Question about Garden
Connections for cut-out switch - Garden
Need to put a ford taurus head light switch on a jeep truck
Why would you do this? If you must, your need the switch and wiring plug-in. Fashion some way to mount the switch, cut plug off Jeep harness and make new connections by stripping wires, making good mechanical connections, solder and tape.
Jun 08, 2015 | Ford Cars & Trucks
Dishwasher not finishing cycle
A10 4 + 6 Heating circuit Heating element, connections, module,
relay, pressure switch
A10 Open circuit in heating circuit.
• Check the circuit of the heating element (26 ohms).
• Check for an open circuit heater cut-out.
• Check pressure switch open circuit (connections 11-14).
• Check wiring and connections between module card, pressure switch and heater.
• If all above is OK, replace module card.
Sep 18, 2014 | Hotpoint 24 in. FDW60 Free-standing...
Where do i find an A/B speaker switch
It's probably not the switch. These models have a common problem with the solder connections between the switch pcb and display pcb going bad. You need to resolder these connections, and your problem should be solved.
Jun 17, 2013 | Sony STR-DE635 Receiver
DSP A 1092 keeps tripping when switched
try unplugging each set of leads 1 set at a time,and after each set of leads are unplugged switch it on as it may be a set of faulty leads,it sounds like the safety cut out is coming on and switching off the power to save your system blowing due to bad or broken phono leads or speaker cables.it could also be that you could have blown your output transisters or something else thats causing the saftey cut out to cut off the power,also make sure there are no loose connections inside your mains plug as this would cause the same thing.
Jan 06, 2013 | Audio Players & Recorders
Encore Premier 36 walk behind- safety switch connection problem
you can adjust the handle not the switch try and swapping the switch with the other side and see if the problem follows the switch
May 12, 2012 | Garden
Starts to spin then cuts out
Check the program controller for shutting off, check the motor for tripping off , possible door switch making it cut off - safety switch on the door.
If prograam controller , check for loose connections, if motor check if heating off, check capacitor .
Sep 29, 2010 | Electrolux EW1200i Front Load Washer /...
Will a 1993 ignition switch housing kit fit an 1986 liberty flhtc?Only difference i can see visually is in the type of key used. not sure of the wiring harness on bike yet,and will it line up?
As long as both switches have the same number of connections, they should work. I think they should have six connections on the switches. Earlier switches had only five and latter switches were electronic with a plug on them.
Apr 10, 2010 | Harley Davidson FLHTC Electra Glide...
Car won't start
should be a fuel cut off switch on drivers floor on door side.
Nov 09, 2009 | 2002 Hyundai Accent
I have a simple comfort 2000 thermostat and the fan will not cut off unless I cut the breaker off. The thermostat cuts the ac unit off and on but the fan will not go off. What could be the problem. I only...
Sounds like the Fan/Auto switch is not working or is out of the circuit. Do you have a Volt/Ohm meter to check the switch? Set the meter on Ohms on the lowest range, turn off the breaker, disconnect the leads from the switch, and put the probes on the connections to the switch. The reading will be near zero when you touch the leads to connections that are turned on by the switch. You can buy cheap meters at Harbor Freight ($5) or other discount places. If the switch is working, it has been bypassed somehow, or the wires are connected wrong. Did you recently install the thermostat?
Aug 21, 2009 | Heating & Cooling
I HAVE A 92 BUICK LESABRE BUT KEY IN SWITCH TURN SWITCH NO POWER GOING TO SWITCH SIDE OF STARTER BUT WHEN I TAKE A WIRE FROM HOT SIDE OF BATTERY TO SWITCH SIDE OF STARTER AND KEY IN SWITCH TURN ON CAR...
You have no power from the switch to the starter. Check all you wiring that goes through the fire wall and look for burnt connections or just bad connections.
Aug 05, 2009 | 1992 Buick LeSabre
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
