Question about Kenmore Elite HE4 Electric Dryer
Beeping start button
I go to press the start button on my gas dryer and it just beeps at me and wont start and if it eventually does start you cant get it to restart for a real long time after being used im talking 10 hrs.
  • Ellrob Jan 02, 2009
    Dryer beeps through out the drying process. The first minute or so I can't do anything with the dryer and the beeping slows down and I can change the settings. Anyone have any luck fixing this problem. It is a Kenmore Oasis Dryer.
  • 116 Answers
Possible stuck button on inter face ,, this sounds like kenmore oasis dryer
Posted on Nov 30, 2008
Speed queen 30eg wont start. I have power through the switches all the way to the motor. I can hook the motor up direct and it runs fine, but i cant get it to start with the push button start
If you can jumper across the start switch you can eliminate the start switch as the problem. The switch acts as an open in the start control wiring. If the unit starts when you jumper across the switch, then replace the switch. If you are uncomfortable in jumpering out the switch you can unplug the dryer "disconnect power" just unplug the dryer then use a multimeter to read across the switch. Place the meter on continuity mode for an audible beep. If the meter doesn't beep when you press the switch to close the contacts, then replace the switch. Hope this helps!
Feb 16, 2017 | Speed Queen Dryers
Dryer wont start
check your compasitor it like a big fuse on the side of your dryer near bottom
Oct 13, 2014 | Kenmore HE3 Gas Dryer
Bosch dryer beeps
Two Beeps on my Bosch WTE84100au Condensing Dryer means a thermal overload but also means one of the thermal sensors is faulty .... as if it is always on.
Open the door, pull out the lint catcher and clean around the silver probe (it's like a shiny 1/8" nail sticking into the cavity below the lint catcher). If it still doesn't work (and still 2 beeps), just flick it lightly a couple of times. If it still doesn't work, flick again from the other direction.
Mar 24, 2014 | Dryers
Start button will not initiate on cycle. Get 3 beeps.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 20, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer will not start, just beeps once when start button is pressed. I hear a single click behind the control panel/head too.
HAVING SAME PROBLEM TURNED OUT TO BE THE TEMP SWITCH ON THE DRYER BLOWER DUCT,CALLED THE THERMAL FUSE .SIMPLE REPLACEMENT DRYER RUNS FINE COST AROUND 30.00 DALLORS TO FIX.
Mar 07, 2010 | Kenmore 67032 Dryer
Whirlpool Duet Gas Dryer won't start
Did you take the shipping blocks out? They are inside the machine. You will need to remove the access cover on the back and look in, you cant miss them. Good luck
Jul 26, 2009 | Dryers
Kenmore elite smart sensor model 110.6506 wont run
Many different possibilities. Could be thermal fuse, timer / control, motor. Start switch, or door switch. Most likely need to call service unless you have means to troubleshoot and test parts.
Nov 03, 2017 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 beeps three times when start panel is pressed and wont turn on
FWIW ... the Sears guy came by yesterday. The problem was apparently that the door latch was not operating to the extent that the sensors thought the door was open. He is replacing the latch next week. He adjusted the old one in the mean tiome and it appears to be working fine.
This kind of stunned me, since my wife reported an electric zap and the interior light burned out as the dryer went dead -- so I was sure it would be a fried circuit board -- but, no, a little jiggling of the latch seemed to clear it up....
Jun 24, 2008 | Kenmore Elite HE4 Electric Dryer
Brand new dryer
try holding door switch down with your finger while pressing start button.if dryer starts then your door needs adjusting.
May 20, 2007 | Whirlpool GGW9200L Gas Dryer
Kenmore Elite HE4 Electric Dryer Logo
244 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
