Question about HP 49g+ Calculator
How to do a quadratic regression? - HP 49g+ Calculator
  • HP Master
  • 7,993 Answers
I am sorry to say that natively the HP 49G+ does not perform quadratic regressions. The models that are vailable are Linear fit, logarithmic fit, exponential fit, power fit, and best fit.
These options are available under Right SHIFT (Orange) 5 (STAT)>3:Fit data.
Posted on Feb 25, 2012
How to model real life data?
What is the question?
Put your calculator in STAT mode (2-var statistics or regression )
Enter your data in two lists, preferably sorted according to the x-value
Choose a regression model from the ones available and get the calculator to give you the best fit.
However to see which regression model best fits you data you need a graphing calculator to draw the scatter plot, then superpose on the scatter plot the curve of best fit given by the regression model.
Once you accept a model as the most suited one, you can use the equation of the curve to predict a y-value given an x-value (what ever REAL LIFE meaning they might have)
Dec 11, 2013 | Sentry CA 756 Calculator
Am trying to calculate corelation on a Casio fx-9750GII,
Press Menu.
Use arrows to highlight STAT icon and press EXE.
Enter your data in two lists (x-values in L1, Y-values in L2)
Press F2 to activate the CALC Tab at the bottom of screen.
This is what you see.
Press F3 to activate the REGression tab.
This is what you will see: the TABs at the bottom of screen.
Each tab corresponds to a regression model: X-linear, X2 quadratic, etc.
If you press F3:X^2, you get the following
You see the parameters of the regression equation, the coefficient of determination r^2, and the Mean Square error. No correlation coefficient is defined for this regression model.
For other models like linear, logarithmic, power and exponential regressions, the correlation coefficient is defined and is thus displayed with the regression equation. It is the r-value.
Jul 31, 2011 | Casio FX-9750GPlus Calculator
How to find PRegC= when working with quadratic regression
You can either type in the name or pull it out of the STAT VARS menu (2nd [STAT] F5 MORE MORE MORE MORE F2.
Dec 03, 2010 | Texas Instruments TI-86 Calculator
How to use casio calculator in solving regression problems
I am sorry but I will have to assume that you know how to enter the data.
Once you enter your data [MENU][STAT], press [F1:Graph], select Gph1, Gph2, or Gph3. Once the graph of the experimental data is drawn, you will have access to the diverse regression models. Your choices are [X:Linear] [Med-Med], [Quadratic :X^2] [Cubic;X^3] [Quartic: X^2]. Press [F6] to scroll right to access the others: [Logarithmic:LOG], [Exponential :EXP], [Power :Pwr] and [Sinusoidal: Sin]
After you select a model and press [EXE], the screen displays the equation and its various coefficients. On that same screen, you have a menu option [F6:Draw]. If you select it, the regression curve will be drawn on the same screen as your statistical graph. This allows you to judge if the fit is good. If it is not, you have the option to choose another model.
The other option [F5:Copy] allows you to save the regression equation in the Y1, Y2, etc. variables.
PS If you do not know how to enter data post a comment to this effect and I will see what I can do to help you.
Oct 16, 2010 | Casio FX-9860G Graphic Calculator
When I enter the Regression Equation into the "y=" calculated from the Statistics that I input, it inputs half the equation into the power. Like X^(n 3) instead of X^(n) 3 which is what it is meant to be.
The regression equation can be copied automatically in a Yx variable. You need not enter it manually(?).
Example: Suppose you are performing a quadratic regression on data stored in L1 and L2.
  1. From the [Stat][
Oct 12, 2010 | Texas Instruments TI-84 Plus Silver...
How do i do linear regression on this calculator
Sep 02, 2010 | Casio FX-9860G Graphic Calculator
Do i have only one type of exponencial regression o my 9850gb plus?
Th CFX-9850GB Plus is programmed to perform 10 types of regressions, namely
LinearReg: Linear y=ax+b
Med-Med also linear y=ax+b
QuadReg :Quadratic y= ax^2+bx+c
Cubic: y=ax^3+bx^2+cx+d
Quartic: y=ax^4+bx^3+cx^2+dx+e
LogReg, logarithmic: y=a+b*ln(x)
ExpReg, exponential y=a*e^(bx)
PowerReg, power: y= ax^b
SinReg, sinusoidal: y=a*sin(bx+c) +d
LogisticReg, logistic; y= c/(1+a*e^(-bx))
There may be more regression models appropriate for more advanced (specialized) statistics but the ones in the list are all the CFX-9850GB plus offers. However, since the calculator knows a programming language, you may want to implement a particular model.
Hope that helps.
Oct 24, 2009 | Casio CFX 9850GB Plus Calculator
How to get line of best fit
Hope it helps.
Oct 02, 2009 | Casio FX-9750GPlus Calculator
Singular matrix error
I had this problem as well...Were you working on a SinReg equation by any chance? I was able to do every other type of regression (Linear, quadratic, cubic, ect..) In order to get Sinusoidal regression you need to make sure you arrow down to the Period box when entering the equation, and fill it in with the number of items in your table of values (a ten item list means a period of 10). That was the fix for me, so hopefully it works for you!
Jan 17, 2009 | Texas Instruments TI-89 Calculator
HP 49g+ Calculator Logo
275 people viewed this question
Seeker5211
Seeker5211
