Question about HP LaserJet P2015dn Printer
Network troubleshooter claims printer is turned off but that is not the case.
This printer is connected to a network. Both the router lights and the network troubleshooter detect the printer but claim it is not powered on. I have tried restarting the printer, the router, and the computer but no luck. Printer is plugged into a battery backup that is completely powered up; the printer and other peripherals are all receiving power just fine. It was all working just great until I shut it down for a few days and problems began after powering up on return home.
martmet
  • 52 Answers
SOURCE: network printer P3005 not printing
When the problem arises, can you ping the printer from a workstation? Can you access the web management page (by typing the ip adress in your browser's adress bar) If you got one, you can also try to place a Jet Direct network card in the printer, in case your onboard network adapter is defective. I would start with this, good luck!
Posted on Jun 03, 2009
  • 551 Answers
SOURCE: HP laserjet 2015dn IP address problem
please do not assign dynamic IP on the network printer. give a static IP on it base on your network config. and also, please do assign all you computers on the network with static IP's so that every time they boot there will be no IP conflict or problem on the network connection.
Posted on Mar 05, 2010
SOURCE: HP Laserjet 1000 not printing (connection error)
Put in some ink
Posted on Mar 08, 2010
  • 100 Answers
SOURCE: My HP C6180 gave an error message a few times this
Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This also fixed the ink system failures the printer was having. A similar fix may apply to other printers produced by HP around this time. acca299.jpg
Posted on Oct 03, 2010
  • 1570 Answers
SOURCE: hp 4650dn printer showing offline. Connected
Hello !
You have to self diagnose the printer by your self. Please try this solutions.
1. Usually it is getting offline when the main computer that connects directly to the printer is off and you are only sharing from this computer through a router or a switch hub. Sure it will mention that the printer is offline and cannot print anything. You need that workstation to be open to be able to connect to the printer.
2. If not, check the cable connection connecting from your computer to the switch hub or router. Maybe it is just loosen for some reasons. Remove the cable to the router and plug it again. Turn off your printer and your computer and turn it on again. Try to print test page.
3. If not, try to unplug the printer cable connecting from the computer to the printer and maybe just loose up. Turn off your computer and printer, after turn it on again. Try to print test page.
4. If still not working, it not something to do with the hardware problem. I believe is it software problem, maybe you upgrade software or install software that harms your printer. Uninstall some programs from the computer that corrupted the driver files. If you upgrade the main computer, I suggest to uninstall and reinstall the printer software.
5. If not, try to replace the port (whether usb port) and maybe this is the problem. Try to turn off the unit and turn it on again.
6. If not, replace the cable connection from to the switch hub, close all the PC unit and print and try to print again.
Here is the only diagnostics solution I can give to you. Good Luck and Thank you for using Fixya.
Posted on Jan 06, 2011
How to troubleshoot HP Printer not found during network driver setup issue in Windows Operating system?
Download the full feature software from the HP website or on the software disc and setup your printer for wired or wireless network connection.
There might be one of the following errors if the installer does not detect your printer after setting the connection type.
1.Printer not found
2.Devices not found
3.Unable to find the printer
During the Hp printer network setup, there may be some troubleshooting issues,
Step 1: Reset or restart your computer, HP Officejet printer and the router
1.Disconnect the power cord outlet from the router.
5465_install_1a-ur23imwvkexuk45mistkg3hp-5-0.gif 2.Close all the tabs running on your computer and shut down your computer.
3.Then turn off the HP Officejet 4650 printer.
4.After few minutes reconnect the power cord outlet to the printer and wait till the connected status light blinks to normal.
5.Then turn on the printer and computer.
6.Again install the HP driver and software.
Step 2: Check the status between the printer and the network connection.
Before the setup confirm that your printer is ready.
1.Wireless Network: On the printer, open the wireless network connection settings menu and check whether the wireless signal is turned on.
2.Wired Network: Check that cable is connected to the printer Ethernet port.
Note: The green light should be in steady status and the orange link should blink when the cable is connected and make sure that your HP printer is not connected to a guest or host network.
1.Set the band to 2.4GHz if it is dual band router else the printer cannot connect to the network.
2.Check the network name and status of the connection in the notification bar.
3.If it is a different network then reconnect your network to complete the setup.
4.Move the computer and HP Officejet 4650 printer closer to the router if the signal is weak.
5.Slide the Airplane mode to off if it is on.
6.And again try installing the software and driver.
