My DVD Player wont play on my tv dont know which is right channel
  • 903 Answers
If you are using a scart lead then you need to set your t.v. to AV or EXT. Plug your dvd in, turn it on and using your tv controls, press av or ext until it picks up your dvd. Sometimes you may only need to press the av/ext button once sometimes 2 or three times, depending how many outlets you have on your tv and which one you have you dvd plugged into.
hope this helps
Posted on Oct 28, 2008
White screen when playing dvd
try either a different player or a different tv to see which is causing this, if a player usually cheaper to buy another one.
Sep 01, 2012 | Televison & Video
I dont have cable.i was using this tv just to play dvds and i accidentally hit channel search. now i get a blue screen that says" plerase connect cable system or an antenna to the terminal on the back...
Using remote locate a button called tv/video or Input, turn on the DVD player and hit this button until you see your DVD player Logo. Most dvd players use either video 1 or 2, or componet or HDMI outputs. Seems you have changed the TV's input back to TV mode and you need to change it to a video mode input.
May 17, 2011 | Televison & Video
Trying to hook up dvd player to a philips 27ps55-s121. I cant get it to show up on the tv screen. I dont know what channel the tv needs to be on to show the dvd. and i am unsure where what plug (cable)...
Connect one end of the VIDEO
(yellow) CABLE to the AV1 in VIDEO
jack on the back of the TV. Then connect
one end the AUDIO (red and
white) CABLES to the AV1 in AUDIO
L and R(left and right) jacks on the rear
of the TV. Connect the other end of the cables to the appropriate color on the DVD player (yellow to yellow etc.)
Press the CH + or – buttons on the
remote to scroll the channels until AV1
appears in the upper left corner of the
TV screen.
Slide the TV/VCR/ACC switch to
the VCR position.
Insert DVD into player and press PLAY.
Aug 23, 2010 | Philips Televison & Video
I have a model dvd-vr 357 samsung dvd-vcr player recorder to hook up to a 2002 hitachi, and i must have it hooked up wrong.the tv is a 52 inch large screen h.d. the dvd -vcr turns on and when play is...
You need to use the video and audio outs located in the rear of the samsung player, or if you want to use the rf connector(atenna in) on the tv you need to select analog channel 3 or 4 to get a picture through, you can down load an owners manual at
Feb 03, 2010 | Televison & Video
Video channel
if your DVD player supports a HDMI cable a single cable is enough for both audio and video channel.
but both your player and TV must support HDMI.
Aug 12, 2008 | Samsung DVD-V4600 DVD Player/VCR
To connect my dvd player
Check your remote. On my Sentry 2, the magic is the SOURCE button, which allows you to access the AUX (auxilliary) channel. This is what you need to select to view your DVD output.
May 10, 2008 | Zenith C27A24T 27" TV
Can't get to "Video 1" to play DVDs
try turning your dvd player on and then doing a channel search if that does not work just buy a RF modulator and hook up your dvd player to it and it will run on channel 3 or 4 and will switch over by itself when you turn on your dvd player
Feb 26, 2008 | Emerson EWF2703 27" TV
Lightning Mcqueen TV/DVD COMBO
my lightning maqueen tv dvd player keeps cutin off what do i do
Feb 14, 2008 | Disney Ramone DVD Player
My dvd/vcr promblem
Neen codes to program in my remote
Dec 26, 2007 | Daewoo DV-6T834 DVD Player/VCR
Connecting a dvd player to a BUSH Bush BTV180T 14in TV/VCR Combi
if there is a scart connection on your bush tv then
you can use your panasonic dvd player on it, trust me
just look all over the remote carefully for an AV button, or failing that press channel up or down whilst the DVD is powered up and playing a disc and you will have solved it
hope this helps mate
Nov 05, 2007 | Bush DVD142RC 14 in. TV/DVD Combo
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
