Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Washer WM2075CW -The dispenser is stuck, only pulls out aprox 1/2
LG Washer WM2075CW - Frt Load - Ultra Capacity-Direct Drive System- SS Drum - Quite Operation - Detergent Dispenser is stuck, only will pull out aprox 1/2". Does it have a locking system so it cant be opened durning operation OR could it simply be one of the trays has gotten mis-positioned and is sticking on the lip. This problem started a couple months ago and I've been able to giggle it & it's always opened, until now, now all of a sudden "STUCK" - Suggestions please - Thank you / Michael -Lake Forest, Ca.
  • LG Master
  • 2,306 Answers
Yes you are correct, fabric softener dispenser is culprit. Search on this site for solutions. Issues and solutions have been posted often.
Posted on May 05, 2017
SOURCE: Water in detergent dispenser
Remove dispencer again, remove conditioner syphon assembly and clean up the little tube. Should then go okay
Posted on Jul 11, 2007
  • 74 Answers
SOURCE: lg wm-2277 dispenser tray
Hiya Vanch... disconnect the electric.. remove the lid screws at the rear.. slide from the front to the back with lid.
Depress the tab at the top of the drawer "gently" whilst easing the drawer from the machine.
Refit lid.. connect up to electric.. Sorted!!
Regards Faggly
Posted on Mar 19, 2008
  • 487 Answers
SOURCE: Soap dispenser stuck on LG WM2277HW
here is your SERVICE MANUAL
Posted on Jun 23, 2008
  • 1543 Answers
SOURCE: Detergent dispenser drawer stuck
You may have to remove the washer top (three phillips screws at the back, then push top back about two inches and lift it off) then drill a hole in the top of the plastic dispenser to allow you to use an object like a screwdriver to maneuver the offending part around so it will drop down and allow you to open the dispenser drawer. Use foil tape to seal hole if you don't want to buy a new dispenser. Clean out blue plastic dispenser parts so detergent will siphon out completely. Pushing down on the center tab at the back of the dispenser should allow you to take the dispenser drawer the remainder of the way out. In the future, make sure you do not use over 1 tablespoon of HE soap (and 1 teaspoon of fabric softner) max per load. Even less if you have 2x or more detergent.
Posted on Oct 11, 2008
  • 1543 Answers
SOURCE: Fabric softener not draining
Remove the dispenser drawer by pushing down on the tab at the center back and pulling drawer out. Now, remove the top of the fabric softener compartment and the parts of the soap dispenser and clean them all out. An old toothbrush often helps. Reassemble and replace. They should siphon out now.
Posted on May 23, 2009
What is the capacity of a front loading whirlpool washer MO#GHW9150PWO
Whirlpool GHW9150PW 27 Inch Duet Front-Load Washer with 3.8 Cu. Ft. Capacity, 8 Wash Cycles & Triple Dispenser.
whirlpool ghw9150pw0 capacity Google Search
Nov 25, 2017 | Whirlpool Washing Machines
My washing machine makes marks on everything
LG WM2101HW 4.0 cu.ft. Washer Stains clothes ruining ... > ... > LG > LG WM2101HW 4.0 cu.ft. Washer
... stains out with anything and they are ruining numerous items of clothing. ... stainson light objects ie making white marks on light blue clothes ruining these ... by greasestains from their front loader Kenmore. .... remove the agitator from a ...
Oct 19, 2015 | LG WM2101HW Front Load Washer, White, 4.0...
What is the button combination to put the LG washer in test mode?
i believe it is the power button along with the two center buttons on the right.
Mar 30, 2015 | LG WM2701HV Front Load Ultra Capacity...
That didn't work! What are some other options ? Machine has a child / pre-wash button but trying it did work either.
To activate or de-activate the child lock feature, press and hold the Child Lock button for three seconds.
Dec 29, 2014 | LG WM3001HWA Front Load Steam Washer,...
Lg front loader when during the cycle is the bleach dispenced
bleach? do u mean detergent? normally machines run pump/then start to fill.water will pass through drawer then they heat /wash/drain/spin then refil for rinse conditioner/spin rinse drain fast spin end pretty much
Aug 08, 2014 | LG WM2101HW Front Load Washer, White, 4.0...
Main control board needs replacing.
Nov 20, 2013 | LG WM2101HW Front Load Washer, White, 4.0...
Does not start
Could you explain the "no start" condition? Does it fill and not agitate?Do you get any lights on the unit? Does it dispaly any error codes?
Oct 13, 2012 | LG WM2101HW Front Load Washer, White, 4.0...
I have a front loading LG TROMM Steam Washer, serial No. WM2688HNW, 4.0 Ultra Capacity, Direct Drive System. My problem is a rubbing/scratching noise coming from the drum as it rotates. I ran my fingers...
Sorry. I doubt anyone on this forum would be able to give you that information. It's just made up of ordinary guys and gals, probably at home, from all over the world, with experience of addressing problems and giving guidance for free on the web but not supplying engineers or spares ;-0)
You will either have to search in telephone directories OR stay on line and search for '(make) washer service' for instance or '(make) washer spares' and hope that you can find someone reasonably local.
Sorry again ;-0(
Good luck,
John C
Mar 23, 2011 | LG Washing Machines
Washing Machines Logo
137 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
