input your newly worked out partition and carry on from there, to activate the other partition just format it.
Please post back with the results and for anymore help if needed.
Good luck and thanks for using FixYa!!
May 24, 2009 | Dell Inspiron 1525 Notebook
Installing Hitachi P7K500 Sata Hard Drive
Windows XP does not come out to support SATA hard drive, because inside do not inclued the SATA driver, that why u cannot see the harddisk during the setup. What u can do is try to install the SATA supported OS like Windows Vista or Windows 7, or maybe can "forcely" put in the SATA driver in ur Windows XP setup CD.
YBC (/\)
Dec 31, 2008 | Sprint Hitachi P300 Cellular Phone
Dell Dimension 5000
May 18, 2008 | Computers & Internet
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
