Question about Jenn-Air Jenn Air 22 Cu. Ft. Side by Side Counter depth Refrigerator, JCD2290HE
Refrigerator Compartment The refrigerator compartment has no cold airflow comming in from freezer section. I have taken apart control panel to check bellows control and freezer temp control for loose/broken connection. None found. Cleaned and checked rear of unit, comppressor etc. looks OK. Checked Freezer some frost on evaporator. Freezer working. Took out all perishables from refrig, to prevent spoilage (10/27/08). Woke up this morning (10/28/08) to find refrig recieving cold air from freezer. Could active defrost part in refrig compartment be going bad? This has been going on for about a week.
2 Suggested Answers
  • 464 Answers
SOURCE: Jenn Air JCD2289AEB coil in freezer compartment is
Sounds like you need to replace the adaptive defrost which is #13 in the breakdown I have in250cluded here. Part number is 61003990.
Posted on Nov 11, 2009
heatman101
  • 43501 Answers
SOURCE: I have a Jenn-Aire side-by-side
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 27, 2010
Hotpoint hsm25gfta sa
Check for a device called a damper in the refrigerator compartment. It controls how much cold air from the freezer is sent to the refrigerator. In my recent experience with a bad damper in a GE side by side, the damper door broke and the refrigerator got too cold. The damper door could be broken or the motor failed and left the door closed. If this happens, the refrigerator compartment will not get enough cold air from the freezer and run warmer than normal. Check the appliance parts web sites for a breakdown of you model. You may find it's a major disassembly to get to the control. What I did was remove the bad part and control the airflow from the freezer with a partial blockage until I got a new part and the time to repair it.
Apr 17, 2014 | Refrigerators
The freezer is cold but the lower section is warm.
If your freezer section has a knob that says "Colder" then set it to the left instead of
to "Colder"
Many people mistake this for a cold control but it only closes off airflow to
the lower compartment from the freezer section.
The freezer supplies cold air to the lower compartment. You may also want to see if the vent to the lower compartment is
blocked with ice. (The vent duct is the plastic duct in the freezer compartment).
hope this helps.
Jul 31, 2011 | Refrigerators
Bottom not cool at all
Greetings,
The first thing to check is are all the fans running? there is one in the freezer and usually one in the rear compressor compartment...the next thing to check if fans are operating is: remove rear freezer panel and see if ice or frost is blocking the air thru the freezer coil...if there is ice blocking the airflow. defrost the coil using a hair dryer.. the fresh food section gets cold air from the freezer..its blown over into top of refrigeration via a fan...it goes thru a baffle into refrigerator...this baffle sometimes will not open...This is one place you check for air coming into refrigerator...so, check here also before you take it apart. there should be a noticable amount of airflow....if not, remove the cover and work a small wooden dowel or skewer into the slot and open the vent..this will allow air to go into refrig section...the skewer can be left in there to keep it working if this is it...getting back to a frosted evap...if it is froze up..there is a derfost problem and defrosting will give you temp service until you can get it repaired......Bruce Denton
Jan 09, 2011 | Whirlpool ED2SHAXM Side by Side...
Refrigerator less than two months old. Freezer side fine refrigerator side stopped working altogether. All food ruined. Who should I contact. purchased from Home Depot.
This is a very common issue, If the freezer compartment is cold and making ice the
problem is simply airflow from the freezer into the refrigerated section.
Typically when one senses the refrigerator is warm they max out the settings
on both dials the thermostat with its 1-10 settings as well as off for the compressor.
This controls the compressor and temperature.
The additional setting or dial is for colder freezer or refrigerator as well , However
it simply opens or closes a flapper door between the freezer and refrigerator boxes.
When that dial or setting is maxed , it closes and makes the freezer colder, yet leaves the refrigerated section starved for sufficient airflow to maintain a cold box in the refrigerated section.
Just set the dial that does not turn the compressor off to the middle setting.
One can leave the thermostat that does control the compressor in the max setting , just not the colder freezer setting, If you notice colder isnt colder refrigerator, Its actually colder freezer, A common issue found on 25% of all refrigerator calls a simple setting adjustment.
Its easy to think that maxing out the settings makes for a colder refrigerator, it doesnt, it makes a colder freezer and warm rerigeration section.
If a freezer is making ice, theres nothing wrong with the unit other than airflow setting.
Add a comment
Dec 24, 2010 | Maytag Refrigerators
My GE TFX30PP is constantly running and doesn't turn off. The freezer is very cold but the frig side isn't cold enough. A repair guy put in a new "cold contol" sensor but it didn't help.
I would also clesan the condenser coils off.
Add a comment
Dec 24, 2010 | GE Profile Performance 29.8 cu. ft....
Left door open while cleaning out refrigerator and top unit shut off freezer is still on what should I do
The fresh food compartment is cooled by air being blown from the freezer compartment into the fresh food compartment.
There is a panel, or door if you will, that separates the freezer and fresh food compartments. The freezer temp control determines how much cold air is allowed to escape into the fresh food compartment by opening or closing this panel.
