Question about Syntax SV266M Motherboard
Motherboard manual sv266m - Syntax SV266M Motherboard
Hola amigos mi pregunta era saber cuanta memoria aguanta el mother sintax sv266m(a)
a sintax sv266m memoria m?xima que se puede utilizar en la placa base es de 2 GB
Aug 02, 2011 | Syntax SV266M Motherboard
Syntax SV266M
if you go to this link.
you will need to sign up its free to sign up.
http://members.driverguide.com/driver/detail.php?driverid=350098&si=cb50455104f1d4b8bed38935cfebe1bf
this should help you
Good Luck
Happy Computing
Jan 10, 2010 | Syntax SV266M Motherboard
I need specs
Here is the specs of the mobo.
Product MPN MPN sv266m Key Features Form Factor dtrquestion.gif Micro ATX Compatibility PC Chipset dtrquestion.gif VIA ProSavageDDR KM266 Compatible Processors AMD Athlon Processor Max supported CPUs qty 1 Memory Memory Type dtrquestion.gif DDR SDRAM Max Supported RAM dtrquestion.gif 2 GB Audio / Video Audio Output dtrquestion.gif Sound Card Video Interface dtrquestion.gif AGP 4x Communication Networking Type Network adapter Other Features Chassis Type dtrquestion.gif Desktop Package Qty 1 Dimensions Depth 9.52 in. Width 8.97 in.
Dec 03, 2009 | Syntax SV266M Motherboard
Drivers needed for syntax sv266m motherboard
You can try following links for downloading the drivers:
http://download.driverguide.com/driver/SV266M/Syntax/d350111.html
http://ar-domena.com.pl/sv266m/
Nov 04, 2009 | Computers & Internet
I cant find syntax's website to download a flashing utility and the bios image.
HI timereillyis,
The Syntax-Brillian Corporation maker of the SV266M Motherboard, In May of 09 all assets were acquired by Emerson Radio Corp. Now, I don't think Emerson is going to support that motherboard, however, you can can most of your drivers, from HERE. You may need to create a login, but I'm pretty sure they will have what your looking for.
Thanks
Mark
Oct 21, 2009 | Syntax SV266M Motherboard
Cant get past windows xp screen
http://downloads.drivershq.com/DD/driverfiles/5/DriverDetective.exe
Here is what you need!!! Click on the Above Link. Download Software!!!
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 04, 2009 | Syntax SV266M Motherboard
Syntax sv266m motherboard....it wont go past the windows xp scree
check if the safe mode is working..?pressing F8 just b4 windows xp screen comes up...
if yes then good...
check if u seated the ram properly?.and check if its showing the full amount of ram in the bios page..
Need all Drivers
You can refer to the manual for component specifications.
Here's some helpful pieces of information:
Chipset:
-- VIA Apollo KM266
-- VT8375 Northbridge
-- VT8235 Southbridge
VGA
-- Onboard S3 Graphics ProSavage8
-- 4x AGP
Audio
-- AC' 97 Audio
LAN
-- Onboard Realtek TRL8100B
Google any of these components and you should have better luck finding drivers for the board.
Jun 01, 2008 | Syntax SV266M Motherboard
Compatible Memory
if your motherboard is a DDR Ram supported type memory it should be able to take DDR 2100 or higher as most DDR is backward speed compatable, but it may be incompatable with certain types of ram or may need two of the same speed in each slot. Pc 266 is the double data rate of pc133 which in DDR terms is pc 2100
Apr 19, 2007 | Syntax SV266M Motherboard
Syntax SV266M Motherboard Logo
192 people viewed this question
Top Syntax Computers & Internet Experts
Steven Burn
Steven Burn
John Anderson
John Anderson
T-Comtech Repairs
T-Comtech Repairs
Are you a Syntax Computer and Internet Expert? Answer questions, earn points and help others