Step 3: Run the HP Print and Scan Doctor:
1.HP provides a free tool called HP Print and Scan Doctor to resolve the scanning and printing issues.
2.Download the HP print and scan doctor software to resolve all the troubleshooting issues.
3.After the installation on the Welcome screen click start.
4.A new menu box appears on the screen with the printer list. If your printer is not listed then turn on the printer again and connect it.
hpscanprinter-ur23imwvkexuk45mistkg3hp-5-2.png 5.Click the option my product is not listed and then select retry.
6.After that, your printers display and select it.
Step 4: Temporarily disable firewall software.
If the firewall software is installed on the computer that will help you to block the threats that found on your computer.
Use the print and scan doctor to identify and temporarily disable firewall software on your computer.
1.Click network on the print and scan doctor window.
2.A drop down box appears in that select the option troubleshooting firewalls.
3.Click the firewall software to disable it.
4.And install the HP driver and software.
If the HP driver is successfully installed then consult the firewall software support to change the settings as security level, trusted zones. After changing the settings re-enable the firewall software.
If the HP driver is not installed then there is no issue in firewall software and re-enable it.
Step 5: Uninstall and reinstall the HP drivers and software.
1.Disconnect the cable if your HP Officejet 4650 printer is connected to the USB cable.
2.Click programs and features in the search windows.
3.A list of installed programs will be displayed click your printer name and uninstall it.
4.Then follow the on-screen instruction to complete the process and restart your computer and reinstall the software from the official site.
If you still have doubts regarding this setup you can call us @1-800-836-3987 or visit us 123 hp setup oj 4650
Jul 06, 2017 | HP Office Equipment & Supplies
Cannot connect to computer
not much to go on. which did you set staic IP, inside Printer?, inside Router? or inside PC? is printer using lan cable to Router? is printer using lan cable to PC? is printer using Wifi to Router? is printer using Wifi direct to PC? try giving more information. you should be able to type in printer IP into IE to see its configuration pages/menus.
Jul 25, 2016 | Office Equipment & Supplies
Can't connect iPhone 5s and hp 1220c
Sir/Madam
iOS: Troubleshooting Wi-Fi networks and connections Symptoms This Issue is Related To Your apple Mobile And Make Sure You Already Install HP Printer Software In Your Desktop or Laptop. If yes I suggest you perform below Solution for Your Apple 5s and HP Priter Connectivity Issue:
Learn how to troubleshoot WiFi.Issues you may encounter while using your iPhone, iPad, or iPod touch.
Resolution Occasionally while using your iOS device, you may notice unexpected Wi-Fi behavior: Difficulty locating or connecting to a network
Unexpected Wi-Fi signal strength or disconnects
Inability to access the Internet
Not automatically connecting to WiFi when expected
Follow these steps to troubleshoot the above issues:
1.Be sure you're in range of your Wi-Fi router (access point).
2.TapSettings WiFiand turn WiFi off and on. If your Wi-Fi setting is dimmed,follow these steps.
1.Confirm that your Wi-Fi router and cable or DSL modem are connected to power, turned on, and connected to the Internet. If not, refer to your network administrator or Internet service provider (ISP) for assistance.
2.Restart your iOS device.
3.Tap Settings WiFi and locate the WiFi network to which you're connected.
4.Tap and Forget this Network.
5.Try to connect to your desired Wi-Fi network.
Note: You may need to enter your Wi-Fi password again if your network requires one.
6.Turn your Wi-Fi router off and on. If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
7.Update your deviceto the latest version of software.
8.Update your Wi-Fi router to the latest firmware. For AirPort Base Stations,install updates using the AirPort Utility.
If the issue is still unresolved Follow the steps below for the issue you're experiencing.
Collapse All'Expand All
Unable to locate a Wi-Fi network
Unable to connect to a Wi-Fi network
WiFi disconnects or signal strength is less than expected
Unable to access the Internet while connected to Wi-Fi
Unable to automatically connect to Wi-Fi
Additional Information Find information onconnecting to a Wi-Fi network.
Some third-party routers may not be compatible with all iOS devices, even after updating to the latest firmware. If your iOS devices can successfully connect to other Wi-Fi networks, contact your router's manufacturer to ensure that your router is compatible with your iOS device.
See recommended settings forconfiguring your Wi-Fi router for use with iOS devices.
Notes
1.iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models supportWLAN.
2.If needed, please consult with your network administrator (which may be your Internet Service Provider) for assistance with this step.
