Tix Clock not working
I recently bought a Tix Clock but can´t seem to make it work. I live in Europe and bought an adapter with the required specs (6v and 1000 ma) The clock lights up and shows the "Tix" word but the clock won´t start. I need help please!
SOURCE: bose clock radio Awrc-1p
Call the US tech support line, they will talk you through it.
Posted on Sep 26, 2007
headstrong
  • 233 Answers
SOURCE: Orange and green light flash
The flashing battery light is an indication that the system is attempting to charge the battery. The orange light indicates a problem charging one of the battery cells. This usually means that the battery either needs to be recalibrated or replaced. To recalibrate the battery just use the system until the battery is dead, then recharge and repeat the process twice, after which time the battery should be recalibrated. If this doesn’t fix the flashing orange light then the battery may need to be replaced.
hope this helps
Posted on Jan 07, 2008
informatica
  • 1114 Answers
SOURCE: 12:33 keeps flashing
Hi - You can download the manual from the link underlined in blue below:
moz-screenshot.jpgRCA RP5420
Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Jul 31, 2008
SOURCE: Sony Liv Clock Radio, Cd Player
I have a sony dream machine ICF-C18 and had day light saving time and cannot change the time
Please help
Posted on Nov 02, 2008
SOURCE: instructions for setting Sharp Atomic clock
Remove backup battaries
and re insert new/or-goodbattaries in the battarey comportmane as correct +/- sign.
show the time if its start from 12:00AM
press startbutton -get time adjust mode -select correct Time and press set to mnormal mode.
Posted on Nov 20, 2008
Cheats for unlimeted tix
you gotta wait when you log out in log in you will recive 10 tix everyday but it might be slow and it works
Jul 16, 2014 | roblox.com
My ipad not charging but the usb cable and the ac adapter is working
You can check to insure your ac adapter is working by substituting other adapters and cables, and see if they work with other devices.
Remember that iPads require more current than is available from most USB adapters. You will typically need 2.3 amps of power at 5 volts. If you have an adapter that will only put out 1 amp or less, your iPad will not charge because your adapter is under powered.
Jan 27, 2014 | Apple iPad 3 Tablet 32GB Black WI-FI 4G...
Hello, I recently bought a 1990 Toyota Celica 4cyl 5spd manual. The clock and cigarette lighter worked when I bought it but days later they both stopped working, I have tried looking at the fuses but...
same thing with mine. except the clock only worked once. i took it out and bought another one out of a junkyard. these cars aren't easy to find in junkyards, mainly because they are invincible, but you could try checking around.
Jul 01, 2011 | 1990 Toyota Celica
The embroidery unit no longer registers on my artista 180 when I connect it. I borrowed a friends embroidery unit and it worked so i assume it not the 180 which is the problem. What should be my next move...
If you bought the embroidery unit with the machine, I would try to take it back to the place of purchase & ask for a sewing tech to check the machine & unit for you.
I recently had a similar issue with my machine-took it to a local bernina agent & within a week, it was back in my sewing room, at no cost to me. I hope this helps you, & yes I have a 180 with the embroidery unit like you mentioned
Jan 05, 2011 | Bernina Artista 180
NOKIA 1208 No network problem
you may contact the service provider.........
Feb 13, 2010 | Nokia 1208 Cellular Phone
Is my AC Adapter for HP Deskjet F380 out of order?
You can contact PRASHANT 9820930880.
I found this on the net while searching for the adapter. Placed the order just now. Not sure how genuine he is
we have hp all in one adapters model f/310/325/335/340/350/370/378/380/385/388/390/394 @400RS. CONTACT : PRASHANT 9820930880
Jan 05, 2010 | HP DeskJet F380 All-In-One Printer
Acer Aspire 3690-2970
I have traveled to Europe. Australia and China. As this is a laptop I believe your power supply is that often black box in the middle of the electric wire you plug into your laptop. I we operate on 110 volt 60 cycle electricity. The bulk of the rest of the world operates as 240 volts and mostly 50 cycles. The power supplies for laptop I used overseas indicated they operated from 110 - 240 volts and 50 to 60 cycles approximately (small print on the adapter). If your adapter does not handle 240 volt and 50 - 60 cycle requirement you may need to secure another before leaving. The real challenge is to have the right plug adapter for the country you are in. Our two and three prong plugs do not work anywhere else I've been without adapters excluding soem bathrooms for electric shavers only and some universal plugs I have seen installed in China on my last trip (but even in China they were rare). My friend bought two different versions of adapters I believe at Radio Shack - one was a small bag of adapters that covered all of Europe and more recently a single adapter with sliders that could adjust to all the separate adapters he purchased before. I had the experience of buying an adapter in China where I do not speak Mandarin -- pointing at a British adapter and drawing the US plug got me what I wanted however you may wish to solve this problem before you arrive in Europe. Assuming you purchase adapters before leaving the clerk at the store may be able to confirm the suitability of your power supply for general european operation, I tended to double check with the local hotel staff or friends keeping in mind that all counties and some areas can be different.
Dec 15, 2007 | Computers & Internet
50 people viewed this question
 Grubhead
Grubhead