In your case, the door must be stuck all the way open, allowing all the cold air to be diverted into the fresh food compartment. The compressor cycle is controlled by the thermostat in the fresh food compartment and thus 'short cycles' because the fresh food compartment acheives normal temperature while the freezer is relativel warm.
If the panel is restricted from moving (stuck in the extreme open position, for example), the fresh food compartment will get VERY cold while the freezer will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is diverting all the cold air from the freezer into the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel/door/flap itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Hope this was helpful. Good Luck.
Aug 27, 2009 | Sub-Zero 650 / O Bottom Freezer...
I have water collecting on the iside of the refrigerator compartment. It is leaking through the air vent openings from the freezer compartment.
I am going to assume you have a defrost condensate blockage in the rear of the freezer and behind the rear panel where the evaporator dreains condensate after each defros. Please correct me if I am wrong.
The answer to finding the cause of the leak is where we need to begin. Most start in the freezer section behind the rear panel where the defrost condensate is drained during defrost. Sometimes the drain hole freezes over and the water drains down into the freezer creating a large area of frozen water. Other times i happens as the water leaves the drain in the freezer and follows its path to the pan below your refrigerator to re evaporate into the air inside your home. If leaking inside the fresh food compartment then the cup behind the control panel may be over flowing and leaking down the back wall of the refrigerator and will need to be taken apart and cleaned to allow the water to continue down to the pan below the refrigerator. Sludge and dust or even ice may be blocking this line. Below is a link to a page that may help you resolve and fix this. If you have more questions feel free to let me know. appliancepartsse@yahoo.com Thanks, Sea Breeze
click link below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Aug 27, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerator compartment freezing
Experience tells me the design should maintain 40 -34 degrees in the refrigerator section when the freezer is between 0 and -10 You might check this if you have a thermometer for the job, and adjust the thermostat accordingly. Your unit may also have an airflow control (I didn't research) to adjust the refrigerator independent of the freezer.
May 25, 2009 | Whirlpool GB9SHDXPS Stainless Steel Bottom...
Kenmore elite 596 73503201 no cooling in top compartment
if the freezer is getting cold the problem is due to the cold air from the freezer not getting into the refrigerator. There are several things that can cause this problem. The coils in the freezer icing up and not defrosting properly is one of the things that can cause the refrigerator not to get cold enough. Another problem is the fan that blows the cold air from the freezer compartment into the refrigerator, not working. When the compressor is running open the refrigerator's door and push the switch that makes the light go out. You should hear the fan blowing the cold air from the freezer into the refrigerator, when this switch is pushed in. If the fan is working then you will need to find what is blocking the air flow. Iced up coils are a common problem. The icing problem can be due to a defective defrost timer or something defective in the defrost circuit. Click here for more information. Check for these problems and let me know what you have found.
REFRIGERATOR TROUBLESHOOTING
#1 Refrigerator side getting warm Freezer still cold
Evaporator fan motor not running.
Defective defrost timer. See Defrost Diagnosis Procedure
Defrost heater defective. See Defrost Diagnosis Procedure
Defrost thermostat defective. See Defrost Diagnosis Procedure
Airflow blocked from freezer compartment.
Freezer control turned to "coldest" setting blocking air flow to refrigerator side. On most refrigerator/freezers, the freezer control closes a baffle when turned to coldest setting, and this blocks off the air flow to the fresh food compartment.
Fan blade broken.
Defective door switch on older models.
Light staying on with door closed.
2 Refrigerator & freezer compartments both are getting warm
Make sure refrigerator is plugged in and has power.
Condenser fan motor on bottom under refrigerator not running.
Condenser coil clogged.
Defective defrost heater. See Defrost Diagnosis Procedure
Defective defrost thermostat. See Defrost Diagnosis Procedure
Cold control defective.
Compressor overload defective.
Compressor relay defective.
Compressor defective.
Low on refrigerant. #3 Freezer compartment getting hot.
Defrost timer stuck in defrost cycle.(replace)
Defrost thermostat stuck.(replace)
Ice maker stuck in harvest cycle
Light staying on with door closed. 4 Ice maker not making ice
Defective inlet water valve.
Freezer temperature not cold enough. (see problem # 2 & 3 above)
Defective thermostat in ice maker.
Defective drive motor.
Water inlet tube clogged with ice.
Defective module in newer style icemaker. 5 Refrigerator sweating around door edges
Door gaskets leaking air.
Defective case heaters.
Energy saver switch not set to reduce exterior moisture
also if require more help click the link http://www.applianceaid.com/refrigerator.html please do rate the solution .thanks in advance.thank you for using fixya.
Mar 27, 2009 | Refrigerators
Top Freezer section working Bottom Refrigerator not getting cold
I have a side by side jenn-air refrigerator, the freezer compartment working fine and making ice like it should, however the refrigerator compartmant is not cooling, no cold air is felt, I need advise.
Sep 28, 2008 | LG LRTC19314ST Top Freezer Refrigerator
Jenn-Air Jenn Air 22 Cu. Ft. Side by Side Counter depth Refrigerator, JCD2290HE Logo
24 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
