Question about Roper REX3614KW Electric Dryer
Roper Dryer Push the start button and the dryer growls at you but won't spin the drum Help Please
  • 943 Answers
Hi thanks for your question. When a dryer growles at you like that. Its a sign of a bad motor. To repair the dryer replace the motor
Posted on Dec 16, 2008
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
I have an Ultimate Care II gas dryer. Model # LGQ7030KQ0 and the drum won't spin when I push the start button.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 29, 2011 | Whirlpool Dryers
I've got a 4 yr old Roper electric dryer that won't start up. The belt is fine and the drum spins freely. When you push the button to start it will hum but won't turn the drum. I've got...
heatman101
Jul 03, 2011 | Roper RGX4634KQ Gas Dryer
My Roper dryer has power I can here it, but it does not spin the clothes dry...doesn't turn on. How do I figure out what is wrong?
try this,open the door,with one hand push in the door switch,with the other hand spin the drum,have someone else push the start button,if it runs you have a bad motor
Feb 22, 2011 | Roper REX3614KW Electric Dryer
My Roper dryer heats up but does not turn when I push the start button. What would cause the dryer to not spin?
one is the belt may be broken or have slipped off the pulley.the door switch could also be bad. try and hold the door open and depress the door switch at the same time someone is pushing/turning the start button and then try to rotate the drum be hand and see if it will turn. the motor could have alot of lint build up and cause the motor not to turn.
Oct 13, 2010 | Roper REX4634KQ Electric Dryer
My Roper dryer worked fine until my basement flooded about 6 inches of water on floor. Now my dryer just hums when I try to start the dryer. The heat does come on. When I spin the drum and hold in the door...
It sounds like the motor was damaged in the flood. You may be able to salvage it by spraying both ends of the motor shaft with penetrating oil several times moving it in between, but you may not be able to salvage it.
Dec 30, 2009 | Roper REX4634KQ Electric Dryer
Roper dryer by maytag press star button here noise but does not start?
you will nead someone to help you to see if you have a bad moter.first open door,with your right hand push in on the door switch.hold the switch in ,have someone push the start switch in and at the same time with your left hand turn the dryer drum clock wise,if the dryer starts than you have a bad moter.the cost of the moter would be 1/3off the cost off a new unit.
Nov 20, 2009 | Roper REX4634KQ Electric Dryer
Dryer drum will not spin when you push start button.
can you hear the motor running? if so its probably a broke belt
Sep 03, 2009 | Dryers
Roper Electric Dryer Heats but drum won't spin
Yank the filter out the top. Remove the 2 screws in the filter housing. Use a putty knife to pop the top and then remove the screws holding the front on. NOTE: raise up on the front panel slightly so you won't damage the bottom clips. Get the front out yer way and remove the drum. Clean out the dryer and oil the rollers and idler. Use this handy ROUTING GUIDE to see how to put the belt back.
Jan 20, 2009 | Roper REX3614KW Electric Dryer
Roper REX3614KW Electric Dryer Logo
85 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
