Question about Vacuums
My DC07 animal vacuum canister won't stay closed.
  • KimM79 Feb 28, 2012
    It actually ended up being that the cyclone assembly was so dusty that the clip was not retracting enough to catch the bin lid. All fixed. Thanks for the tips!
  • 4 Answers
Maybe the clip is just bent
Posted on Feb 26, 2012
Dysonteam
  • 167 Answers
SOURCE: Dyson DC07 - broken 'Contact Head' release clip
Hi Wombat64
We noticed you are having difficulties with your Dyson vacuum cleaner. We think we can help, simply call our Customer service team for free on 0800 298 0298 between 7am - 10pm, 7 days a week.
We look forward to hearing from you.
Darran
Dyson Customer Service
Posted on Jul 16, 2008
SOURCE: Dyson Animal dc07 -- change belt
Read the manual -- available on the Dyson web site. Brushbar not spinning • Ensure brush control is set on carpets mode. Note: brushbar will only spin when the handle is reclined.
Posted on Dec 28, 2008
SOURCE: I have a DC07 Animal Vacuum It works and sucks but
Make sure the setting is on carpet and not on bare floor. The brushes will not turn when it is on the bare floor setting.
Posted on Jun 27, 2009
  • 33 Answers
SOURCE: My DC07 dyson animal has no suction when i put it
If you've tried everything else and still just don't have suction, try this:
http://www.ehow.com/how_5870417_modify-dyson-prefilter-suction.html
Posted on Jan 26, 2010
VacuumRepair
  • 438 Answers
SOURCE: dyson dc07 animal\ no suction
There could be a few things that would cause your Dyson to have no suction. I will give you detailed step by step instructions along with pictures on how you can diagnose this.
Possible Problem #1. The first problem is extremely common. In fact, we probably see between 2-3 of these problems every week. It mostly happens after people take the bottom plate off the vacuum in order to clean the roller brush. What happens is when they reinstall the bottom plate, they put it on on incorrectly. It's actually very easy to do. When the bottom plate (soleplate) is installed wrong, there will be a gap between the bottom plate, and the agitator housing, or the purple tray the roller brush sits in. This will cause the soleplate to be a few inches higher off the ground then it should be, preventing the brushes from even hitting the carpet. This makes it seem to the user that vacuum has lost suction power because without the brushes hitting the carpet, the machine will not pick up very well on floors, but when they use the attachment hose there's plenty of suction power.
Here's a picture of the WRONG way to install the bottom plate. Notice the gap in between the two housings:
Here's another picture, that is the RIGHT way to install the soleplate:
I would say probably 6 times out of 10 this is the problem with the customers machine. If you checked the soleplate and it is installed correctly, move on to the second possible problem.
Possible Problem # 2. Turn the vacuum cleaner upside down so the brush roller is facing upwards. I found the easiest way to work on it is to put it on a counter top or work bench. On the left hand side behind the roller brush you should see a flexible transparent hose that goes from the motor to the agitator housing. This hose actually has a lot of strain on it when the vacuum cleaner is in the reclined position. When the first few series of Dyson DC07 models came out, they didn't make this hose long enough, so when the vacuum was in the reclined position, it would put too much stress on the hose, and cause the hose to actually crack, usually right where the end of the hose that goes into the agitator housing. Examine your hose and see if you have any visible cracks in this hose. If you need to you may just remove the entire hose assembly by pulling on it. It will easily come right out of the machine so you can inspect it better. Here's a picture of where the hose usually cracks:
This would also explain why the vacuum works fine when using the attachments, but not on the floors. The attachment hose uses a different suction channel, and when the machine is in the upright position, no suction goes through this hose. If you do find a crack in this hose, the this hose needs to be replaced. Here's a direct link to that hose on our GoVacuum website.
