Question about Dishwashers
Whirlpool dishwasher model DU810DWGU1 water remaining in washer
Water not draining
SOURCE: whirlpool dishwasher
I had the exact same problem with my Whirlpool Quiet Partner IV. I removed the lower arm, and a couple of components below that, and got to the filter/grinder (that thing that chops up and filters the recirculated water before it goes to the pump that feeds the arms). The filter was completely clogged. I used a knife to scrap away the foodstuffs, put everything back together and all worked excellent. Just goes to show you that you should rinse your plates before to place them in the dishwasher.
Posted on May 13, 2007
  • 351 Answers
SOURCE: Whirlpool dishwasher not draining
blockage in the drain hose somewhere
Posted on Mar 20, 2008
micromaster
  • 3614 Answers
SOURCE: dishwashing machine not fully draining (2 inches of water remain)
Following a cycle, a small pool of clean water inside the tub is typical. Excessive water means the pump isn't pumping water out properly, the drain hose isn't carrying it to the drain pipe, or the house's drain lines are backed up. If dirty water spews from the air gap, the drain line is kinked or clogged. Note: If you've recently installed a garbage disposer, be sure the knockout plug for the dishwasher was removed when the connection was made (see your disposer instructions).
Posted on Apr 22, 2008
rickzilla
  • 706 Answers
SOURCE: Dishwasher will not drain
Hello Tom_Simmers,
Here is a link with exploded views and parts lists for your dishwasher for reference however based on your description, have you made sure you don't a blockage in the check valve? That's part of the pump drain assembly. http://www.pcappliancerepair.com/model-display.php
You may also have a problem with the pump itself so the documentation on the website will help you evaluate that.
In many instances, its just a blockage of food byproducts inline with the drain system so chances are thats what you will find.. Good Luck on that.
Regards,
Rick
Posted on Dec 02, 2008
  • 1214 Answers
SOURCE: Whirlpool Quiet Wash Dishwasher will not drain water
You can get the manual from the Whirlpool website.
Go to the Customer Support, Owner Information, Manuals link and enter your model number. Your exact model is not listed, but any of those listed will be close enough.
Check that the drain line is not kinked in any way, leading to the disposal, and make sure the line is routed up to the top of the cabinet, just underneath the counter top. Otherwise water can flow back into the dishwasher from the sink.
Make sure all filter screens are clean.
You can probably find an exploded view breakdown on SearsPartsDirect.com
Posted on Jan 24, 2009
Is it normal for 2 inches of water to remain in space where filter container is positioned...whenever filter is removed water is in the compartment where filter rests
In my experience the lowest section of the washer has always retained some water about a cup or two. If the one way valve(check valve) in the drain hose has failed or residue trapped in it more water will drain back at the end of cycle. You can see from the image the volume of additional water that would be trapped in the hose that if the one way valve leaks; the water in the hose would leak back into the tub.
the drain hose is required to go above the drain connection to prevent back flow into the washer. the one way valve in the drain hose is required to prevent back flow into the tub in the event of a blocked drain.
I hope that this helps.
Check Valve Replacement part 8268375 Whirlpool Dishwasher Repair
In some washers the check valve is critical because the pump reverses during the normal cycle. The attached video is an example of the check valve replacement in a Whirlpool. I have found all washers are similar.
You can usually hear when the pump has emptied the tub by a change of pitch from the motor. If you quickly open the door and observe the remaining water level that is as low as I would expect.
Jan 05, 2016 | Dishwashers
My whirlpool dishwasher (GU980SCGB3)will not drain. Wash cycle works fine. Water will not drain when the cycle is finished.
Whirlpool Dishwasher Won't Drain - Model GU980SCGB3 ...
www.repairclinic.com/...Dishwasher/...-/Whirlpool-Dishwasher-won-t-dr...
My Orders. Login · Order History · My ... Whirlpool Dishwasher Won't Drain.GU980SCGB3 ... Dishwasher not draining, wont' start or not cleaning dishes properly? This video provides ... how to access... Show all parts for model GU980SCGB3 ...
Nov 04, 2015 | Whirlpool 24 in. GU980SCG Built-in...
How do I replace a check valve in Whirlpool dishwasher model #WDT710PAYM5
The drain check valve is in the first part on your drain hose, the part attached to the drain pump. You have to remove the dishwasher from the cabinet . you will see the drain hose on the left side of the dishwasher. It is a whitish opaque plastic tube. Detach it from the pump and from the drain extension, a pan may be needed to catch remaining water. Carefully remove the loop from the plastic fill channel. Reinstall in the reverse order
Feb 08, 2015 | Whirlpool Dishwashers
Whirlpool dishwasher model du810dwgu1 Dishwasher door won't latch
Either door latch is broken or the springs are too tight
Need to check the actual parts.
For door latch see items 9 and 10 in this diagram
http://www.appliancepartspros.com/frame-console-parts-for-whirlpool-du810dwgu1.html
For spring location and adjustment see item 28 in this diagramhttp://www.appliancepartspros.com/tub-assembly-parts-for-whirlpool-du810dwgu1.html
Apr 02, 2014 | Dishwashers
The unit runs through cycle fine, but ends with water remaining in the bottom, that has not been drained and dishes are covered with soap residue.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Dec 16, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
The water used to completely drain out of the whirlpool dishwasher after the last rinse cycle. now water remains in the bottom. Also noticing decreased flow when actually draining into the garbage disposal...
Pumps. There are 2 pumps in most dishwashers. The drain pump,( which describes itself -it pumps the water out of the machine.)
The recirculating pump which forces the water at high pressure through the spray nozzles and arms. (This is how the cleaning action is performed)
These pump may either leak, or burn out. Either way, the only solution is replacement.
Mar 09, 2010 | Whirlpool 24 in. ADG6340iX Built-in...
We have a Whirlpool Gold Quiet Partner GU980SCGZ0 model. When rinse cycle is over the water only trickles out when draining. We checked the drain and it is not plugged. Water remains sitting in bottom of...
I took the check valve assembly off the bottom of the pump assembly and there was a big chunk of string balled up in the line which created a plug against the screen when trying to drain.Works great now!
Feb 15, 2010 | Whirlpool Dishwashers
Dish Washer retains the water without draining....
the drain pump is fairly easy to replace. it locks into place beside the sump and motor. push tab in and rotate pump to pull out. you will lose water so have a towel handy. inspect drain hose for restrictions or kinks.
Jun 25, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
PORTABLE WASHER LCE4332PQ1
did you fix this? i have the same problem.
Apr 06, 2009 | Whirlpool LCE4332P Top Load Washer
Dishwashers Logo
79 people viewed this question
Top Dishwashers Experts
Owen Barnes
