Question about Hitachi HDS721032CLA362 / 0A39264 Deskstar 7K1000.B 320GB 7200 RPM 8MB cache SATA 3.0Gb/s 3.5 intern... SATA II Hard Drive
My hitachi 320gb is not detected in Bios setup
  • Hitachi Master
  • 27,725 Answers
One bad lead or faulty connection point can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure they are dust free and securely seated some motherboards cmos batteries are soldered in
hope this helps you
Posted on Feb 25, 2012
Cannot access bios setup
The function key, probably F1 must be pressed as the first splash screen shows otherwise you will miss it.
Mar 21, 2014 | Gateway NE56R Dual Core 2.10GHz 4GB 320GB...
Is Hitachi 320GB SATA 2,5"
you perches ata to sata connector or sata to ata connector
Sep 07, 2011 | Hitachi 320GB SATA 2,5" HTS543232L9A300...
I have been using HTS545032B9A300 320GB drive in my Samsung R428 laptop. One day, suddenly, its shuts down and never boots up. It never gets beyond setup. It hangs and showing "Entering into...
When start your laptop,is their any spinning sound in your hard disk(Hitachi)?
If so, try to go setup the bios ,just watch the laptop either detect or not,
If your laptop detect the hard disk ,again install to the laptop, and remove the new seagate just for recover the data through following step.
Please download hiren boot bootable ISO file ,
Download the iso file from =http://www.fullandfree.info/software/hirens-bootcd-v100/
Mazor problem is most of the user, burn ISO file in data mode and the result, it could not run in boot time.
Burn the iso file, under image burning option from any nero .
Boot from cd, no need to setup bios.
DONT PANIC follow all the steep It is very simple. (Use the down arrow key.)
1.INSERT CD TO CD TRAY
2.Boot from cd
3.Select start boot cd
FOR REPAIR THE HDD DONT PANICI
Choice hard disk tools
1.select HDD regenerator>enter
wait create it auto mode
2.Enter(If you have one HDD)
3.Press "1"ENTER for scan and repair (With out lose any data)
4. press 3 for REGENERATE ALL SECTORS
I will sugest press for "1" and enter
press( 1-9 )any one number and type mb and ENTER
Repair will Start soon.
Insert a pen drive
Restart your laptop and boot from cd
1.Boot from cd
2.Select mini windows
3.you can explore every drive (hitachi) and can copy paste to pen drive.
ALL IT WILL BE POSSIBLE IF YOUR HDD CAN SPIN AND AND READ .
Hope this helps.
Shibuda,
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Jan 18, 2011 | Hitachi Travelstar 5K500.B...
I connect my new 320GB hitachi internal hard drive (ide) as a primey slave, to go along side my primy master, but It doesn't find my 320gb hard drive?
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to ......,press escape then press f10 to save to cmos to restart
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
??????????????????????????????????????????? hope this helps
Jan 08, 2011 | Hitachi Deskstar T7K500 320 GB ATA-133...
Where can I find a driver for my hitachi travelstar IC25N080ATMR04-0
1. You shouldn't need a driver for the hard drive
the Bios ( Basic Input/output system ).
2. You mother board should detect the driver
3. You will have to go into the BIOS setup to see of your hard drive is detect then set the BIOS to boot from the hard drive
4. If your pc takes SATA ( Serial advance technology attachment) then a IDE ( Intelligent drive electronics) will not work with the system without an adapter.
5. Your PC mother board instruction manual will have instruction on hard to access your BIOS settings
Caution: Any changes in the BIOS will not allow some devices attached to your PC to work properly is not properly addressed in the BIOS setup.
Mar 19, 2010 | Computers & Internet
After windows sp2 update
0141 error is no hard drive detected. So boot to the BIOS F2 at boot and ensure that the BIOS is seeing the hard disk drive. If it is not, then reseat the drive/drive cable connections and try again. If the drive is detected in bios, then try booting to WIndows, if HDD never is detected, reset bios defaults and reboot, and see if it detects, if still not detected, replace the hard disk drive
Nov 01, 2009 | Dell XPS 420 (dxcwqj1_2) Intel Core2 Duo...
Tring to replace h/d w/hitachi deskstar 500 gb sata h/d on bootup cant find h/d. the old h/d was single ide can someone help ?
Get into the BIOS screen and make sure that the hard drive is detected under the SATA port. If not you may have to set it to auto. In some BIOS cases it is turned off by default. You may also have to turn off the IDE in the BIOS so the computer does not go looking for it. To get into the BIOS look for a screen message on startup (during or after the splash screen, before windows starts) that says something like "Press F2,Esc,Del,etc to enter setup."
Once in setup the instructions for navigating it should be somewhere on the screen.
Mar 12, 2009 | HP Compaq Presario SR1053WM PC Desktop
Installing Hitachi P7K500 Sata Hard Drive
Windows XP does not come out to support SATA hard drive, because inside do not inclued the SATA driver, that why u cannot see the harddisk during the setup. What u can do is try to install the SATA supported OS like Windows Vista or Windows 7, or maybe can "forcely" put in the SATA driver in ur Windows XP setup CD.
YBC (/\)
Dec 31, 2008 | Sprint Hitachi P300 Cellular Phone
Hard disk drive not detected
firstly check your cable connections, then log onto your bios setup menu during startup and check whether the Hard drive is detected by your bios, if it is then you can try to format the harddrive using the ntfs system (use the long formatt) if you are using windows xp or later if using any earlier os then formatt with the FAT32 system.
If your HDD is not detected by the bios then try to download bios updates for your motherboard and install thed in windows. is this does not work then its time to get a new HDD. thanks
May 27, 2008 | Hitachi hts548080m9at00 80 GB Hard Drive
Hitachi HDS721032CLA362 / 0A39264 Deskstar 7K1000.B 320GB 7200 RPM 8MB cache SATA 3.0Gb/s 3.5 intern... SATA II Hard Drive Logo
157 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
