Question about Exceed-RC RC Truck
Pull start is not turning engine every pull it does catch once in awhile
Pull starter is new it feels like something is not hooked up right
Clean the one way bearing in the pull start....
have to take pull start off and clean the bearing inside the recoil...
Posted on Jun 21, 2013
How can you tell when the starter is going bad or is bad?
Click or grinding when you try to start car
Sep 27, 2014 | Cars & Trucks
I have a 96 cadillac deville 4.6 northstar engine. I have changed the starter three times already. Once it was cracked. Third time a new one was put in, it wouldn't start and and there was smoke coming...
You may have ground issue , to much current , high resistance . Do you know how to use a DVOM - digital volt ohm meter ? Do voltage drop testing on the starter electrical circuit . Watch these videos .
Starter Voltage Drop
How to voltage drop test starter motor circuit
Apr 29, 2017 | Cars & Trucks
Pull cord for starter is not catching?
There are starter pawls that catch the flywheel when the rope is pulled. They are plastic. You will need to disassemble the unit and remove the starter assembly to inspect the pawls.
Nov 11, 2012 | Ryobi Garden
DO I NEED SPECIAL TOOL TO REFIT COIL SPRING WHICH CAME OUT WHEN FITTING STARTER PULL CORD
There are special tools made for this job, however not needed for most jobs (makes easier). Clean the spring and lube slightly with silicone spray or light oil. Catch the end of the spring that would be the outer end onto slot or pin and slowly spiral the coil into place holding down coils as you turn(dont try to coil the spring then drop it in, take your time as you wind and maybe ask a freind to lend a third hand if your fingers get tired, once you start you cant stop). The inner part of the coil has a bent hook that will catch on the inner portion of the pull rewind. Lood at how the rewind catches this hook by turning the rewind in the direction that it turns when you pull the rope. When you pull the rope it winds the spring. If you put the spring in backwards the rewind spring will not catch. Once you got the spring in place, turn the rewind in the direction that it turns when you pull the rope until it stops, then release one turn and insert rope thru guide and into spool to tie knot. Slowly let rewing pull in new rope. Good luck
Aug 23, 2011 | Electrical Supplies
My battery acts dead when ever i try to start the vehicle. the battery is new and the starter is new. once it starts it trys to stall out. i've had to jump start it recently and now it starts right away...
Your description is not very clear--do you mean that the starter does not turn the engine over at times or that the engine turns over but does not "catch"? Or, does nothing happen at all when you turn the key?
In any case, it sounds as though you have a loose or damaged cable or a corroded connection at the battery or a ground.
Nov 26, 2010 | 2000 GMC Yukon XL
Won't start just clicks I have a new battery and attenltor
The just clicks is aways a bad connection causing low voltage at the starter, But the starter can be bad or ( hung in) Turn the engine by hand to se that it will turn if you hear a loud click when you turn the engine the starter ws hung, The starter being loose or worn out will let the gear climb up on a tooth of the flywheel. once cleared it may start right up. if there's alot of gear noise then the starter and or the ring gear (flex plate) may be damaged and need to be replaced. Low voltage is most ofte the cause, The old batery being bad or the new one being low, ( not charged) is most often the cause. After turning the engine, With jumper cables connected to another running car try again, Try hooking the ground cable of the jumper cables right to the engine block or case of the starter. if ti starts this way and not after you unhook the cables you have a cable connection from the battery to the block or the positive cable where it hooks to the starter bad
Jun 12, 2010 | 1997 Chevrolet Blazer
1995 toyota 4 runner starting problem once in awhile
Is the starter turning over the engine when it wont start or is nothing happening at all?
I might have your solution if I have more details.
If the engine is turning over but not starting then switch on the ignition and push it to start.If it starts you probably need a new ignition switch.
Please get back to me .Thanks
Aug 04, 2009 | 1998 Toyota Corolla
Cranks fine, won't "catch"
From what u describe, I believe u have a starter and possibly a flywheel problem. When u turn the key to start the car, the starter gear engages w/ the flywheel, turning the flywheel, which turns the engine over. It sounds like the teeth of the flywheel and starter are worn, (they should mesh together smoothly) which would make the grinding noise u describe. If this is the case, the flywheel and starter would need to be replaced, and its a labor intensive job, as engine and trans. have to be separated to remove/install the flywheel. The rrrrrrr sound could be the starter gear spinning but not engaging. The starter gear extends on a shaft, then engages the flywheel. It is possible the gear isn't moving forward on the shaft, just spinning w/out engaging, making the rrr sound. So, I would recommend u remove the starter and have it tested (many parts stores will do this for free) and check the teeth on the gear to see if they are worn or broken. U will also be able to see a portion of the flywheel after the starter is removed, and u should check the teeth on it also. Let me know what u find, hopefully it's just a starter problem, and the flywheel is ok.
Dec 30, 2008 | 1991 Buick Skylark
Exceed-RC RC Truck Logo
83 people viewed this question
Top Exceed-RC Toys Experts
jasiel murphy
Tejodhar Atreya...
Tejodhar Atreya...
Tom Chichester
Are you an Exceed-RC Toy Expert? Answer questions, earn points and help others
