Hi got a micket mouse clubhouse computer for kids the mouse have been pulled off and there are about 6 cables need a wiring diagram to solder wires back on can you help
  • 1 more comment
  • willis774k Oct 28, 2008
    its made by clementoni havent got a product no on it
    its made by clementoni got a cable going from mouse to computer no plug to use another mouse
    it havent got a serial no its made by clementoni cant use another mouse as cable goes directly into computer
  • 1,800 Answers
Best solution to is to give up from that mouse and check if there any USB port and purchase an USB 2.0 Mouse.
click here to purchase one.
plz do rate this post.
Posted on Oct 28, 2008
  • Jalal Sordo
    Jalal Sordo Oct 28, 2008
    "Can you please provide us the model number if there is for this unit so we can help you better..."
    nice answer
  • 1,879 Answers
Where is the disconnection part, on the mouse side or the computers ?
  • 6,487 Answers
  • 13,433 Answers
Unless this is a special custom computer, its easyest to purchase a replacement mause, can you give me more details on the computer?
please use the add a comment button,
Thanks
    Master:
  • 538 Answers
Is that a mickey mouse clubhouse computer...???..does it have a model number on the unit?
  • 4 more comments
  • A Womans Computer Man
    A Womans Computer Man Oct 28, 2008
    is that the ears around the lcd screen that are pulled off?
    those wires are at the top of the lcd or at the bottom..either way, they work to supply the digital video signal..
    how long has that been in your house..not under warranty, right_
    what condition are the cables in? are they frayed?
    so is this the mouse that is for using on the screen, or the mouse ears that surround the monitor that was
    pulled off..
    well..chalk up another glaring error in working the premium system..hope this guy figures it out..soon..
How do fix where a mouse chewed through 6 wires
replace the wires. Solder a small piece of wire from electronics store and use heat shrink to cover the joins to the wires also get at electronics store. Soldering iron and solder also get at electronics store.
Mar 07, 2016 | Music
Tip
How to Crimping Network Cables
Tools and Materials You Will Need
Crimper with RJ-45 die.
Wire stripper
Wire cutter
RJ-45 plugs
Cat-5 UTP cable
Optional Tools
Wire Tester
Procedure
1. Strip off insulation
2. Untangle wires
3. Place wires in correct order &
straighten.
4. Trim wires to desired length.
Note:
If the wires are too long the plug will not
crimp onto the insulation for strength.
5. Slide wires all the way into the plug.
Make sure not to disrupt the color
scheme.
6. Crimp plug.
7. Repeat steps 1-6 for the other end.
8. Test wire using optional test equipment
or between working computer and hub
for patch (straight through) cables ,or
between switches for crossover cables.
Wire Color Scheme
Pin Color Diagram
1. Orange / White
2. Orange
3. Green / White
4. Blue
5. Blue / White
6. Green
7. Brown / White
Patch Cable
(Straight Through)
Both ends follow this
format.
8. Brown
Pin Color Diagram
1. Green / White
2. Green
3. Orange / White
4. Blue
5. Blue / White
6. Orange
7. Brown / White
Crossover Cable
One end as a patch cable
and the other as follows
8. Brown
on Dec 08, 2009 | Computers & Internet
Hi, the battery cable end that connects to the hummer broke. The wires snapped due to the kids pulling it apart. Can I solder it back on or do I need to buy a whole new cable. Just replaced the...
You can probably go on amazon.com and purchase another cable far less than what the stores charge. There is a chance if you solder the wires back together that it can blow the charger completely. Cutting corners is fun, but not when it comes to electronics.
Oct 14, 2013 | National Little Tikes Hummer Yellow
A creative speaker SBS A200 connector pin was damaged. we need to connect that cable directly into the board.so we need that pin details.
Hi, I hope this helps,
Pins look like this: (Top view, not copper side)
1 2 3 4 5
6 7 8 9
1 = Thin white wire from thick white cable (Left input)
2 = Gray (Speaker out)
3 = Orange (+V return from volume unit to bass unit)
4 = Not connected
5 = Thin Red wire from thick red wire (Right input)
6 = Blue (+V power from bass unit to volume unit)
7 = Black (GND - if socket removed, solder 3 socket shield holes to each other or solder black wire directly leftmost hole)
8 = Not connected
9 = Shield copper from thick red wire
Shield copper from thick wire : Solder to GND or Left unconnected
Jun 23, 2011 | Creative Technology SBS A200 2 Speakers
The Envision H170L Monitor VGA cable.
the Envision H170L Monitor uses an interface 1.0x VGA - 15 pin HD D-Sub (HD-15). The same VGA cable wildly use in different computer brands..I was wondering why you have not found a replace for that cable. It can be purchase from any computer store.
If you are planning on cutting the wires and solder it together that would be easy if you have the diagrams of the pin numbering for male VGA connector and the female VGA connector. Check first this diagrams and follow strictly the coding of the wire so that it would be successful when connecting it together.
It is also better if after you solder the wire, you will use an shrinkable tube on the connection. Cover the whole sections of interconnected wires with shrinkable tube before you use the vga cable.
Jun 03, 2010 | Envision H170L Monitor
Positive battery cable
i think that one goes to the starter. how bout cutting off the end and putting an after market cable end?
Sep 19, 2008 | 1998 Ford Contour
Broken speaker
the only way is o replace the wires from end to end.. you may have to do some soldering inside the subwoofer and the satellite speakers
May 12, 2008 | Altec Lansing Multimedia Computer Speakers
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
