Question about Garden
What does LA Screw mean on Stihl Whipper Snipper
The three screws on a stihl whipper Snipper mean what?
5 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: my stihl fs36 Whippersnipper continues to flood what is the cause
Your float adjustment in the carb needs to be reset, or there is trash under in inlet valve in the carb.
If the float is set wrong or trash in the inlet valve then that will cause the problem of flooding,
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 15, 2010
  • 313 Answers
SOURCE: How do i replace the line in a Stihl whipper
Look on Stilhl web site for downloads to locate the operating instructions which you can download and print off. Possibly in PDF format.
Posted on Jul 25, 2010
needs a carb kit with needle valve $20 at a small engine store
Posted on May 22, 2011
SOURCE: How to fit whipper snipper line
Hold the snipper upside down so the petrol leaks onto the kitchen floor. Take 6 metres of line and untangle it eventually. Stick it through the two holes and wind the cord in opposite directions so it jams together and tangles. Stick the unit head back together with two feet of line sticking out each side. Start the trimmer and jump backwards as the line rips itself to pieces. Use it on weeds until line breaks within 20 seconds. Slam the end of the trimmer into the concrete and shout **** fuckey **** ****. Then tear off the head cover and start again. I have done this for years and it never fails. Hope this helps.
Posted on Jan 05, 2012
My stihl whipper snipper loses power and cuts out when i try to rev and apply throttle.
With 2 strokes I always start with 'AIR' 'FUEL' 'SPARK' from the sounds of it the choke might be stuck on (choking the motor ha ha) also check the air filter, You have fuel and its moving through but the fuel filter might be slightly clogged. As its starting and going on low your spark unit is ok but you might need a new spark plug.
Dec 21, 2015 | Stihl Garden
I have a stihl 2 stroke petrol whipper snipper. It seems to have over heated at the reel end. I have smoke and grease spewing out at that end (metal neck at the reel end) have I fried it?
Sounds like you have a straight shaft trimmer version that have got bad bearing(s) that needs replacing. It probably will take the whole gearbox as a replacement item.
Jan 20, 2015 | whipper snipper stihl fs 38
Need a new wire from throttle trigger to carb
throttle cable, call a Stihl dealer. Part look-ups for Stihl and others are not available online
Aug 28, 2013 | whipper snipper stihl fs 38
Stihl whipper snipper fuel oil ratio
all Stihl products are 50:1 fuel mixture
Mar 30, 2013 | whipper snipper stihl fs 38
Sthil whipper snipper fs38 won't engage the starting pull mechanism, it turns but won't grab drive coupling
remove the recoil cover and check the dogs that engauge the starter to the flywheel
Jul 28, 2012 | whipper snipper stihl fs 38
My stihl fs36 Whippersnipper continues to flood what is the cause
Mar 17, 2010 | Yard Machines Garden
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
