Question about Aiwa AV-X200
Receiver Shorting Out?
When I turn the volume up on the receiver past 1/4 while listening to music, the receiver will click and either completely shut down (meaning no more clock and unplugging is required to turn it back on) or it will turn off and blink (similar to what happens after a power outage). It will also do this while watching a movie for an extended period of time; leading me to believe it is overheating or there is a short somewhere.
    President:
  • 3,130 Answers
The power supply regulator is bad. it a bad regulator ic erroe transistor or even a bad capacitor. if you have the proper equipment and know how to troubleshoot solid state electronics, you should have No problem finding this fault. If your not trained to repair electronics, most likly this set will not be worth repairing or spending any money one.
Posted on Sep 02, 2006
I have owned an NAD 705 Receiver for many years, and am just now having problems (probably over 20 years old). I'm getting a message on the screen of the receiver that says 'protection' .
if the receiver turns on and operates then eventually turns off due to protection mode its because a wire is shorting out the receiver.if it doesn't turn on or goes straight into protection mode then its probably time for repairs or a new receiver.
Jan 06, 2018 | NAD Audio Players & Recorders
Yamaha htr 5730 manual
You would have to have a mini-plug (headphone) to RCA cable and connect the headphone jack to one of the rca inputs on the receiver. Make sure that the volume on the laptop isn't turned up too loud, or you may over-drive the receiver amp and cause it to shut down.
Dec 06, 2013 | Audio Players & Recorders
Dennon gets hot shuts off
how are your four outside speakers hooked up? If you have four speakers hooked up to only two output channels on the receiver, the receiver is sensing a short and shutting down to avoid damage to the amp.
Jul 20, 2013 | Denon AVR-3806 Receiver
Kenwood Receiver VR 806 turning off
Sounds like the music amplifier is different to the tuner audio amp. The music amplifier is now looking at an unbalanced impedance which is less than it should be. Therefore the output chip of the music amp has more current through it than it wants so it gets hot and shuts down.Put a four ohm wirewound resistor ( from Radio Shack ) in series with each surround speaker to reduce the current flow through the amplifier output.
Apr 09, 2010 | Kenwood VR-806 Receiver
Receiver will click off
check your power supply to make sure the correct amps and volts are there. check your speakers to verify the correct ohms for the receiver. if the ohms are to big you will shut down because it overdraws on the receiver.
Jul 28, 2009 | Audio Players & Recorders
My speakers shut fown briefly even at small volumes. Help!?!
are the hooked up correctly positive and negative whats the ohm load of the speakers and amp could be a short in your speaker cables
could be many different problems
Jul 02, 2009 | Sherwood RX-4105 Receiver
Yamaha RX-V1400 receiver powers off, in case it becomes louder
Hey, yeah that can be frustrating.
When you turn it up do you hear the relay or a clicking sound, then you turn it on and it comes back below the +2db?
Try unplugging All the speaker wires from the unit. Turn on the unit and listen for the click.
after the click, turn it up past the 2+ db mark and see if you hear it click or shut down. If it did not click off, then suspect a shorted crossover on one of your speakers.
2nd test is to plug in One speaker, and test it at high volume, it will not harm it. If it shuts off disconnect that speaker and try another. Only one at a time.
If it works at high volume, you need to isolate one of your speakers and i bet it has a shorted crossover that has been cooked. P.S. If one is bad, suspect they will fail at a later date.
If they all fail, use a friends speaker and try it before sending it to a repair shop.
P.S. i found one on ebay i think you can get for under $100 bucks in the box.
http://cgi.ebay.com/Yamaha-RX-V1400-7-1-THX-Select-Receiver-MINT-Condition_W0QQitemZ330311512027QQcmdZViewItemQQptZReceivers_Tuners?hash=item330311512027&_trksid=p3286.c0.m14&_trkparms=72%3A570|66%3A2|65%3A12|39%3A2|240%3A1318
E
Mar 02, 2009 | Yamaha RX-V1400 Receiver
Volume cuts in and out
Since a CD/DVD player is a digital device, it can be susceptible to such things as power line glitches, interference from other digital equipment and even the ignition interference from nearby passing cars. With older analog gear, you might get a short burst of static, whereas it can completely shut down a digital device sometimes (glitches interrupt its internal program). Sadly, there's nothing you can do about this except plugging the unit into a power line conditioner. You might try jiggling the connecting cables (especially the audio cable), but it sounds more like a random glitch since you can use your remote to fix it. They haven't yet worked out all the bugs in digital equipment, unfortunately. It's also possible that a defect in the DVD player was not caught at the factory during final test.
Jun 04, 2008 | Bose Acoustimass 15 System
The receiver sound shuts off
There is a problem with the receiver that is allowing DC voltage to get to the output amp section. This is detected and the protection circuit shuts down the receiver. Yamaha uses coupling capacitors between sections to prevent this. If one of these is defective, it would explain your symptom. This should be a relatively simple repair for a repair shop. Expect $10-$25 for parts plus the local labor rate.
Dan
Mar 18, 2008 | Yamaha RX-V992
Receiver turns on and clicks off when volume is raised over 8 or 9 on the dial
I had the same problem with my Yamaha amp. It turned out to be a shorting speaker wire. When I resoldered the speaker wall outlet connection it worked fine!
Feb 27, 2008 | Yamaha RX-V659 Receiver
246 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
