Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson dc07 The rotating brush on the bottom of my vacuum was filled with strings. I removed the brush by undoing all yellow plastic screws from plate. Removed all strings and replaced as best I could and it was hard to get the brush back in and the belt around it. I dont have my manual but it fits so it should be correct....? Right? No, not true, because when I turn it on and try to and vacuum (by lower canister with foot release) it makes that terrible ratching sound). Please help
  • 43 Answers
The loud ratching is a warning to tell you that there is something stopping the roller bar from rotating this is a very common thing lay the machine on the floor front side down take off the bottom plate and just check the belt is in the centre of the belt guide on the brush bar normally if you turn the roller slowly without the bottom plate fitted it will straighten out on its own
Posted on Nov 11, 2008
How do you change a belt on a dyson DC07
Turn vacuum over so you can see the brush.
Using a standard screwdriver, undo the three fasteners just behind the brush.
Remove the base plate.
Remove the belt.
Remove roller brush.
Place new belt on roller brush and center it in position.
Feed belt through the hole, and return brush to position.
Ensure the brush ends are located in the slots correctly.
Pull the belt over the motor shaft.
Rotate the brush a few times to ensure belt is centered and secure.
Replace the base plate, tighten fasteners, and rotate the brush a few more times to make sure it turns properly and the belt isn't caught.
Mar 04, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
When I try to vaccuum the brush doesn't rotate. I've made sure that it is in the right position
DC14s have two drive belts that turn the brush bar - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar.
You can check the latter simply by removing the sole plate and looking. Unfortunately the other belt is hidden under a plastic cover, so you cant see if it is okay or not without some dismantling. This cover is not easy to remove and requires a Torx driver to undo the securing screws.
If, after removing the cover, the other belt is okay, then you have a faulty clutch. New clutches are available on eBay reasonably cheaply, but again good tools and DIY skills are required.
Have a look at www.dysonmedic.com which has some excellent info on dismantling and repairing a DC07 (the DC14 is very similar to the DC07), but unless you have access to such tools, and feel confident to tackle it, it's probably time to call Dyson or a Vacuum repairer.
Nov 01, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
I have a DCO7 dyson VAC it is not picking up any thing. It seems like it is working and sounds all right, I did clean the brushes .
Greetings,
I see this happen a lot on Dyson vacuum cleaners. A lot of the time when the user removes the bottom sole plate to clean the brushes, the sole plate is installed incorrectly when putting it back together. This causes the brushes of the vacuum not to hit the floor, and thus greatly reducing the cleaing ability of your Dyson on floors and carpets, but when you use the attachments you'll still have full suction power and great cleaning ability when you use the attachments.
Check the sole plate on your vacuum on the sides of the vacuum. Are the sides of the soleplate flush with the yellow (or purple for DC07 Animal models) agitator housing, or is there a visible crack in between these two plastic pieces?
If you see that crack, then simply remove the soleplate again by unscrewing the three colored plastic screws on the bottom, and re install, this time making sure that the two housing are completely flush with each other.
If this didn't fix your problem, I'd love to try and help you further diagnosis this issue. Please just use the Clarification Request that you see here on this page, and let me know a little more specifics about what's going on. I hope this helped you out. If it did help, please be sure to rate the repair solution helpful by clicking on the Thumbs Up Icons in this repair.
Thank you very much,
Chris J.
Mar 21, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Cant undoe the Dyson in order to clean it
To clean the brush bar area: Lie the machine on its back, look for the three plastic screws under there. Turn them anti-clockwise using a 2p coin (or a quarter if American) and the sole plate comes off that way. This gives you access to the brush bar to clean it.
Oct 12, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I was vacuuming with the Dyson DC 17 and sucked up a berber carpet string by accident and after cutting and pulling it all out of the bottom brush part, the brush no longer spins but the suction part...
The belt could be snapped. If this model has a brush protected belt then it has to be repaired by a service call. If however you can get to the brush roll belt by removing the bottom sole plate (turning over the vacuum so that you're looking at the base) with the plastic catches undone where you can see the belt then check to see if it has snapped. If it hasn't snapped then it may just need readjusting.
If you can't see the belt and has protective covers that can't be undone then the model has a brush control system that has to be replaced by someone who can do Dyson repairs.
Mar 12, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Brush bar on my dyson dc07 will not turn.
Hi.
Your Dc07 may have A clutch unit.
Check that when you pull back handle to vacuum that the clutch control knob which is located front lower left side of machine moves to drive position & is not stuck in off or park position.
Rotate it to drive if its at off or park when you have lowered handle.
If adter checking this you still have no brush rotation you will need to remove clutch unit to either replace thr belts or fit new clutch.
Try this site for further help http://dysonmanuals.llc.nu/
If you dont have the clutch arangement then just turn the three plastic screws on the sole plate ( Under front of machine) to unlock pull off sole plate & fit new belt to brush roller.
Easy job to do.
Dec 29, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My dyson is making a loud horrible noise
Hi.
Check the brush roller can be moved by hand & that it is not snagging on something.
If it is difficult to rotate remove sole plate by turning the 3 plastic screws to unlock position lift plate off & clean brush roller & check you can turn it after this.
If brush roller is free to rotate the chances are the clutch is faulty & will need to be replaced.
Go to this site http://dysonmanuals.llc.nu/
It has manuals that cover clutch replacing on all Dyson models.
Sep 01, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
No suction when vacuming floors
Hi.
There are 2 types of Dc07 one is clutched & has two belts the second has only one belt going from motor to brush roller.
Lay machine on its side pull back handle as if you are to vac carpet switch machine on look to see if brush roller is spinning.
If it is not spinning unplug machine from mains supply & remove the sole plate by turning the three plastic screws to unlock position, Lift sole plate away if you have non clutched machine you will now see the brush roller with A belt going from this to the motor shaft belt may have snapped or come off so replace it.
If your Dyson has A clutch unit this engages the brush roller when you pull the handle back to vacuum.
Check the clutch control knob which is at the bottom left side of machine looking from the front.
It should rotate to drive position when handle is pulled back.
If it doesnt turn the knob by hand to drive.
If you still have no brush rotation after doing all this then either the clutch is faulty or the second belt which goes clutch to motor has snapped & will need replacing.
There are service manuals available for these repairs at this site
http://dysonmanuals.llc.nu/index.htm
Jul 05, 2008 | Dyson DC07 All Floors Bagless Upright...
Dyson DC07 Vaccum - brush will not turn
Hi.
Your Dyson has A clutch unit this engages the brush roller when you pull the handle back to vacuum.
If it doesnt turn the knob by hand to drive & try the machine.
If you still have no brush rotation after doing all this then UNPLUG machine from mains supply.
Now lay machine on its side & remove the sole plate, This is the cover over the brush roller.
Turn the 3 plastic screws to unlock postition & lift sole plate off.
Now try to yurn brush roller using your hand. It should turn freely if it is difficult to turn look for any foriegn object obstructing the roller.
If no obstruction found then remove the brush roller from the machine & check the bearings in the ends of the brush roller one or both may be siezed up if they are then new brush roller will solve the problem.
If bearings are good then either the clutch is faulty or the second belt which goes clutch to motor has snapped & will need replacing.
It is difficult to fully explain the clutch removing procedure,
But there are service manuals available for these repairs at this site
Jun 15, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson vaccume cleaner
Remove sole plate by turning 3 plastic screws to unlock then pull plate off.
Check belt has not snapped.
If your machine is all floors with clutch check that selector knob on front side of machine goes to (D) or drive when you pull the handle back.
Let me know how you get on.
http://dysonmanuals.inc.io/
Chris.
Dec 09, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
89 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
