Question about Magnavox MDR515hf7 Player
Magnavox mdr515h/f7 will not display video or audio. Was working fine before today.
No video display or audio
After reading all the above I took my cover off and found the little fuse. I removed it and it tested ok. I had called Magnavox and they told me there is no fuse or anything like that. I took one last look before throwing it in the trash and there on the circuit board is a little button marked reset. I pushed it and now it works again. So there is both a fuse and a reset button.
Posted on Nov 30, 2012
  • swells32
    swells32 Nov 30, 2012
  •  Rebecca Willey
    Rebecca Willey Feb 28, 2014
    I am *SO* grateful for your post, I had opened the cover and checked the fuse, which was fine, so I'd closed it up and was going to let it sit overnight unplugged. I was certain I'd need to replace it! Then I found your post, opened it up again, found the tiny black "reset" button, pressed it, plugged it in and presto, it's alive!!! I am so happy.
4 Suggested Answers
Demonic-2011
  • 467 Answers
SOURCE: MDR515h/f7 Dead....Think it is fuse?
You can replace the fuse (if the unit is not under any warranty) by carefully opening the top cover - the fuse is a small glass tube in the power supply (near where the cord connects) check its rating and voltage (the replacement MUST match the original). You should be able to reach this easily without further disassembly of the unit.
If replacing this inexpensive part does not restore any power to your unit, then you have a faulty/defective power supply circuit - this should really be tackled in a fully equipped workshop with adequate facilities by a qualified technician; it is not meant for end-users to repair when it fails due to the potential dangers involved. Experience suggests in many cases a dead unit is not just a blown fuse, but a switchmode power supply failure.
Try replacing the fuse first - then consider submitting unit to a service centre for a quote, then you can decide afterwards if it's economical/worthwhile repairing.
Posted on Mar 21, 2011
Demonic-2011
  • 467 Answers
SOURCE: 3 month old magnavox mdr515h/f7 is dead. It may be
If it is under warranty, submit to an authorised service centre for a warranty repair - at virtually zero cost to you, since its power supply has obviously failed (take advantage of the warranty if you can, this way you can have it fixed quickly as well as virtually no cost). Unfortunately, the power supply is not a repairable item in every case, so you may have a board replaced. Here's hoping you do have a warranty on this one - it is not a cheap repair!
Fingers crossed if it is only 3 months old from brand new - that you get a working unit out of this.
Testimonial: "I am taking your advice, hope it will be repaired under the warranty. Thanks for the speedy advice!"
gopakumarg43
  • 74383 Answers
SOURCE: Does Magnavox mdv 2100/F7 dvd player have front panel display
Hello
This DVD player has no front panel display. Its front panel have ony two LED light indications, out of which, one is for power On indication and the other for p-scan [Progressive Scan] which will ight up when you select Progressive Scan function.
There are three push button switches, for Open/Close, Play & Stop.
It has only ON-Screen display system, which will be active only after connection the DVD player to tV. OK.
http://www.dataentryjobs.us/67948.html
Posted on Feb 02, 2012
Testimonial: "I can't believe with all that space in front that they didn't include a display panel for cd tracking. Since the unit plays cd's, why wouldn't it have a front display panel?"
How do I connect a Emerson TV to a Magnavox DVD?
You will need either an S-Video connector and two RCA connectors, or three RCA connectors. Use either the S-video connector or one RCA connector to connect the video, and use the two RCA connectors to connect LEFT and RIGHT audio. Done.
May 04, 2015 | Magnavox Televison & Video
Magnavox MDR537H/F7 -- DEAD no power
There is usually an internal fuse in all audio/video equipment and it will normally be a 20mm glass one positioned near the power supply or somewher close on the circuit board. There may be more than one so have a good check around. Be sure to replace with the same type and rating, no sticking kitchen foil across it to short it out, this illegal and DANGEROUS.
Jun 03, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
How do i get back to the initial setup menu on my magnavox MDR535H/F7
Try the following: press Menu and use the Up/Down arrows to navigate to the General Settings. Press OK and then use the same arrows to select Display. Click OK. Again using the Up/Down arrows select Language which should be the item at the top of the list. Make sure that English is highlighted or use the arrows again to select that. Then press OK. Press Menu again to exit the entire menu system. Unfortunately, you will need to navigate through each item from the initial setup individually if any other setting is part of the problem.
Magnavox has the manual for the MDR535H/F7 on their product support page: http://www.m4c.magnavox.com/cgi-bin/cpindex.pl?ctn=MDR535H/F7&hlt=Link_UserManuals&mid=Link_UserManuals&scy=US&slg=AEN . The direct link to the manual is http://download.m4c.magnavox.com/files/m/mdr535h_f7/mdr535h_f7_dfu_aen.pdf . See pages 108 and 109 for the Language setting.
I hope this helps.
Jun 24, 2017 | Magnavox Televison & Video
Don't know how set up my red yellow and white wires
Red = Right audio White = Left audio Yellow = Video
Dec 16, 2013 | Magnavox 32md311b/f7
Need magnavox dvr MDR515H/F7 code for URC WR7 universal remote
Check these codes. To know more, check this link.
0062 0004 0009 0456 0183 0226 0288 0008 0068 0075 0141
Feb 02, 2013 | Televison & Video
Magnavox MDR515H will not finalize
clean the OPU unit ( objetive LENS ) WITH disk cleaner. and fix it.
otherwise read your instr. manual go to the section troubleshooting
or download your instr. manual www. retrevo.com
If the problem persist you must go to the repair shop TV for fix it.
God bless you
Sep 30, 2012 | Magnavox MDR515H HDDVD Recorder
Mdr515h dosent work
Sounds like you need to do a "Hard Reboot" . . . Unplug the power cord and let it sit overnight, then plug it back in and it should work for you.
Jan 11, 2012 | Magnavox MDR515H HDDVD Recorder
I have a 19" magnavox
Do you have a digital converter box. If not, you need to get one to receive the analog channels.
Feb 06, 2011 | Televison & Video
Magnavox MDR515hf7 Player Logo
210 people viewed this question
Top Magnavox Televison & Video Experts
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
