Question about Drills
Cant undo the chuck its really tight - Drills
  • 885 Answers
Some chucks get dirt, grime, and other foreign stuff in them or they rust internally and get stuck. If it's too tight to get loose by hand you may have to use some WD40 or Liquid Wrench and a channel lock pliers or vice grips to hold it tight enough to get it loose. If that doesn't work you may be looking at cutting the chuck off and replacing it.
Posted on Feb 27, 2012
How to remove keyless chuck
open the chuck jaws right up
down the center of the chuck you will see either a philips screw head or a hex head for allen key
hold the shaft at the base of the chuck to stop it from turning and undo the screw in the chuck in a right hand direction ( it is a left hand thread) when you have that out , still holding the shaft turn the chuck in the left hand direction ( normal thread ) and screw the chuck off
to assist in undoing the chuck do it up so that the jaws come out a bit
place something between the 3 jaws to act as a lever or use an allen key in the chuck done it tight and use that as a lever to undo the chuck
the secret is the lh thread screw in side the chuck which stops it from undoing when the drill is in reverse
Nov 17, 2015 | Bosch 18V Brute Tough Drill with Blue Core...
Cannot release tool from Dremel 300
I had a similar problem with a router, the best way to do it is to get a clamp, a strong metal c clamp, not too big but big enough to fit chuck into, line one side of clamp up with button and the other on the chuck. tighten the clamp as tight as you possibly can so it presses and holds the button in, and does not slip. Then use a wrench or whatever tool you use to undo the chuck. if this does not work, try spraying some WD40 on and leave to work for a few minutes.
Feb 21, 2014 | Dremel Tools & Hardware - Others
Cant remove chuck from a dwd 520
That one looks tricky! If the jaws on the chuck work lock an allen socket in the jaws and impact it of right hand with an impact wrench. This could damage the gears however if it's really tight. Another option is cutting half the chuck off in a chop saw just above the spindle and welding a nut on and impacting it off that way. The heat from the chop saw and welding will help loosen the chuck.
Good luck with that one!
Dec 28, 2011 | Dewalt Drills
How to remove the chuck from the drill to replace the motor
open the chuck as wide as it will go at the bottom of the chuck inside you will see either a Phillips screw or a hex screw . Turn this clockwise (it is a left hand thread) to undo it and take it out place a round bar ( bend a bolt ) bent at right angles in the chuck and do it up tight Tap the bar solidly with a hammer and the chuck will screw off .
Jul 31, 2011 | Metabo BS18 LT LithiumIon Cordless...
Can not get bit out of dewalt drill DW727 VSR
these drill are a "grip and rip" style chuck, you might have to place the chuck in a vise to get it undone. Though it shouldn't be that tough. I have never gotten a chuck so tight that I could not undo it.
Jun 07, 2011 | Garden
WHEN i TRY TO UNSCREW A TEC SCREW OR SCREW THE CHUCK KEEPS UNDOING, WHAT AM i DOING WRONG.
if you have it clamped nice and tight it should no way do this. unless the handle is hitting the chuck.
May 15, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
Can't tighten or loosen the "keyless chuck" inorder to put in a bit
What you need to do is get a piece of strong strapping, on a stick like a jar opener, or a vice, or some way of "Grabbing" the chuck, other than you hand, even using the inner edge of a door frame and "Grip" the Chuck, Now with a nice fresh battery installed, put it in "Reverse" and holding the chuck tight operate the unit and it should undo itself.
Feb 24, 2010 | Black & Decker & Cordless Drill
How do you replace the chuck on a Bosch 650 RE
while holding the drill like a gun, hold the lock button REALLY tight and pull the black part to the right really hard. this will unlock the chuck and if you keep twisting the black part to the right it will loosen it enough so that you can remove it
Jan 03, 2010 | Bosch Drills
Never have used a keyless chuck b4- need to change bit, how do I do this? thanks
hi this should be reletively easy hold the end black bit with the sivler bit holde coming out not the black bit next to the yellow case on drill you hold the black part thats at end of drill by where the bit goes into not the black bit near the trigger hope i explain this ok.
Hold this bit tight then put drill in reverse then press trigger a couple of times it might be tight but shouldnt be that tight it wont undo.
1 put in reverse
2 hold black plastic piece near where drill bit goes into
3 press trigger few times
4 this should undo it allowing you to put a bit in
make sure its in reverse else you will just tighten it up more let me know if you need further assistance ok
Mar 05, 2008 | Dewalt 18 Volt Compact Drill Kit
Chuck loosens
Chucks ARE meant to stay tight.
You also use drill to UNSCREW THINGS.
Nov 27, 2007 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Drills Logo
65 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
