Question about Lexmark P3150 All-In-One InkJet Printer
Scanner it doesn't show the whole text I am trying to scan mainly at the borders
  • carrascocana Oct 28, 2008
    Thank you very much, even though it is in french, I understand and appreciate the help, it seems that I have another problem though... M.E.
J'ai besoins d'un driver pour lexmark p3150 pour vista
Posted on Oct 28, 2008
After programming my BC92XLT scanner it shows to be scanning but nothing picks up
could be a bad antenna connector, or it could be a protection diode
( called a pin diode ) that popped on the main board. it is there to protect the scanner from a static charge from coming through the antenna connector and blowing the whole main board
Dec 20, 2014 | Radio Communications
When I scan, using the ADF on my brothers mfc 6490, the resulting image is shifted, cutting off the right hand margin of the 8-1/2 x 11" scan. I am using Scansoft Paperport on my XP Pro laptop. The...
I read the whole paragraph and could not find a question, so I will try a few suggestions.
When you scan, select the option to open the scanner interface. It will give you more control on what you scan.
From the flatbed
When the scanner interface appears choose to Preview the scanned area. On the preview image click neat its border and you will see a dotted/ interrupted frame. Play with the borders of the frame to select the area. Intelligent software like Adobe Acrobat rotate the image to right it.
From the ADF
Check the alignment of the paper on the document feeder. Test the first page and see if it is correct. If it is, and all the subsequent pages have the same margins use the ADF If not, maybe you should use the flatbed.
Oct 29, 2013 | ScanSoft Nuance PaperPort 11 for PC
Can I scan legal size paper with the Canon MP 240
Hi
You can scan the largest size of paper that will fit on the glass area of the scanner (the platten).
If your legal paper fits in this area or, at least the text printed on it fits well within the borders of platten, then you can scan it.
Your scan will show you a preview of the image scanned so you can see if all the text has been scanned from the original document before you save the scanned image on the computer or copy print it.
Legal Paper Size is: 8.5" x 14" (216mm x 356mm)
A4 Paper Size is: 210mm x 297mm
Letter Paper Size is: (8.5" x 11") 216mm X 279mm
This printer's Scanning Width is: A4/Letter
This printer's Scanning Length is: A4/Letter
I hope this helps.
Aug 28, 2011 | Canon PIXMA MP240 All-In-One InkJet...
I am trying to scan a document and it is not working, I have a hp photosmart c4280 printer. How do I install a usb cord
hi
Place the document or image into the scanner for scanning. A scanner with a paper feeder will only receive flat papers and photographs, but a flatbed scanner opens to accommodate books, fabrics and leaves along with flat papers. There is even a attachment for feeding photo slides into flatbed scanners.
  • Step 2 Start the scanning softwaremag-glass_10x10.gif. If the scanner does not engage the software automatically, press the "start" or "scan" button, or click the scanner icon on the computer screen to initialize the software.
  • Step 3 Activate the scan. Click the "file" menu and select "acquire," "import," or another practical choice that applies.
  • Step 4 Preview the item to be scanned. Most scanners have a preview option. This will show the scan area inside dotted lines. The lines can be moved with the mouse to relocate, enlarge or crop the scanning area.
  • Step 5 Set the resolution for images by number of dots per inch (dpi). For computer screen viewing, 100 dpi should suffice. Use 200 to 300 dpi for items to be printed.
  • Step 6 Use the appropriate setting for scanning black and white text. If the scanner does not show a preset for text, use "line art" or "black and white" at 300 dpi. Then use the optical character recognition (OCR) program to convert the image of the text into a file for word processi
  • Jun 09, 2010 | HP Photosmart C4280 Aio Printer
    Uneven black border showing up on scanned documents
    Most scanners scan the whole "bed" not just the document lying on it. Where no part of the document covers the bed usually appears as black.
    Normally when scanning you are offered and option whether to scan the whole document or a portion thereof. When previewed, a dotted line appears around the portion the scanner thinks you want, you have to re-arrange that box so that it lies just within the part or the document you require.
    Should this not resolve the issue the menu options on
    the left hand side of the Xerox web page should guide you to a resolution.
    http://www.xeroxscanners.com/en/us/products/DM632/
    Mar 31, 2010 | Xerox DocuMate 632 Scanner
    Scans wrong size...only scan a portion or smaller "window" of document
    Normally these scanner have a prescan window whcih shows the image that is being scanned. Only the selected area will be bright and the rest little shaded. You need to expand the selection, by dragging the line (dashes running along the border). Select default option in the software setting, if in doubt.
    S. Mohan
    Jul 18, 2009 | HP Office Equipment & Supplies
    Canoscan LIDE 25 using Vuescsan software
    The first scan is 'pre-scan' and the second one is the real scan. The pre-scan shows you a rough image and you can check borders etc. Look for options and switch off 'Pre-scan' S. Mohan, India
    Jun 03, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
    Scanned image is blank, although the page inside the scanner has text &/or picture.
    Scanner contains Unlock botton below it, just unlock it it will scan fine.
    Vikrant
    May 08, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
    Fujitsu fi-4530C
    Hi
    F at power on is a ROM Error. sounds like a main board issue. check for dry joints, but may need the whole board replacing.
    Sep 04, 2008 | Fujitsu fi-4530C Pass-Through Scanner
    Print area
    Scanners copy everything it can see. So make sure it can see what you are copying.
    Apr 18, 2007 | Lexmark X83 All-In-One InkJet Printer
    Lexmark P3150 All-In-One InkJet Printer Logo
    23 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
