Where are my scroll and number lock keys ? - Computers & Internet
  • 97 Answers
Go to Start --> Run--> type "OSK" in the box and press ok
It will open on screen keyboard. Here you can find num lock and scroll
Posted on Feb 25, 2012
2 Suggested Answers
SOURCE: no number lock or schroll lock Keys
Your laptop computer may have a numeric keypad integrated into the
keyboard. The keypad corresponds to the keypad of an extended keyboard.
• To type a number or symbol, press and hold <Fn> and press the desired
key.
• To enable the numeric keypad, press <Num Lk>. The 9 light indicates
that the keypad is active.
• To disable the numeric keypad, press <Num Lk> again.
numeric keypadSource(s): http://support.dell.com/support/edocs/systems/xlob/dtg/en/en_dtg.pdf
Above my scroll/# lock the lightbar is lit,and some letters produce #... i = 5 etc
Sounds like yo have the scroll lock or num lock turned on. If the scroll key is a colored key (the scroll lk lettering is blue) then you will have to Press and Hold the FN function key at the lower left portion of the keyboard then hit the scroll key to turn it off. When it is turned on if you press the letter i you get the number 5. If you press the letter O you get the number 6.
Notice that the numbers on the keys that have letters are a different color than the letters (blue most times). That means you have to Press and Hold the blue FN function key at the lower left portion of the keyboard then hit the key with the same color if you want the colored representation to happen.
Some laptops will use a Square Box instead of the blue colors on the keys. In that case you have to press and hold the key a the lower left portion of the keyboard that has the square box, then hit the key you want.
Jun 03, 2012 | HP Compaq Presario C500t Notebook
There 3 lights on the right top side of keyboard - one is capital lock -one is number lock- what is the third one? the light is on and I don't know what to hit ti turn it off.. thanks
The third one is probably Scroll lock. On your keyboard you should see a key labels Scroll Lock or it may be abbreviated. The key may also have the same symbol as the light. You turn Scroll lock on and off the same way as turning Num Lock on and off. Usually involves using the FN key + Scroll Lock.
Mar 12, 2011 | Compaq Keyboard
There are three lights on the upper right hand side of the keyboard. I know number lock and caps lock, what is the third light and what keys did i hit that made it go on? How do I turn it off?
The third light on your keyboard is normally the scroll lock, the key to enable/disable this function is the Scroll Lock key which is located above the Home key.
Mar 03, 2011 | GE Power Keyboard (97798)
On the computer keyboard by nextech is there suppose to be keyboard lights and if so how are they turned on
Hi
The usual lights for a keyoard are the 3 above the number pad. they will be labelled to correspond with the following keys:
- CAPS Lock
- NUMBER Lock
- SCROLL Lock
When they are pressed once the light will go on, meaning that function key is active. So if the CAPS Lock key was pressed and the light is on, then any letter key (A to Z) you press appear as a capital in documents. Press CAPS Lock again and the light goes out and the letter will type lower case.
The NUMBER LOCK is for the keypad to the right (not the number across the top and above the letters). This function ensures the numbers will appear instead of their alternate function, such cursor and Page UP/down, Home, and End.
SCROLL Lock is not used much, but it can be used in Excel to hold the current selection. For example, you want scroll about the sheet using the cursor keys, but want to keep the current cell selected. So with SROLL lock active, when you use the cursor key's, the sheet will move in the direction you want while leaving the selected cell selected. Try it and you'll see what I mean.
I hope this helps.
Mar 01, 2011 | Lenovo Keyboard
Text has changed to numbers
The keyboard on this model and lots of others have a built in 10 key number pad that is activated by a key combination. In this case num lock activated by pressing Fn+Scroll. The Fn key is to the right of the left Ctrl key and the Scroll key is in the top row upper right hand corner and doubles as the num lock key when the Fn key is pressed at the same time.
Nov 14, 2010 | Compaq Presario 700 470024-192 Notebook
Keypad numbers are locked on, how do i unlock??
Boot to your Bios and look in advanced for num lock and disable.
or
go to run in the start menu.
typ: regedit.
Go to: HKEY_USERS\.Default\Control Panel\Keyboard
Then String value- InitialKeyboardIndicators right click click modify then choose a number below.
Explaination numbers.
0= Truns Off, Num Lock, Caps Lock, Scroll Lock
1= Turns On Caps Lock,
2= Turns ON Num Lock,
3= Turns On Caps Lock, and Num Lock
4= Turns ON Scroll Lock
5= Turns on Caps Lock, and Scroll Lock
6= Turns On Num Lock, and Scroll Lock
7= Turns On Caps Lock, Num Lock, and Scroll Lock
Hope this helps.
Feb 07, 2010 | Acer TravelMate 4230-6499 Notebook
On my hp 6735b laptop I would like to turn off the scroll zone on the touch pad if possible.
You don't specify what system are you using. In Windows you have to go to Control Panel, Mouse and Pointing Device properties, and find your touchpad options there, including the scroll areas.
If it's not there, chances are there is a separate application, either in Control Panel, or in the Start Menu, for setting up the touchpad. You can also look in the system tray beside the clock - often there's an icon there for the pointing device.
Nov 25, 2009 | HP Compaq 6735b Notebook
How to get rid of numberlock in ibm thinkpad t30
Hi Ritadeng,
On the Thinkpad T30, the number lock key can be turned on or off by pressing the shift-key and the scroll-lock key. The scroll lock button is found at the top of the keyboard between the PrtSc button and the Pause button.
You should see the light with the arrow and the number 1 inside (just above the F7 key) turn on and off when you press this.
Hope this helps!
David
Nov 18, 2008 | IBM ThinkPad T30 2366 Notebook
What are the hot keys to switch between PC's?
You might try Scroll Lock twice followed by Up and Down Aerrows
Scroll Lock + Scroll Lock + Up or #1 or #2... and Scroll Lock + Scroll Lock + Down or #1 or #2 to switch b/w comps
Feb 15, 2007 | IC Intracom 156752 4-port KVM Switch
Computers & Internet Logo
David Payne
David Payne