3.iPhone 5, iPad devices, and iPod touch (5th generation) are the only iOS devices that can connect to 5 GHz networks.
If You Still Haveing Problem then Visit official Below Apple Website URL Link:
http://support.apple.com/kb/ts1398
Or
In case you still having HP Printer Issue Then Follow Us On:
HP Printer Support
Feb 12, 2014 | HP DeskJet 1220c InkJet Printer
My wi fi orange light is blinking on my lexmark x4650 printer
The blinking WiFi light on your printer indicates either your printer is trying to communicate with your wireless network or your printer is not connected at all. For a quick fix, try to disconnect your printer from the power outlet. Power cycle your router and reboot your computer. Then, power on your router first, then your printer and lastly your computer. Check the WiFi light on your printer. If it goes to a solid green, that means you are connected back in your network. If not, you may reset your printer's wireless network adapter to its default settings. From the printer operator panel, press the Setup button > Network Setup > Reset Network Adapter to Default. The WiFi light on your printer will momentarily turn off then back on solid orange. Then try to run the Lexmark Wireless Setup Utility on your computer to reconfigure your printer to connect to your wireless network.
I hope this helps.
Nov 20, 2011 | Lexmark X4650 All-In-One InkJet Printer
How to stop wi fi from flashing orange on my x4650 lexmark printer
I hope this helps.
Nov 20, 2011 | Lexmark X4650 InkJet Printer
The modem and the wireless router were configured previously to me moving in with a new computer. In the network and sharing center, windows 7, it says that the wireless network is connected, however,...
If you have network access, it is not likely your computer. Since you have a network connection, I would start troubleshooting with the modem by turning off the local network (unplug power from rear) then turning off the modem (same, unplug at rear) for about 20 seconds then repowering the modem. Wait until the modem lights have settled into their connected/ok state then replug the local router. This will in most cases solve your particular issue. Farmerbear at FixYa
Oct 14, 2010 | Linksys Wireless-G WRT54G Router
Router quite working. Wireless does not work nor
Follow this procedure :
  1. Turn off all components on your network - computer, router, modem, printers and any wifi laptops
  2. With the ethernet cable connected only between the modem and the router TURN THE POWER TO THE ROUTER ON and let it boot up.
  3. Turn on the modem and let it boot up to all lights on.
  4. Connect / boot up any and all other components on your network.
Keep this order handy in case of a power outage. Best of successes!
Dec 04, 2009 | Linksys WRT160N Wireless Router
How do i do a wireless connection between computer and a kodac 5100 all in one printer
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/5100AiOPrinterUG_EN-US.pdf
follow this manual ...
  1. Check the Wi-Fi Status Indicator on the front of the printer:
  2. Status: Do the following: Off
    1. Select Menu (or Home)>Network Settings and press OK.
    2. Select Turn Wi-Fi Radio On and press OK.
    3. Select Wi-Fi Setup Wizard and press OK.
    4. Select the SSID (name) for your router.
    5. If you have your network secured, you must also enter your password.
    Blinking
    2. Select Wi-Fi Setup Wizard and press OK.
    3. Select the SSID (name) for your router.
    4. If you have your network secured, you must also enter your password.
    5. NOTE: If the message Your printer is already configured for Wi-Fi network appears, your printer cannot find your router.
    6. If this occurs, check that the router is turned on and located within 100 ft (approximately 30 m) of the printer.
    On The WiFi Status Indicator could be on, but you could be connected to the wrong router if you used the manufacturer's default SSID and password when you set up your router. If this is the case:
  3. Select Menu (or Home) from the printer control panel on the front of your printer.
  4. Select Network Settings and press OK.
  5. Select View Network Configuration and press OK.
Place the KODAK All-in-One Printer Software CD into the CD-ROM drive on your computer.
Follow the on-screen instructions. Do one of the following depending on the version of KODAK All-in-One Home Center Software:
  • When the KODAK Printer Setup Utility screen appears, select how you want your printer to be connected:
    • USB cable
    • Wireless Wi-Fi® connection
    • Ethernet cable
Oct 12, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
The printer won't connect to my wireless network
I had the same problem. The issue was that the printer only accepts upper case letters for the network security pass phrase. However, my password was entered in lower case during the router set up.
I had to change the network password to upper case.
Mar 15, 2009 | Office Equipment & Supplies
HP LaserJet P2015dn Printer Logo
91 people viewed this question
Seeker5211
Seeker5211
