Question about iGo Mobility Electronics Easidock Univ Docking Station USB 200
Mobility easidock usb 200 power cord
What voltage power cord?
Does my Casio g-200 keyboard have a fuse ? If so what type and where is it ?
I'd go exchange the power supply for the correct one (check the voltage, polarity and mA rating that's marked next to the power input). It may be too late, though.
There will be a fuse on the internal power input board, as well as one in the power supply, but if the instrument is turning on and lighting up, it's not a blown fuse.
Jun 29, 2016 | Casio Wk-200 Wk200 76-key Digital Personal...
Where can I find a power cord for simpletech
Hi, I think I found one for you 5V AC DC power adapter for SIMPLETECH 96200 41001 075 250GB USB hard... . If it is correct, it is OK to just find ANY power cord with Output Voltage: 5 Volts DC and Amperage: 1 Amps. It just need to fit in.
Sep 21, 2014 | SimpleTech 250GB USB2.0 7200 RPM External...
USB cord for Singer CE 200 quantum Futura
I would suggest contacting the singer website customer service and ask them or contacting a singer dealer about the cord..
Jun 20, 2013 | Sewing Machines
Micromax x225 is showing low signal
Ever looked at the power specifications of a mobile charger?? well if not, then have a peek... u will read that the output voltage is 5V DC........ the computer USB also has a voltage output of 5V DC........... any USB based electronic device needs this power to get started.... The laptop coolers u get basically work on this power from the USB... U'll notice that the USB ports have 4 terminals.... the extreme outer side are the POWER terminals +ve and -ve..... the middle 2 are the BUS lines IN and OUT.... a BUS is something electric conductive that allows the flow of 0's and 1's or rather high and low voltages to pass(Basic IT theory).... so this 5V DC can be used for doing anything; charging the mobile phone battery to lighting up entire rooms with LED's, making laptop coolers, etc......... Every mobile phone which has the USB connectivity option gets charged when plugged in... so sometimes even if u dont have the Mobile charger dont panic, find a computer and plug in the USB... not only micromax x225 mobile but, there are almost 80% mobiles which charge by connecting it to pc. Only nokia phones don't get charged. it is a good feature don't worry
Feb 24, 2012 | Nokia Cell Phones
I am replacing the line cord on a malibu model 200 RT power pact and had to unsolder the power cord from a circuit board. I forgot to mark which was the white and which the black. I tink I can figurate...
For 120 AC, the white wire is the base/ground/chassis/common lead. The black would be connected to the otherwise isolated high/hot side. Look at both the timer circuit and the transformer primary/input - the white should be common/base to both.
Aug 17, 2011 | Malibu ML200RT - Low Voltage Power Pack...
USB cord
USB cords should be boxed with the router. Typically you get either USB, ethernet or both. If neither was in the box I would return it for another or purchase any USB or Ethernet cord.
May 02, 2009 | Computers & Internet
CDJ 200 without electricity fuse blow off?
no you cannot do that , the device works on 120v( 117v around me) , but it cannot be changed like that , you would need a trans former that breaks down the voltage to 120v
changing the fuse will not change the circuitry in the device
Nov 30, 2008 | Pioneer CDJ-200 CD Player
Nuvi 200 -- won't power up after plugging into USB & Computer
Found out from Garmin Tech services how to reset the NUVI. Good to go.
Thanks.
Aug 05, 2008 | Garmin StreetPilot 2720 GPS Receiver
iGo Mobility Electronics Easidock Univ Docking Station USB 200 Logo
133 people viewed this question
Top iGo Computers & Internet Experts
David Payne
David Payne
Are you an iGo Computer and Internet Expert? Answer questions, earn points and help others
