Question about Refrigerators
I have a GE Profile water cooler w/ bottom fridge. Mod#GXCF25FBS. The cold side would not release water and the room temp. was comimg out slowly. I found that the inside tank area was frozen. I turned it off to defrost and also drianed the whole system from the back valve. I found alot of sediment. I then put a new bottle in and the cold side still doesn't work. ??
HVACRH20
  • 237 Answers
SOURCE: GE refridgerator
If the unit has an ice maker or water dispensor, etc. there's always a chance a connection is loose or a valve is leaking by. If no other water is hooked up to the refer, then the defrost cycle water that should drain down to the bottom underneath pan is what is likely. You may have to take the inside rear panels off to see if the drain line is plugged up, that would allow water from the defrosting of the coils to drip inside the fridge vice outside like it should.
Posted on Jan 02, 2007
Bgillespie
  • 89 Answers
SOURCE: GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
Wow, so you dropped some money into it, eh? I would take a look at the damper door asslb(DIFFUSER). located at the very top left of your refrigerator section in back. It has a motorized door that opens and close's and it may be stuck open. More than likely it is broken and needs to be replaced. GOODLUCK!!!!
FYI: All your cold air in your refrigerator comes from your freezer!
Posted on Dec 17, 2007
MNTECH
  • 1543 Answers
SOURCE: GE TFX20JR side by side/water leaks out freezer during defrost
Yes, you are correct, that is a drain. Use a turkey baster with hot (not boiling) water to flush out the drain tube until water will flow out into the drain pan under the refrig. (where the air blown over it will cause it to evaporate)
Posted on Jan 06, 2009
peyton32034
  • 410 Answers
SOURCE: GE TFX27PF refrigerator and freezer still not getting cold enough
the partial frost pattern is an indication of low refrigerant, restriction or bad compressor. if the unit is under 5 years old this repair will probably be under warranty thru GE. if out of warranty then you are looking in most cases between 200-500 dollars for repair. good luck Thanx peyton
Posted on Jan 30, 2009
tborn6
  • 700 Answers
SOURCE: kitchenaid side by side too cold. Freezes everything.
the damper motor on the refrigerator portion is not working properly
Posted on Apr 04, 2009
I HAVE A 21 YEAR OLD GE FRIG SIDE BY SIDE MOD. # TFX27PFSA. HOW MUCH AIRFLOW SHOULD BE COMING INTO THE FRIDGE ? FREEZER IS 10 DEG. & FRIDGE IS 60 DEG. IM NOT GETTING ENOUGH COLD AIR TO FRIDGE & EVAP COILS...
You are correct -Temps not low enough and you have been thorough in checking things out. About the only thing I can think of now is to make sure that the condenser coils underneath are perfectly clean to promote max efficiency. If clean, and we know your compressor is running after all these years You may be, yipes, low on refrigerant. I am sure you have thought of that but did not really want to deal with it - don't blame you. If you want to pursue that venue it is a PIA but can be done, CAREFULLY because the freon level on refrigerators is a critical parameter, not like a room or car AC. If wanna try relist your question as DIY refrigerator charging.
Sep 02, 2017 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Water Cooler Cold Water does not come out, Why?
It works like a fridge or ac. When its charge gets low it can't cool. It will cycle on and off as freon goes around the circuit. Must be leaking around seals or crack in line. A good ac man could check its pressure to determine. Also, thermostat could be going bad, I would check that as well.
Feb 17, 2013 | GE Profile PXCF22RBS Hot and Cold Water...
My GE Profile side by side fridge freeze the food in the bottom draw. I have set the temp to 43F but keep the fridge at 34 or colder. It frooze the water lines and tank in the fridge several times. What am...
You probably have a sensor issues there are two one for the freezer one for the frig. Check your freezer temp it should be at 0 degress at manufactor setting. If the temp is below -10 you freezer sensor is bad. Otherwise your frig sensor is bad. CHECK FREEZER FIRST!!!
May 27, 2011 | GE Profile 25.5 Cu. Ft. Side-by-Side...
Inside fridge is cooler then usual,water on door suddenly not working
need to adjust cold control to a warmer tempt to prevent freezing . this will fix the water not working. if it will not adjust then control will need to be replaced .. mm .
Apr 04, 2010 | GE Profile PSW26P Stainless Steel Side by...
Need owner manual for POLAR water cooler with fridge
how do i set the thermostat on my polar water dispenser.model#PWD335-
Sep 25, 2009 | Kitchen Appliances - Others
GE Profile Side by Side is getting too cold on the fridge side.
the dampener door in the fresh food is more then likely broke . allowing air in to the fresh food.
Jun 06, 2017 | GE PSS25NGNBB Side by Side Refrigerator
SAMSUNG SIDE BY SIDE FRIDGE FREEZER
these appliances are a pain in the butt. fault with water dispensor is oprob that the water bottle at bottom of fridge is frozen. rise in temp is prob that defrost not taking place. not a diy unless you are experienced
Mar 14, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
