Question about eMachines T5052 PC Desktop
Machine boot half way and then shut down and restart the booting process again
  • Majdi Othman
    Majdi Othman Feb 25, 2012
    Have you tried "Safe Mode" or "Last known good configuration" from advanced boot screed (F8) ?
  • eMachines Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU make sure its securely seated and has thermal grease might be getting to hot
another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the CPU central processing unit
hope this helps you
Posted on Feb 25, 2012
How to enable startup repair on windows 7
restart ur machine and while it is booting up press buttons F2 F4 F6 F8 F10 which will take you into the boot menu where u can select the boot order then insert ur repair disk into DVD drive then select DVD drive as primary boot option and hit enter the machine should restart again and boot up the repair process
Oct 31, 2016 | Computers & Internet
Hi, My Samsung R580 I3 JBB2-US keeps on shutting down. If I close the lid when I re-open it shuts down & I have to restart or it freezes and I have to force restart. Sometimes when I boot up it...
You can try go to Start - Control Panel - Power Options and check what you want computer do when you close the lid of your laptop. Fix that and restart laptop to apply the setting.
If the boot up not complete and restart by itself, in my opinon, there is something wrong on the start up process, could be hardware malfuctions, could be a software not compatible. Try check the start up process to see.(use Start- Run: msconfig)
If this happen often, you should call the Samsung customer services to find out. Laptop i3 should still under warranty.
Hope this will help.
Thanks for reading
Jul 20, 2011 | Samsung R580 Notebook
E- computer turn on then the screen says it was shut off improperly. say click to restart or wait.....did this it ran through its process and went to screen with no signal. ran it again under boot and...
sounds like your windows installation took a hit, try booting from the windows cd into the repair console and do a chkdsk /F /R; a fixboot and an fixmbr command. if ths doesn't work, try the repair option. You can also try to boot from a hirens boot disk and try the tools that come with that.
Jun 17, 2011 | E-Machines eMachines Desktop PC
Shutdown problems
I assume it is not shutting down. Do a complete reset, unplug computer from wall push power button in for 3-5 seconds, then plug it in and restart the machine. Then let it complete the boot up process then go to start and shut it down again see if it shuts down now. Thanks for the question hope this assists you. John
Jan 21, 2011 | Gateway DX482203 (PTGA002009) PC Desktop
When I boot my computer the monitor flashes the Windows XP logo then goes dark and the computer shuts down and then restarts itself and start the process all over again and again
Try starting it in safe mode, F8 during the boot process, this loads a windows shell, once active, run a system restore.
(Programmes - Accessories - System tools - System restore)
Choose a date prior to your problems.
Sep 12, 2010 | Kogi L7CH Monitor
When i shut the notebook down and tryed to load it back up it will not load it gets to windows is staring and then restarts the process
Hi there!
Your computer may have an error that is causing the computer to restart, Try this one, when you turn on the computer start pressing f8, then advance boot menu should come up, after that select, disable automatic restart then the computer will start booting to windows then it should display the error, if it still stays on the screen q/o showing anything, do the f8 process again and this time select safemode.
Hope this helps!
Jun 01, 2010 | Computers & Internet
I have a Compaq Evo N610c laptop and when i turn it on it gets half way through the boot up process and then shuts down
Try restarting in safe mode by pressing F8 on start-up use system restore to go back to a date that your laptop worked
Jan 24, 2010 | HP Compaq Evo n610c Notebook
T23 Thinkpad turns off during boot after restart
My guess would be ;-
A power supply problem with the battery and/or power adapter
The most likely one.
The CPU is overheating and shutting down and if you wait a while and it will power it up again, it will then run for a while and shut down again.
This can be caused by a faulty fan (its not spinning and needs to be replaced) or the vents are clogged with dust (needs to be cleaned and you may need to remove the fan assembly to do this).
Jan 27, 2009 | IBM ThinkPad T23 2647 Notebook
Won't complete booting
Sounds like at the very least, the hard drive is. This is common when a file required by the OS is corrupted, and the OS tries to not damage data so it restarts or shuts down.
Jan 18, 2009 | HP Media Center PC 873n (P9875A#ABA) PC...
eMachines T5052  PC Desktop Logo
67 people viewed this question
Top eMachines Computers & Internet Experts
brian soufane
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
