Question about Fisher and Paykel Washing Machines
F&p mw511 washing machine
HOw do I replace the rotor position sensor
  • Fisher and P... Expert
  • 555 Answers
RPS removal
Posted on Dec 26, 2013
tzweeb
  • 318 Answers
SOURCE: Cabrio rotor position sensor
ok lets try... first off you need to have the f51 code. then if you do, you do have a "rps"sensor that has failed.
get under the unit and you will see the large disc with an allen set screw holding it to the tub. remove the screw and it will pull off. then there will be 4 screws holding the rotor windings to the tub with a few wires on the sensor.
remove the screws and then the rotor will pull off and you will have the windings and sensor in your hands. when you get this all of it will be very confusing as the wires and sensor are just held into place by plastic tabs. if you have a new sensor that will help you to know that you are dealing with the right part. then unhook the wires from the sensor and next remove the sensor from the rotor windings
there is an arrow mark to show you where to put the sensor back into place, but its not easy.
thats why i get paid the big bucks!!!!!
anyway you can try this but dont get upset or mad, its just not easy for the first time you do it, but if you do it for a living then it gets easier the more times you do it.
of course i know you will only do it once but thats the best i can offer here.
Posted on Jan 06, 2009
blueextc3221
  • 15935 Answers
SOURCE: I have a Kenmore Oasis HE top load washer;
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!!!
Posted on Sep 18, 2010
  • 37 Answers
SOURCE: i have a F &
56. (00111000) Phase 4 to 6 - Basket Check No Valid Fault
While carrying out a basket check, the machine has not been able to determine a
valid tub status and so the Display flags this fault. This fault differs from fault 40 in
that a valid tub status could not be determined. The first two areas to check are the
clutch and pressure tube. If these two appear correct, then the fault could be with
the pressure transducer in the motor controller.
Primary Source: Mechanical.
Action:
1) Check that there are no clothes or other foreign objects preventing the clutch
from re-engaging.
2) Next check that the pressure tube has not come off and that it is not kinked.
Secondary Source: Motor Controller module. (Phase 4) Rotor Position
Sensor (Phase 5 and 6)
Action:
Replace the Motor Controller module. (Phase 4) Rotor Position Sensor (Phase 5
and 6)
Posted on Nov 21, 2010
  • 713 Answers
SOURCE: Need replacement motherboard for Model
Hi just read your posting.Have you try ed Fisher and Paykel local distributor ?What country are you in?If you are in Australia I can help you with phone numbers.Please reply with additional information and I am sure I can help you out.Looking forward to your reply.
Posted on May 21, 2011
  • 6277 Answers
SOURCE: how to fix a fisher
(no promises 'cos it could be a number of things but try this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 09, 2011
Washing was not filling up we fixed that we changed rotor position sensor now nothing works machine will come on will drain will not wash will not spin will fill now
Check you have put the rotor position sensor in the correct position & the 3 wires for the stator in the correct order Red Blue Yellow
Oct 27, 2015 | Fisher and Paykel Washing Machines
Gw511
Your lid will not lock will this Error code.
130. (10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness between the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: Check for corrosion on the RAST connector of the Rotor Position
Sensor and the Motor Control Module connector.
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if
faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted
(Refer to Section 2.7.2).
37
Jun 07, 2013 | Fisher and Paykel GWL11 Top Load Washer
Rps sensor on my F&p GW712 as the LED 1 & 7 come on and it beeps and I read somewhere that the problem is the RPS Sensor
Fault code 130
yes it is the RPS
Info on fault 130
faulty.
Mar 02, 2013 | Fisher Paykel EcoSmart GWL15
Fisher & Paykel MW511 error code lights 1 and 7 lighting up and beeping
Error code 130 is rotor position sensor faulty or wiring to it.
sensors sell for $25 to $50 on Ebay.
Jan 28, 2013 | Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel intuitive eco manual, bearing & seals need replacing
Error code 130 is Rotor position sensor fault.
130.(10000010) Phase 1 to 6 Single Rotor Position Sensor Error
from the Rotor Position Sensor. Likely causes of this fault are a bad
Action: 1. Check for corrosion on the edge connector of
2. Check the contacts on the rotor positional
sensor end of the hall harness to see if any
have been damaged. (Each set of contacts in
the socket has two wipers. If the distance
between these wipers varies between
different contacts, replace the rotor positional
sensor harness.)
tester. Replace if faulty.
Go to this site & select your model for parts view.
You will need Adobe reader to view PDF's
http://www.jordansmanuals.com/default.aspx?Brand=FP&Product=Washing
Oct 05, 2012 | Fisher and Paykel Washing Machines
My fisher & paykel GWL 15 washer, began to intake water in a few intervals ( one second ) in and out.Then it stop and make a beep every seconds and the first light at left is on( in washer proces
It could be fault code130
faulty.
Apr 26, 2012 | Fisher Paykel EcoSmart GWL15
I too have the same problem as lion heart, I have a fisher &pykel washing machine with model number GW612. It will stop n start while filling n two orange flashing lights will appear. The order of the...
This is a rotor position sensor Fault, below is the diagnostic procedure from the service manual.
130. (10000010) Phase 1 to 6 - Single Rotor Position
Sensor Error
sensor harness.)
Mar 05, 2012 | Fisher and Paykel Washing Machines
Gw712
Fault code 130
Sensor Error
sensor harness.)
Feb 29, 2012 | Fisher Paykel EcoSmart GWL15
I have a F & P mw511 washing machine, that stops and flashes a code 56. where do i start looking.
Action:
from re-engaging.
Action:
and 6)
Sep 16, 2008 | Fisher and Paykel Washing Machines
Washing Machines Logo
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
