Question about Westinghouse Refrigerators
I have a Westinghouse side by side refrigerator model WSE 7000S. The fridge door has suddenly stopped closing by itself. It used to close automatically once the door was less than perpindicular to t
Model WSE 7000 S
SOURCE: Right Door is making loud popping noise
replace the door cam assy. and door stop.
Posted on Nov 05, 2008
After reading these posts, I fixed my refrigerator door in less than 5 minutes. The little black plastic cam on the bottom hinge was loose. To fix it, take the hinge cover off of the top with an 8mm socket, and remove the three 8mm screws holding the top hinge on. Remove the door by lifting up off of the bottom hinge and set it aside. On the bottom hinge is a black plastic cam held on by an 8mm screw. The screw on mine was really loose. Tightening it and putting the door back on made it work like new. You probably don't have a bad cam, just a loose one.
Posted on Dec 25, 2008
  • 125 Answers
SOURCE: Kitchenaid refrigerator side by side, refrigerator door will not close on its on like it use to. Model #KSRS25qDWH01 bought in 1996. If we give it a push it closes fine. But it use to close nearly b
order a cam and stop for the affected door. it is on the top of the hinge and the bottom of the door, you'll see the two pieces if you look where the door contacts the hinge, call a dealer for the correct part numbers.
Posted on May 05, 2009
Muzzi_123
  • 749 Answers
SOURCE: Refrigerator Door Does not Close Properly
Try a hard reset. Just unplug the power cord for 30 minutes or more, then try again.
Posted on May 14, 2009
heavyice
  • 374 Answers
SOURCE: I have a whirlpool the refrigerator door will not stay close.
It shouldn't be pushing the door itself...you see the magnet that is used in the refrigerators are not repulsive.It doesn't get weaken that easily but what you can do is check if there isn't something bulging out of the fridge and pushing the door...take out all the things from inside and then try closing the door again. If door opens up again then definitely you have to look for a new gasket.
Posted on Jun 05, 2009
I have a westinghouse frdge freezer bj 385 motor constantly running with the door close motor stops intermidently open door motor stops recently moved fridge
Hi Peter, It it's not freezing the fridge up then it needs regassing but it it's freezing the fridge up then could be the thermostat, Good luck mate..... CHEERS..
Apr 04, 2016 | Westinghouse Refrigerators
Door Doesn't close on GE Profile PDS20SCRALSS
Check for long items, too big to fit in the fridge.
May 04, 2017 | GE Profile PDS20SBSRSS 30" 19.5 Cu. Ft....
Door does swing closed so it remains slightly open about half the time when the last person could have sworn they closed it. Hubby tried to adjust hinge but it did not make a difference. The fridge is only...
There should be a way to level the feet of your fridge so the door swings closed by itself. Check the user manual that came with your fridge for advice on how to do this on your fridge, as each make and model of fridge differs. This technique to level a fridge on the floor is generally necessary because the floor where the fridge is placed is unlevel, and it does not imply any fault with the fridge itself.
Jun 08, 2010 | Kenmore 53642 / 53644 Side by Side...
Fridge door does not close on it's own. possibly missing spring.
There are no springs to assist refrigerator doors to close.
The fridge doors can be made to close themselves by adjusting the height of the feet of the fridge. "Pitching" the fridge slightly away from the hinge will accomplish this. If the foot on the hinge side of the fridge door is slightly higher than the foot on the handle side of the door, the door will usually want to close by itself. If the fridge is a side-by-side type and this is done, one door will close by itself and the other will want to remain open (or open fully). In this case, it's best to have the fridge as close to level as possible.
I hope this was helpful.
Nov 28, 2009 | Amana Refrigerators
Jun 05, 2009 | Refrigerators
May 04, 2009 | KitchenAid KSCS25FKSS Side by Side...
Fridge door suddenly won't close
Your refrigerator may not be level side-to-side and front-to-back
Jan 05, 2018 | General Electric GDL22KCWSS Stainless...
Refrigerators Logo
94 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
