Question about Canon iP100 Portable Printer
Replaced black ink, but am not getting solid light showing it's ok.
When I replaced the black ink cartridge, the red light on the cartridge flashes rapidly and continuously, and there is no image when I print.
    Top Expert:
  • 1,575 Answers
Hi
Turn it off and on.
Re-check the installations.
Unplug the printer for 1min to reset and then plug it back.
Try printing.
Posted on Feb 25, 2012
  • 15 Answers
SOURCE: BLACK PRINTOUTS ARE NOT CLEAR
The printer head is probably dirty or blocked.
You can run a head cleaning operation from the maintenance package which came with the printer.
Posted on Nov 29, 2009
  • 16 Answers
SOURCE: black ink cartridge
Are you using original Cartridge or a compatible one? One possibility is you didn't remove the sticker on the top which covers the air hole., please run a cleaning cycle from your pc before printing and take a nozzle check print.
Posted on May 12, 2008
  • 92 Answers
SOURCE: Help. Cannot print from black ink cartridge
Hi ....
There could be many reason for black ink not printing. You could try couple of steps starting with cleaning the print head ... Follow the below steps to clean the print head ...
After confirming that the cable is connected (if applicable) and the printer is powered on, perform the following.
Note: Standard print head cleaning can also be performed by holding down the <Resume> on the printer until the power light flashes one time. Deep print head cleaning (a more power process that uses more ink) can only be performed from the computer.
  1. Open the Printers folder.
    For Windows Vista
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
    • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
    For Windows XP Home Edition
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
    For Windows XP Professional Edition
    • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
    For Windows 2000/Me/98
    • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
  2. Right-click the printer icon and select 'Properties'.
  3. Click the Maintenance tab, and then click the 'Cleaning' icon.
  4. Select which nozzles should be cleaned.
  5. Click 'OK' to continue with the print head cleaning. The power lamp will flash and print head cleaning will start. Do not perform any other operations until print head cleaning completes.
  6. When the print head cleaning has finished, print the nozzle check pattern by clicking on the 'OK' button to determine if further cleaning is necessary.
  7. Once the page has printed examine the nozzle check pattern.
  8. If the pattern does not print correctly, click the 'OK' button to return to the Maintenance tab.
  9. Click the 'Deep Cleaning' icon.
  10. Click the 'Execute' button after selecting the nozzles to be cleaned.
  11. Confirm the message, and then click the 'OK' button to start the Deep cleaning.
  12. The Power lamp will blink and print head deep cleaning will start. Deep cleaning completes when the Power lamp stops blinking and lights. (It will take about a minute for the Power lamp to stop blinking and light solid.)
  13. Print another nozzle test pattern. If the pattern still does not print correctly, replace any ink tank that may be low, and then perform another deep print head cleaning.
  14. If printing is still not satisfactory, there may be a problem with the print head or the printer may need to be repaired.
This resolves the problem most of the time but if this does not work, please just leave me a note and we'll move to the next step which is checking the cartridge installation to check if its inctalled correctly or not ....
Please vote if this helps .... Cheers :)
Posted on Aug 04, 2009
  • 19 Answers
SOURCE: black ink cartridge holder not working
The problem you are describing is with the black ( BC-10 ) print head and not with the printer.
1. Check your black ink tank and be sure it is not dry.
2. Run the printer through one DEEP cleaning cycle and see if that improves the print.
If your black ink tank is full, and the deep cleaning cycle produces no improvement, you will need to replace the BC-10 print head.
Posted on Mar 14, 2010
  • 25 Answers
SOURCE: I bought ink cartridge online
on the front of the printer there is s stop/rest button hold down that for 20 sec that should over ride the empty message
Posted on Jun 22, 2011
Just tried top new black cartridge in - seems ok, but scanner not working and shows red light over ink sign
Clean cartridge with sof tissue and alcohol and insert it again, carefully.
btw: are you sure ink is NEW and not a refill? Refills should be good too but sometimes they fail.
May 06, 2015 | Office Equipment & Supplies
I can't print with the black ink. I performed a print head cleaning, and then I printed the nozzle check pattern. I noticed that the Cyan, Magenta, and Yellow shows up. However, the black checkered...
Simple problem that print head cleaning will typically not fix. The black ink is pigment based so it tends to form more stubborn clogs. Just remove the print head and if you have a steamer hit the black printhead nozzles with some pressured steam. If not available, soak the surface of the printhead in shallow hot water (try not to get the contact wet or be sure to dry them if you do). You can tell if the printhead nozzles are open by folding a section of wet paper towel like 5-10 layers and then soak it, press the printhead surface up and down lightly on the wet paper towel and if the nozzles are open you will see some ink pulse in the black port screen (the colors will also pulse from the pressure of the liquid under the printhead). It's easier than it sounds so give it a try. I've saved 100s of Canon printheads this way.
Note: if you have a really dried out head, you sometimes have to soak from the top inlet ports and the bottom nozzle surface to clear, but unlikely in you case since you had a black cartridge installed with ink in it (this keeps the top port from drying).
Sep 15, 2011 | Canon MP520 All-In-One InkJet Photo...
Error message - "some ink
All the ink tanks should be red with no flashing.
The tanks that are flashing or have no red light on , need to be replaced.
Feb 14, 2011 | Office Equipment & Supplies
I have cleaned the print heads, replaced cartridges and still can't get text to print. Any idea?