Dyson DC-07 & DC-14 Upright Replacement Internal Hose Part # 904219
Possible Problem #3. I would suspect that this may not be the problem, but if neither of the solutions above worked, then try this one. Dyson's in general are prone to clogging. There are a few clog ports throughout the vacuum cleaner that were added there due to Dyson prototypes becoming clogged at these points. Here are pictures of how and where to check for these clogs. Simply remove the suction port covers at both of these locations:
Possible Problem #4. If none of the above solutions worked for you, try this last one. The Dyson DC07 models use a clutch mechanism that stops the roller brush from spinning when changed from carpet mode to bare floor mode. This clutch mechanism is a notorious problem with all Dyson models, in fact they were such a problem that Dyson had to redesign the DC07 model to a non-clutch system. Even if yours is one of the newer ones that don't use a clutch, yours still has a belt inside. You can tell if your model uses a clutch or not by the shape of the roller brush. If your brush is a perfect cylinder shape, yours does NOT have a clutch. To check and see if the clutch or the belt have gone bad, first release the handle on the vacuum as if you were vacuuming carpets. Make sure the machine is set to carpet mode. Now while the handle has been released, turn the machine upside down and see if the brushes are spinning. If the brushes are spinning then turn the vacuum right side up and put the brushes on the floor. Can you still hear the brushes spinning when they are hitting the carpet? If yes, then this is not the problem. If the brushes however are NOT spinning, this indicates either your brush roll, clutch, or belt have gone bad.
If these solutions still didn't fix your problem, I'd be happy to try and help you further. Just use the Clarification Request, or comment section here on the Fixya repair page.
If this repair was helpful to you, please be sure to rate this repair as helpful by clicking the thumbs up icons in the top right hand corner of the repair. Thanks so much!
Chris J.
GoVacuum
Posted on Apr 04, 2010
DC07 Vacuum canister stuck. I won't release so I can empty it. Any suggestions?
You may have to press the release button and hold it depressed as you pry the canister loose.
Feb 13, 2015 | Dyson DC07 Animal Bagless Upright Cyclonic...
DYSON DC 17 CLIP THAT HOLDS CANISTER BROKE
some options for this are craigslist, search >dyson>broken>vaccuum>DC 07
Options 2> we used duck tape for a year and it worked fine, then when a broken DC07 was posted on craigslist we bought it for parts.
Jan 03, 2014 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson Canister Clip Replacement
You can purchase a replacement clear bin assembly for your DC25 directly from our online store - visit www.dyson.com and click 'Spares' (UK), or 'Parts' (US).
However, I'd encourage you to give our free customer Helpline a call, as we'll be able to confirm if this replacement is covered under the terms of our 5-year guarantee. You can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Feb 20, 2012 | Dyson DC25 Animal Bagless Upright Vacuum
Canister will not open on Dyson Dc 07 animal
Sorry to hear you're having difficulties with your DC07 Animal. If the bin base won't open when you pull the trigger, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you to identify the cause of the issue, and will be able to recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Aug 26, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
DC07 bin base wont open the catch seems to work, but the base is solid
Sorry to hear you're having difficulties with your DC07 Animal. If the bin base won't release at all, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Aug 19, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
My Dyson DC17 Animal Bagless Upright does not click to stay in an upright position. It works but the handle falls to the floor.
This is a common fault with the Dyson DC07 (and other Dysons) unfortunately the clip that holds the handle upright hs broken. It can be repaired, but will cost a reasonable amount to have done... I would just live with the problem and prop the vacuum cleaner against a wall when not in use.
Aug 27, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuum works but doesn't pickup dirt
there is a clog. check the hose, and the entry to the canister, check the holes inside the canister and check / clean your filter. also remove any threads/ animal hair from the brush so i can freely grab the carpet :)
Mar 26, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Canister problem
If it won't latch after cleaning the latch and making sure that everything is seated well, get in touch with Dyson, they're great about making things right with their vacuums.
Sep 18, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuums Logo
204 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
