Question about Haier Refrigerators
I have a small refridgerator with a LG MA53LBCM compressor. The compressor make a clicking noise every minute or so. The compressor makes no other noise and does not seem to run or try to run. The compressor gets very hot to touch, almost too hot to touch. Should I check into the overload or does it seem as though the motor has failed?
docjohn174
  • 943 Answers
SOURCE: refridgerator
Hi. thanks for the question. the heat between the doors is normal . to solve . pull the fridge away from wall .remove back panel. clean all lint in coils .Dust in the coils causes the heat between the doors to get warmer . so cleaning of coils. will solve the problem thanks the appliance doc
Posted on Oct 04, 2008
  • 1122 Answers
SOURCE: refrigerator Compressor hot to touch & fridge/freezer not cooling
you need to do an amp draw with your meter,clamp the run wire on the compressor,you should get 2-5 amp reading,any higher means the compressor is going bad,also should be a locked rotor amp(LRA) reading on comp.-mike
Posted on Nov 04, 2008
livewire874
  • 618 Answers
SOURCE: Relay close to the compressor clicks on and off
It can be either. Cheapest is to try the relay pack and see if that cures it. Most likely culprit.
Posted on Oct 27, 2010
repairman45
  • 130 Answers
SOURCE: i have a 2 year old Haier kegerator and it seems
Do you have any technical background? There is a simple and sure fix to this but you will need to be able to read a wiring diagram and have basic electrical tools like a wire stripper and electrical tape.
Posted on Dec 02, 2010
baraquielnar
  • 247 Answers
SOURCE: very hot day (93F /
try to clean your condenser and check the condenser fan motor if working good. then observe the unit.after u perfom cleaning try to start your ref. if the unit cannot start check ur over loador replace it if deffective. the n observe unit.or try to relocate your ref. unit may the circulation or air is not good cause of trippng of compressor. or check your breaker if ok.
Posted on Feb 05, 2011
Why does 15 amp 250 volt fuse in my lg refridgerator keep blowing
the 15 amp fuse is blowing because the current draw to run the compressor exceeds 15 amps
that problem could be from a failed start/ run capacitor or a failed compressor motor (I am betting on the capacitor)
the best answer is to get a fridge technician to check it out as the capacitor is a cheap fix while the compressor unit is as costly as a new fridge
Jun 25, 2015 | LG Refrigerators
Refrigerator wont run. Clicking noise coming from main board preceded by a short humming noise every several seconds. Unplug for 30 minutes then plug back in and compressor starts up after several clicks...
That condenser fan motor needs to be replaced. You and doing the right thing as far as using a seperate fan to keep compressor cool,buy replacing the fan the compressor will run cooler and click off by being too hot as you have heard/seen.
Find your model number and call your local appliance parts store and see if they have a CONDERSER FAN MOTOR in stock
Gene
Aug 15, 2011 | Refrigerators
I have a 2 year old Haier kegerator and it seems to have stopped working. I hear a clicking sound which I believe is the compressor going on and off. I have done some research and found that this is a...
Dec 02, 2010 | Haier HBF05EBSS Commercial Beverage...
Refridgerator makes a clicking noise like a set of contacts trying to open and close. what might that be.
If the fridge is not working properly it's probably the starter relay trying to start the compressor. It's a small electrical part on or near the compressor around at the back behind the cardboard cover. It's cheap and you can replace it yourself. If it's not the problem but it can't start the compressor then you need a tech to look at the compressor.
If the unit is cooling the noise could be from the electronic control which could be on the back in some models and in fridge with the controls in others. A noise from the control usually means it's going bad.
Nov 17, 2010 | GE 22.3 Cu. Ft. Bottom-Mount Refrigerator...
My Amana ARB9059CS refridgerator is not cooling. Fans blowing top and bottom. Makes a clicking noise every few minutes. Tried unplugging it for a day, then plugging back in. Did not help.
The clicking noise you hear is a relay trying to start your compressor but your compressor does not want to obey! Compressor most likely is bad and needs to be replaced or all your refrigerant gas has leaked out and would need to be repaired and system re-charger with refrigerant gas. Not a cheap venture either way. Might want to consider getting a new one.
Nov 07, 2009 | Amana ARB9059CS Bottom Freezer...
Very loud clicking noise from my LG LSC26905TT refridgerator
first you have to remove all shelves in the freezer,then remove all screws in the interior rear panel. In some cases you'll have to remove a couple of shelf tabe located on the side wall. Once tha panel is removed,the fan will be in plain sight. The blade is usually aboue 4-5 inches in diameter and is attached to a small motor with 2 wires and a green grounding wire. Note: you might want to check why it's making noise. Is there ice built up around the blades?Are you getting too much moisture entering the box thru faulty door gaskets?
Aug 26, 2009 | LG LSC26905TT Side by Side Refrigerator
My Kenmore side-by-side refridgerator is making a loud humming noise. My Kenmore side by side refrigerator/freezer has been making a buzzing noise every few minutes. Now I realize that the freezer is no...
You need to clean your coils under the 'fridge,' and wait 24 hours, if it is not not getting cold, perhaps replace the freon. If that does not work, you need to call a repairman.
May 26, 2009 | Kenmore 57029 Side by Side Refrigerator
Refridgerator
IF THE BUZZING SOUND IS ONLY THERE WHEN THE MOTOR IS RUNNING THAT COULD MEAN ONLY ONE THING.YOUR PISTON IN SIDE THE COMPRESSOR IS NOISEY THE ONLY WAY TO SOLVE THAT IS TO REPLACE THE COMPRESSOR.BEST YOU HAVE A TECH TO ADVICE YOU FUTHER.GOODLUCK.MOHAMED
Jul 21, 2008 | Whirlpool ED2FHEXN Side by Side...
Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
Jun 25, 2008 | Jenn-Air JCB2388G Side by Side...
Don't start smooth
restarting of refridgerator may damage your compressor motor due to overload.
when you switch off the refridgerator the compressor is in load condition, sudden restart overload the motor, it consume more current so the light going to dim.
solution. If your refridgerator have no delay circuit inside,
use a refridgerator stabilizer or attach a delay circuit,
if you have the the restart delay circuit may problem repair it.
Jan 18, 2008 | Refrigerators
Refrigerators Logo
475 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