If you have a a solid red light showing you will not get any printing done. On the epson printer which red light is showing? Is it the one for the black or the color? Was that cartridge replaced by you? I have actually seen one cartridge's red light glowing and so replace the cartridge. Then the printer goes through a charging sequence and to my surprise another red light is showing, but this time it's the other cartridge, because the printer was already low on that color and the charging cycle emptied that cartridge enough to trigger the light to start blinking on and off. Now suppose it's the same light that is still on even after you replaced the cartridge. Do this: hold the paper in feed button for about 3 seconds. The printhead will move to the left. Lift up the clamp of the cartridge that
has the red light glowing and bring it down somewhat definitively again to lock the cartridge down. There is a microswitch that is reset when this is done that tells the printer it has a new cartridge installed. Sometimes when a cartridge is replaced the switch is not reset if the clamping process is not definitive enough, or it simply needs to be done again. When you've done this push the paper infeed button again to move the head back to park postition.
Good luck,
Jan 05, 2011 | Epson CX4200 All-In-One PSC Printer
I have a Samsung ML-2525 BW laser printer. Recently, the red bar second from the top started flashing and then it went solid. I thought this was because of the ink toner, and the cartridge was running low...
I guess it FixYa didn't accept my (very long, but totally correct) solution that I took the time to type. Because I refused to "sign in".
Here's the short version. Load Paper. The same thing happened to me. I replaced the toner cartridge with a new one (because of a FLASHING red light for several weeks) after the red light went to STEADY red. But it still would not print. The paper was "out". When I'd refilled the paper-tray, it printed fine. I had just ASSUMED that the steady-red light meant toner was finally OUT. WRONG! That steady-red light had nothing-to-do with toner; it meant "you're out-of-paper". Don't get confused like I did. Refill the paper-tray. Then take that expensive NEW toner cartridge OUT, and put the OLD toner cartridge back in. And keep using the "dregs" of the toner out of the old cartridge for several more weeks. And DON'T get confused by the paper-is-out condition making that red light STEADY.
Nov 01, 2010 | Samsung ML 2525 BW laser Printer
1. Replaced Color and Black ink cartidges on my HP D5160: Color cartridge - NEW Black cartridge - REFILL SYMPTOMS> Red flashing exclaimation LED, black ink cartridge appears empty (0 dots in the...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Oct 26, 2010 | HP Photosmart D5160 InkJet Printer
Changing color cartridge on my epson stylus color 980 printer.
If you need to replace an ink cartridge in your printer, please follow the instructions below:
To confirm which ink cartridge requires replacement, please use the printer's control panel (there is a black ink out indicator, as well as a color ink out indicator ), or the Status Monitor in your computer.
Red light flashing - Low ink
Red light solid - Out of ink
1. Open the printer cover and press the INK (Cleaning) button for 3 seconds. The print head moves to the center and the lights flash.
2. Lift up the ink cartridge clamp. The cartridge rises up from its holder.
3. Remove the cartridge and dispose of it carefully. If ink gets on your hands, wash them with soap and water. If ink gets in your eyes, flush them immediately with water.
4. Unpack the new ink cartridge and remove the yellow tape. You must remove the yellow tape from the top of the cartridge. Do not remove the clear seal underneath the cartridge. Do not touch the green circuit board on the back of the cartridge, or you may inhibit normal operation and printing.
5. Tilt the new cartridge toward you slightly as you insert it. Lower the cartridge so that the tabs rest on the hooks. Do not place the cartridge tabs under the hooks.
6. Press down firmly on the ink cartridge clamp until it snaps in place.
7. If you need to replace the other ink cartridge, repeat steps 2 through 6 before continuing with step 8 (to move printhead over to color (if black was replaced first) press the cleaning button once).
8. Press the INK (Cleaning) button once, and close the printer cover. The printer begins charging the ink delivery system.
9. Wait until ink charging is finished (the power light stops flashing and the red error light goes out).
May 11, 2009 | Office Equipment & Supplies
My ink ran out and I replaced both the black and color inks. The black is ok, but the color still show that it needs ink. Now my printer won't work. Can you help me?
Yes, I got it solved. I returned the first ink cartridge and got a new one, Ir works fine now, except the red is more pink than red.
Nov 04, 2008 | Office Equipment & Supplies
Epson Stylus 440, solid light on for black ink, have replaced and still won't print
This morning I was researching to purchase a new printer to replace the 10 year one. The last cartridges I had purchased were from Printpal and made in China. They looked the same, but I had to force the door closed on them. With the solid red light on and replacing the cartridge three times with new ones from this order, it was time to find an old used cartridge from another company that I intended to refill myself. I did, installed it and the solid red light disappeared. The old Epson Stylus 440 is still ticking! However, I had written off InkGrabber for unused cartridges going dry in 2 months and now Printpal is on my $%%# list for non-uniform replacement cartridges as well as not lasting long. I am back to refilling my own. I had followed the instructions for resetting the ink level indicator, but to no avail as those instructions are for a blinking light, not a solid light.
I appreciate your website, if for nothing else, to be able to vent. Thanks so much for your follow-up inquiry and I'm sure you'll hear from me again soon about my old Epson.
Shirley
Aug 17, 2008 | Epson Stylus Color 440 InkJet Printer
Canon iP100 Portable Printer  Logo
201 people viewed this question
old marine
old marine
