Rheem parts manual ramb-030jaz
Part number manual
2 Suggested Answers
james3751
  • 614 Answers
SOURCE: I have a Rheem Model # RAMB-030JAZ that the fan
The unit has a fan relay that sometimes goes bad. Check to see of fan is hot or tryimg to start. Might be bad capacitor. Fan relay or relay boards are easy to change.Russ
Posted on Jul 31, 2009
Looking for correct system charge for Rheem RPGA-030jaz
The specs for unit should be on web site. U might also google the info.
Oct 23, 2015 | Cars & Trucks
I need a serial number for the flame sensor. I cannot locate handboodk
-Generally you have to call manufacturer with model and serial number.
http://waterheatertimer.org/Water-heater-manufacturers.html
-However, Rheem, AO Smith, and Bradford White manufacture most water heaters, and each has parts resources.
-AO and Bradford post their resources under manuals.
http://bradfordwhite.com/documentation
http://www.hotwater.com/resources/product-literature/
-While Rheem hides their parts lists on obscure link, hoping that you will call for a service recommendation.
Here is 2011 parts manual for Rheem
http://waterheatertimer.org/pdf/Rheem-Parts-Guide.pdf
Gene
Water Heater Timers Save Money
Mar 18, 2015 | Water Heaters
I have a Rheem RAMB-036JAZ compressor . I just had a preventive maintenance check-up with it . The technician cleaned out the unit and checked the freon and it had been running fine all summer until...
sounds like a bad run capacitor. Its the big round silver thing. You have to get the same micro Farad rating as that one. Easy to change its written on the cap Herm Com and fan. Just replace wires the same as they came off.
Jul 06, 2014 | Heating & Cooling
Rpnl-030jaz condenser fan not turning
if the fan does not run then it could be a bad motor or just the capacitor is bad. usually I check the capacitor first. it usually goes bad before the motor
Apr 14, 2014 | Rheem 2.5 Ton 13 Seer / Ruud Heat Pump...
Rheem power vent 2 flashes red led twice
Copy following link to identify gas control valve and download error code information by type of gas control, and possible service manual.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
If you have Honeywell gas control, then 2 flashes with three second interval can mean pressure switch has failed. And or related issues.
Scroll up on same page to find pressure switch heading among the troubleshoot links.
Or use Ctrl+F find feature on browser, and word search page for 'pressure'
Same page also has Rheem parts list 2010 so you can locate exact part number using model number that shows on label on side of tank.
Rheem does not post service manuals, but other companies do, and they can apply to Rheem (except for the FV system, which varies by manufacturer)
Best that you save product manual when possible because it will have important information including, parts warranty, error codes and parts list. Plus routine recommended maintenance that can prevent outages and error codes
Sep 06, 2012 | Rheem Water Heaters
Rheem condenser fan don't spin up under it'sown power.
If you have a multimeter that tests "uf" or "mfd" that is microfarads. That will test the capacitor. Turn off power to unit, touch top of cap with insulated screwdriver across terminals to discharge and remove fan and common. MARK WHICH WIRES GO WHERE. Or if no mfds on multimeter, amps×2650÷volts=mfd. Amp draw on fan wire off of cap times 2650 divided by the volts between common and fan on the cap. If cap is good it's likely the motor.
Apr 12, 2017 | Heating & Cooling
I have a rheem power vent 21vp75e-1 it ignites the burner for couple of seconds and shuts off and retry to ignite into a lock out I wire jump the vacuum switch and it works properly than i replace the...
Before calling service technician, read manual for troubleshooting and yearly maintenance requirements.
Open following links to identify same-similar product and download manual.
Once you have product showing on page, click 'specs-docs' tab to see use-and-care manual.
http://www.rheem.com/product.aspx?id=C24E3F52-A6A4-4BC7-AF5B-0DF23A7A0263
http://www.rheem.com/Products/tank_water_heaters/gas_water_heaters
http://globalimageserver.com/fetchDocument.aspx?id=c0471d58-5e59-4be6-96f7-68361b8fb515
Rheem site loads slow, and some manuals never load.
Typical power vent manual:
http://waterheatertimer.org/pdf/Rheem-power-vent-manual.pdf
I believe the 21VP is older and Rheem does not show older manuals, but manuals are generally generic enough to help greatly. Year of manufacture show as second and third digit of serial number.
Lockout condition requires service technician and part replacement, or call Rheem and have them send part.
I found one link that talks about FV lockout that may or may not pertain to your issue:
http://www.diychatroom.com/f7/rheem-hot-water-heater-pilot-burner-not-staying-lit-65755/
Apr 19, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
I am trying to determine the specs on my Rheem Criterion II lx2000 heating/AC unit unit installed in Sept 99, I blieve it was manufactured 2/5/99 based on AC Pump serial number 6263F259928697 Model RAMB...
rheems site is secure for dealers only but i can tell you. its a 3 ton unit 12 SEER R22 unit. The coil (rcga) is a 3 ton coil The AC is a 1999 and coil 1998. the # you have for the heater is accually just the honeywell gas valve. the model for the heater would be on the inside wall near the gas valve.
Sep 19, 2009 | Heating & Cooling
I have a Rheem Model # RAMB-030JAZ that the fan will not come on when the A/C is turned on and does not produce cold air. Is there a common electrical problem for this model that would prevent it from...
Jul 30, 2009 | Heating & Cooling
Heating & Cooling Logo
357 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
