Question about Dell Computers & Internet
How to connect Dell Vostro 1510 to LED Vizio TV
Vostro 1510 connecting to Vizio LED television
Nic61
  • 1073 Answers
SOURCE: i need integrated webcam for dell vostro 1510
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=04&l=en&s=bsd&ServiceTag=&SystemID=VOS_N_1510&os=WLH&osl=en&catid=&impid=
THere u go!
You will find the drivers under Input devise drivers----> Sonic SN9C230
Good luck
Nic
Posted on Mar 01, 2009
NitrusInc
  • 326 Answers
SOURCE: I have problem with my vostro 1510 wreless,
The Dell QuickSet utility Wireless options can cause these issues.
There is a setting to always deactivate on battery. Make sure this is not set up. The correct setting would be Always active on battery or Always On, or no power saving options for Wi-Fi. Depending on the version of QuickSet which you have.
It is known to glitch when power is removed from the machine while the wireless is in use.
Please let us know if you have any futher questions. If this information was helpful, please take a moment to rate the solution. Thank you.
Posted on Apr 23, 2009
anshlittle01
  • 57 Answers
SOURCE: Activating bluetooth on Dell vostro 1510
hi,its easy
go in "starts" menu and then go in all programs and then go i bluetooth, then go in wireless file transfer,after doing tht a bluetooth ikon will appear near the place where you see the clock on moniter,right click on that ikon and then select the option u want to perform. remeber that enter same code in both the laptop and the device which you want to use like mobile.
cheers
Posted on Jul 18, 2009
  • 3940 Answers
SOURCE: dell laptop vostro 1510 flashing 9 on the keyboard
That is an indication of either a Video or an LCD failure. If under warranty, contact Dell Tech Support.
If out of warranty, remove all drives, battery, wireless card memory and see if error indications change. If they do, add a ram module back and see if the system posts. If it does, add items back one at a time until you ID the faulty one.
If there no changes, the the motherboard most likely has failed.
You can run the troubleshooter to see if the tool gives you more detailed information
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?c=us&cs=04&l=en&s=bsd&journalid=7AF02DEA4AA96B7BE040AE0AB8E13EBB&treeid=2C485ADAA75B367CE040A68F5B285C4D&Query=bm8rcG9zdCtWb3N0cm8=&SystemID=&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=false&dl=
Posted on Dec 18, 2009
SOURCE: Dell Vostro 1510 laptop.NUM lock
Go to dell site and check what LED flashing means.This points to the problem.good luck
Posted on Apr 13, 2011
In dell vostro 1510 laptop, when adapter is connected to laptop it showing "plugged in, not charging"
is battery already fully charged? Most of laptops disharge the battery while connected with AC adapter, they do not keep the charge at 100%.
Oct 10, 2013 | Dell Vostro 1510 Laptop
What cables do i use to connect my inspiron 1510 to the t.v. and/or cable box
If you are trying to route video from the computer to the TV, the only video out on this model is via the VGA connection which would require a VGA input on the TV or cable box.
Sep 10, 2011 | Dell Vostro 1510 Laptop
Press power button nothing comes up on screen, however, the num lock icon lights up and flashes, the caps lock icon also lights up. Dell Vostro 1510.
Copy and paste this link into your internet browser for the service manual for your laptop.
http://support.dell.com/support/edocs/systems/vos1510/en/SM/html/trouble.htm#wp1092170
The star icon (*) means flashing LED, the bold circle means on, the circle within a circle means off.
The LED's that they are referring to are the NUM, CAPS and SCROLL.
It appears that you have a problem with your LCD. Try connecting an external monitor to your laptop. If you get a display then your LCD display panel needs to be replaced. If no display then your motherboard needs to be replaced.
Apr 19, 2011 | Dell Vostro 1510 Laptop
I have install the drivers for my dell vostro 1510 webcam but i can't lunch to use it
uninstall the driver of dell vostro 1510 webcam remove the connection
now connect the webcam it will detect the new hardware found goes through this and give the path of the driver and check it .....
if after connect the webcam its not detect ....its may be your webcam or usb port problem
Oct 13, 2009 | Dell Vostro 1510 Laptop
Computers & Internet Logo
75 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
